Timing Belt Replacement - Thermostat Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yamasaki, May 31, 2010.
  1. May 31, 2010 at 2:21 PM
    Yamasaki
    Yamasaki [OP] Yamaha + Kawasaki!
    Denver, CO
    2003 Tacoma Limited TRD 4x4
    I will be paying the dealer to replace my timing belt/water pump/drive belts on my '03 Taco. I don't have the tools/patience to do it all myself.
    I am also ordering a pair of radiator hoses (upper/lower) and the thermostat and will have the dealer replace these 3 parts at same time.
    Since I will be providing the hoses/thermostat, I was wondering if the dealer will be charging me any extra labor to replace these parts?
    I figure with everything apart, this should be a non-issue but I know dealers always like to add fees especially for customer supplied parts (These are OEM repalcement parts ordered from Toyotapartscheap.com)
    If its extra labor I get it, but if there is not extra time required, I would like to know. Thanks.
  2. May 31, 2010 at 2:30 PM
    fpradojr36
    fpradojr36 Well-Known Member
    J.R.
    90804
    04 Prerunner, 2019 TRD 4x4
    Sorry to tell you but for sure they will charge extra. When you do timing belt replacment there is no need to take off hoses and t-stat. Maybe you can bargain with them and tell them for a discount. Or try and take it to independent shop it will be cheaper. It's a pretty easy job, its just holding cam's together when putting belt back on is a pain..
  3. May 31, 2010 at 2:31 PM
    StatutoryAPE
    StatutoryAPE Well-Known Member
    Joey
    Phoenix,AZ
    2000 Prerunner xtracab
    TRD Headers,CAI, dynomax super turbo, blacked out headlights, Smoked LED tails, Billy 5100 w/OME 881's and 5125's in rear, rear tube bumper, tint 35% front 3 windows & 5% in rear 3. fiberwerx 4.5's
    i dont see why they would charge extra labor since it will all be apart like you said. but if they do, i dont them charging much more
  4. May 31, 2010 at 2:37 PM
    btkicker
    btkicker Well-Known Member
    Denver
    '10 4x4 Reg Cab Manual
    They won't charge extra.
  5. May 31, 2010 at 3:48 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are the parts from TOYOTA?
    Sometimes the dealers won't install anything unless its TOYOTA parts.
  6. May 31, 2010 at 3:54 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    I think they would charge extra labour...just not as much since the engine is already apart...but it still takes them a little time to put it in...:cool:
  7. May 31, 2010 at 4:24 PM
    biggdog747
    biggdog747 Well-Known Member
    MI
    taco
    if you are replacing the water pump the t-stat sits inside of it so they can just pop the new one in. they will have to remove the top hose so its just the bottom one. if i was doing the job at work i would not charge any extra for that.
  8. May 31, 2010 at 8:51 PM
    ubnpast
    ubnpast Well-Known Member
    Central Jersey
    Try zip tying the belt to the cam gears, it works on other cars, havent done my tacoma yet although its overdue and I have the parts..
