JLink's Build
Discussion in '2nd Gen. Builds (2005-2015)' started by JLink, Aug 15, 2010.
  1. May 25, 2011 at 8:18 AM
    #41
    JLink
    JLink [OP] Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Haha thanks man! You've even seen it in person.. Kinda. Lol
  2. May 26, 2011 at 6:03 PM
    #42
    Sheppymach
    Sheppymach Well-Known Member
    Sheppy
    Philadelphia, Pa
    2014 4Runner trail edition
    BLU LOGIC bt, avid, weather tech mats & rain guards, 285/70/17, BenWA's totally AWESOME power sliding window mod.
    Josh which 10 holes had to be drilled out the bottom 5 on each side? & how long was total time to ship/get to you? They look nice bolted up.
  3. May 26, 2011 at 6:13 PM
    #43
    JLink
    Josh
    Ocean, NJ
    There are 10 holes on each side. 5 are already there, in the vertical part of the frame. The 5 that need to be drilled are for the bottom side of the frame. The sliders basically have L brackets that need to be bolted horizontally and vertically to the frame. I used a floor jack to push the drill up and it worked like a dream. I ordered them April 15th, and got them May 24th
    Strong as hell too!!
  4. Jul 5, 2011 at 2:42 PM
    #44
    JLink
    Josh
    Ocean, NJ
    Just ordered Fox extended travel shocks front and rear along with DSM UCA's.
    Will soon be ordering a new leaf pack, bump stops, and u bolt flip kit... maybe from All Pro???
  5. Jul 5, 2011 at 7:47 PM
    #45
    JLink
    Josh
    Ocean, NJ
    any words of wisdom?
  6. Jul 8, 2011 at 8:45 PM
    #46
    JLink
    Josh
    Ocean, NJ
  7. Jul 10, 2011 at 7:10 PM
    #47
    JLink
    Josh
    Ocean, NJ
    Yea I just saw on your build thread that you are getting fox's too, so that makes me feel like I made a good decision :D
    Thanks man!! Maybe some day you will see it in person.. last 2 times I've seen you the truck was at the dealer with the 4wd problem.
    RC soon???:rolleyes:
  8. Jul 12, 2011 at 1:07 PM
    #48
    JLink
    Josh
    Ocean, NJ
    Thanks Anthony!
    Yeah I can't wait to see how everything looks tomorrow. I'll be starting the install as soon as I get home from work.
    I'll need some help when my package from allpro gets here. I've never bled brakes before.
  9. Jul 14, 2011 at 3:58 AM
    #49
    JLink
    Josh
    Ocean, NJ
    UCA and Coilover install last night was extremely painful. Everything seemed to go the wrong way, nothing worked the way it should. Fox's didnt come with instructions, so I torqued the 3 top bolts to the wrong ft/lbs and stripped one of them out
  10. Jul 14, 2011 at 4:10 AM
    #50
    Namyo
    Namyo -
    Got er done tho:confused:
    Took me and two members 11 hrs to install mah coilovers :anonymous: might make you feel betta...
  11. Jul 14, 2011 at 4:49 PM
    #51
    JLink
    Josh
    Ocean, NJ
    Thanks guys.
    Yea the front is done for now. I still want to remove the LCA bolts and grease them and re install. and when I get a spanner wrench/ after the coils break in/ after I get new brake lines, I'll crank that bitch up as high as I can safely get it.
    Rear will have to wait till all pro gets expo leaf packs back in stock
  12. Jul 15, 2011 at 5:03 AM
    #52
    Namyo
    Namyo -
  13. Jul 17, 2011 at 6:52 PM
    #53
    JLink
    Josh
    Ocean, NJ
  14. Aug 1, 2011 at 10:40 AM
    #54
    JLink
    Josh
    Ocean, NJ
    Got my order from all pro last Friday and supposedly my doug thorley y pipe will be here tomorrow.
    As soon as my broken finger is healed up I'll have a lot to do.
  15. Aug 1, 2011 at 2:30 PM
    #55
    pAP
    pAP ==========
    NJ
    11 Tacoma SR5
    ARB locker and OBA, All Pro front & rear bumper, All Pro IFS skid & modified t-case skid, Custom Trans Skid., 4x Innovations sliders, Custom tire carrier/bed bars, Warn Winch, Fox 2.5" Front coilover, Walker Evans 2.5" rear Shock, All pro Leaf, All Pro U-bolt flip, Baja Designs lights, PIA 510 lights, TRD exhaust cut back, Doug Thorley Pipe Bomb
    Looking really good Josh! :thumbsup:
    A tip for the leafs, I would suggest unbolting the back first, then unbolt the front and slide the bolts out. Its easier to work the front bolts out and have the rear free. Same with putting the new ones back in except in reverse. put the bolts through the front then do the back. I have done them 4 times to know this... ;)
    Also, be prepared to break the studs and or f-up the bolts both flanges on the old Y-pipe flanges on each side. No matter how much heat I gave them, one stud broke and two nuts were f-d. Had to tap out one hole and send a new bolt through and clean up the threads on a stud and bolt.
  16. Aug 1, 2011 at 5:14 PM
    #56
    JLink
    Josh
    Ocean, NJ
    It would go faster, but I have a thing about doing all the work on my truck all by myself (when possible). The brake lines are something I'll need help with though, so if I could atleast get that done with you guys I'd be happy.
    Thanks. Ill have to remember that for the leafs. As for the exhaust.. I've heard that from a few other people too. I'm going to try a wd 40 bath a few times a day for atleast a few days before I try to un bolt it. Hopefully I wont have to deal with any problems.. but I'm sure I'll end up having to do the same thing. :D
  17. Aug 1, 2011 at 9:29 PM
    #57
    DdayIsNear
    DdayIsNear Well-Known Member
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    yes, the plan is to def unbolt the sliders, and drill the last few holes ( 2 i think) theni can rattle can them really quick and we can put them back on.
  18. Aug 2, 2011 at 7:47 PM
    #58
    JLink
    Josh
    Ocean, NJ
    yeaaaa....
    already got the ss extensions though.. so since I dont want them to go to waste, ill just install them... :cool:
    and I finally got my doug thorley y pipe.. ordered may 24, recieved august 2nd....... wow.
  19. Aug 3, 2011 at 11:50 AM
    #59
    JLink
    Josh
    Ocean, NJ
    So you just unbolted the bracket from the axle? No issues so far? What leaf packs are you using
  20. Aug 6, 2011 at 8:40 AM
    #60
    JLink
    Josh
    Ocean, NJ
    Intalled my DT Y pipe last night!
