(SOLD) CanisLupus 2011 Tacoma Build
Discussion in '2nd Gen. Builds (2005-2015)' started by CanisLupus, May 22, 2011.
  1. Jan 18, 2015 at 4:55 PM
    #1561
    CanisLupus
    CanisLupus [OP] Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Do you have pictures of your setup Chris? That was also an idea for me...I saw one of your posts on an old thread talking about this while searching for ideas.
    Do you just leave the connection for the mic dangling under the seat or is your mic always connected?
  2. Jan 18, 2015 at 4:59 PM
    #1562
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    I don't have any pics. It's literally just laying on the floor under the seat. I leave the mic connected all the time. The mic sits in the conceal carry pocket on the front of the Wet Okole when I'm not using it and then up on the rear view when in use.
  3. Jan 18, 2015 at 11:20 PM
    #1563
    CanisLupus
    Stokesdale | NC
    Ah ok. I like the under shifter and behind rear cupholder ideas, but I may run into an issue with troubleshooting like you said. However, both of the above ideas aren't too inaccessible if something ever happens. Both ideas would just be behind a piece of trim.
    What I really want to try and do is a clean install of the mic mount either on the side of the center console trim or possibly up through the center of the cupholders behind the center console so I could just reach back and connect the mic as needed. I also bought the actual lapel mic mount for the 75 if I wanted to keep the mic connected and actually mounted somewhere.
  4. Jan 19, 2015 at 6:31 PM
    #1564
    CanisLupus
    Stokesdale | NC
    Some more ideas...
    Under seat:
    Behind pedals:
  5. Jan 19, 2015 at 8:20 PM
    #1565
    CanisLupus
    Stokesdale | NC
    Spring 2015 To-Do
  6. Jan 24, 2015 at 2:56 PM
    #1566
    CanisLupus
    Stokesdale | NC
    Hi-Lift function check definitely done :)
    Probie on my FD crew was being a typical GM owner and tried to go mudding (on private property...) and got stuck with his front end on top of a foot high stump. He called me and asked if I could help so I headed over while my probie's friend also came.
    We tried rocking the truck at first to get it off the stump but he was pretty stuck on it. So instead of trying to winch or pull him out (it was awkward positioning to get to where I would've had to park the truck), I pulled my Hi-Lift out and just jacked his truck up on his front tow hooks while he controlled reverse and brake. Worked like a charm...
    It got interesting when another guy drove by and got out of his truck, then started at Level 10 screaming at us for being on private property, saying he was going to call the cops. So I had this redneck guy, my redneck probie, and his redneck friend all yelling at each other while I tried to calm all of them down. I told the passerby that we knew that he (my probie) was a dumbass and we were just trying to get him off the property and be on our way, and obviously he wouldn't do this again. Luckily I was still in my uniform from the night before and he said only because I was a fireman and he lived in my first due that he would let us off.
    I've told my probie multiple times in the past whenever he talks about his mudding adventures that this is why all four wheelers get a bad name, for tearing up and going onto private property. Hopefully he learned his lesson...
  7. Jan 24, 2015 at 3:36 PM
    #1567
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
  8. Jan 25, 2015 at 3:10 PM
    #1568
    CanisLupus
    Stokesdale | NC
    Wired up new Cobra 75 with the help of Skygear today. Decided on the under cubby install and then the mic connection through the trim on the driver side console. Even if I have to troubleshoot anything, all I have to do is pop the cupholder trim out. The CB unit actually sits forward of the cupholders under the angled cubby.
    Still working on SWR; Channels 1/19/40 were all reading around 2.5, regardless of antenna height, which is a little confusing, but they are all at least under 3 so the radio is safe to use while I figure it out. Also still working on finalizing the mic connection and then I will ziptie the actual CB unit to keep it from sliding around, ziptie all the wiring, and pop the cupholder trim back in. Need to find a better grommet or solution to keep the mic connection in the plate.
  9. Jan 28, 2015 at 6:48 AM
    #1569
    CanisLupus
    Stokesdale | NC
    Truck going in for 35K service a bit early plus state inspection. Hope the stealership doesn't break anything. :homer:
  10. Jan 28, 2015 at 6:49 AM
    #1570
    CanisLupus
    Stokesdale | NC
    Also, does anyone have any tips for my SWR issues? Regardless of my antenna height, Channels 1/19/40 all have a SWR of about 2.5.
  11. Jan 28, 2015 at 6:55 AM
    #1571
    ckeene9
    Chesterfield, VA
    See Build Thread
    Which antenna?
  12. Jan 28, 2015 at 7:08 AM
    #1572
    CanisLupus
    Stokesdale | NC
    Wilson Flex 4'
  13. Jan 28, 2015 at 7:13 AM
    #1573
    AR15xAR10
    Saw your truck on instagram :spy:
  14. Jan 28, 2015 at 7:23 AM
    #1574
    ckeene9
    Chesterfield, VA
    See Build Thread
    Can you adjust the amount of antenna sticking out of the base? There should be a set screw on the base to allow for movement. I tuned a similar antenna back in the summer for a local guy and probably had to cut almost an inch off of it to get it decent.
  15. Jan 28, 2015 at 12:15 PM
    #1575
    CanisLupus
    Stokesdale | NC
    Ambigious' page?
    :eek:
    I don't think so, just the little tip with the set screw at the top that has maybe 3-4 inches of adjustment.
  16. Jan 28, 2015 at 12:24 PM
    #1576
    ckeene9
    Chesterfield, VA
    See Build Thread
    Never mind it was a different antenna that needed cutting
    So 1 nor 40 improve when you adjust the tip length?
  17. Jan 28, 2015 at 2:24 PM
    #1577
    AR15xAR10
    Rachelonaesthetics. Because you don't have an instagram :rolleyes:
  18. Jan 28, 2015 at 7:09 PM
    #1578
    CanisLupus
    Stokesdale | NC
    I've only done three adjustments to the antenna, but from the shortest to all the way out, all channels were at 2.5.
    I actually did see his because he asked for pics and told me he would use it. I haven't jumped on the IG bandwagon just yet :)
  19. Jan 28, 2015 at 7:16 PM
    #1579
    Adamar85
    Adamar85 Well-Known Member
    Adam
    Baker City, OR
    22 Ford F350 Lariat
    Nice build! Is your antenna a magnetic mount or are you running a different type of mount? My SWR was a little high, but it was because of the mount connection
  20. Jan 28, 2015 at 7:24 PM
    #1580
    CanisLupus
    Stokesdale | NC
