Sandman614's #expoenough Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Sandman614, Feb 21, 2011.
  1. Aug 24, 2014 at 5:03 PM
    #301
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
  2. Aug 24, 2014 at 5:16 PM
    #302
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    That's the bushing that goes into the bottom of the top hat and the top shaft of the front shock. I emailed downsouthmotorsports.com (I bought them from them) about it.
  3. Aug 24, 2014 at 8:19 PM
    #303
    RaleighTaco
    RaleighTaco Well-Known Member
    Jonathon
    Raleigh NC
    '97 Toyota 4runner
    Dayum...didnt see that coming
    What do you think caused that? anything obvious?
  4. Aug 25, 2014 at 8:27 AM
    #304
    Sandman614
    Tim
    '06 SR5 Off Road
    Omg ARB is amazing!!!! They are replacing the shocks!!! I will be praising them and pushing their products and support even more so now!!
  5. Aug 25, 2014 at 8:32 AM
    #305
    RaleighTaco
    Jonathon
    Raleigh NC
    '97 Toyota 4runner
    :woot:
  6. Aug 25, 2014 at 8:39 AM
    #306
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    I told yah so. That is awesome.
  7. Aug 25, 2014 at 9:35 AM
    #307
    Sandman614
    Tim
    '06 SR5 Off Road
    Super excited!!
  8. Aug 28, 2014 at 7:52 AM
    #308
    Sandman614
    Tim
    '06 SR5 Off Road
    Warranty replacements from ARB/OME!!
  9. Aug 28, 2014 at 12:13 PM
    #309
    Sandman614
    Tim
    '06 SR5 Off Road
    Ready to do some work!
  10. Aug 29, 2014 at 6:40 AM
    #310
    Sandman614
    Tim
    '06 SR5 Off Road
    I finally got my air compressor finished. I need a lower psi pressure switch. The one way check valve doesn't work at lower than 1CFM and when psi increases the valves closes and blows off.
    Step one: remove junky wire nuts and relay, and add viair pressure switch/relay (I need a lower psi switch though).
    Step 2: Find mounting location
    Step 3: Build bracket
    Step 4: Plumb and wire
    9235-12X1.25-04 | M12x1.25 Metric Male x 1/4" NPTF Female
    http://www.discounthydraulichose.com/9235_Metric_x_NPTF_Female_p/9235.htm?1=1&CartID=0
    Final View:
    Crom likes this.
  11. Aug 29, 2014 at 12:42 PM
    #311
    Sandman614
    Tim
    '06 SR5 Off Road
    The results are in. About 80-85 psi is where the cfm drops too low for this unloading check valve.
  12. Aug 29, 2014 at 12:50 PM
    #312
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    IIRC That switch is designed to be used on a tank, not in a small setup like you have. might look into a small 1-2 gallon tank for the switch, and it would allow a small air reserve for whatever could use it.
  13. Aug 29, 2014 at 1:23 PM
    #313
    Sandman614
    Tim
    '06 SR5 Off Road
    (edit) are you referring to the viair pressure switch? That's not the problem. It'd rated for 90/150psi. Which I can't hit because of the below.
    The unloading check valve is blowing off pressure because the air flow drops below 1cfm.
    The solutions that I can think of are increasing the cfm (larger compressor) or limiting the psi (lower psi pressure switch).
  14. Aug 29, 2014 at 2:34 PM
    #314
    Gaunt596
    Matthew
    Central Maryland
    Okay, so you have a check valve that will dump air from the compressor before it goes into the system? i thought you meant the pressure switch was cutting the compressor early, which can happen with the unstable output from those type compressors. any reason for the check valve? if anything id go for a burst disk at the rated PSI over a check valve for a backup to the pressure switch if that's what its for.
  15. Aug 29, 2014 at 6:38 PM
    #315
    Sandman614
    Tim
    '06 SR5 Off Road
    The check valve is to allow the compressor to restart with 0 psi on the piston head while still holding pressure in the rest of the system, potentially extending the life of the compressor.
    The compressor just isn't strong/big enough to produce the flow at higher psi.
  16. Aug 29, 2014 at 7:06 PM
    #316
    Gaunt596
    Matthew
    Central Maryland
    ah, that makes more sense, sounds like you need moar beef in your compressor then.
  17. Aug 29, 2014 at 7:35 PM
    #317
    Sandman614
    Tim
    '06 SR5 Off Road
    Yep, or a lower cfm rated check valve, or a lower rated pressure switch.
  18. Sep 4, 2014 at 7:32 AM
    #318
    Sandman614
    Tim
    '06 SR5 Off Road
    http://www.lednews.org/calculate-power-consume-led-flexible-strip/
  19. Sep 4, 2014 at 12:33 PM
    #319
    RaleighTaco
    Jonathon
    Raleigh NC
    '97 Toyota 4runner
  20. Sep 5, 2014 at 2:35 PM
    #320
    Sandman614
    Tim
    '06 SR5 Off Road
