justinhw's reg cab 4x4 2.7 build
Old 05-26-2011, 07:01 PM   #1
justinhw [OP] justinhw is offline
justinhw is one of the sharper tools in the shedjustinhw is one of the sharper tools in the shedjustinhw is one of the sharper tools in the shedjustinhw is one of the sharper tools in the shedjustinhw is one of the sharper tools in the shedjustinhw is one of the sharper tools in the shedjustinhw is one of the sharper tools in the shedjustinhw is one of the sharper tools in the shedjustinhw is one of the sharper tools in the shedjustinhw is one of the sharper tools in the shedjustinhw is one of the sharper tools in the shed
justinhw's Tacoma Gallery
I want to share a bit of what I've done to my tacoma.
Here it is the day I bought it
I added a scangauge in the spare change compartment so it can be hidden away
Next I made some tool rolls to keep everything organized.
Then I built a sleeping platform. The bed has cut-outs for 1x6's which serve as support
The center support is routed so it can be secured between the slots in the bed. It's also notched out for the 1x6's, and when combined together the whole system is secure and won't move - doesn't need screws, bolts or any hardware
I used some carpet padding (closed cell foam, moisture barrier) to serve as a sleeping pad and recess the tie down tracks
And then I used carpeting that matches the inside of the camper shell
I can organize gear/kitchen/food/tools in the bins underneath, as well as secure gear on the top. The tracks are recessed enough so they don't bother me when I sleep.
Old 05-27-2011, 11:59 PM   #3
Hiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shed
Hiatt1991's Avatar
Hiatt1991's Tacoma Gallery
Send a message via MSN to Hiatt1991
Thats an awesome build man. I like how you made your own camper covers. They look factory!
Old 06-01-2011, 03:23 PM   #4
New Shoes - Toyo M-55
I found a really good deal on craigslist for 235/85/16's.. set of 4 for $150. They came off a Ford f250 powerstroke, still plenty of tread left.
$50 to mount & balance = $200 total said and done
These are Toyo M-55, an industrial/commercial 10ply E rated tire. There's a bit of a hum, but that's common with most aggressive tread tires (so I read).
These are also my first time driving with E rated tires, but it's too soon to have any opinions yet.
On to the pictures!
Solution to Taco-lean - 32" tires on the driver side, stock 30.5's on the passenger
At first, I thought I had a bit of rubbing at full lock, but after looking at the tire, there is plenty of clearance.
Old 06-01-2011, 03:31 PM   #5
Hiatt1991's Avatar
^ thats an excellent deal. I hope the spare is working out for you. How did you wire up your scanguage? Thats a cool little spot for it.
Old 06-01-2011, 04:47 PM   #6
Thanks, yah I got 2 out of 4 haha.. still keeping an eye out, but no rush. Winter's a long ways away
I saw it on expeditionportal, the trick is in the coin holder. You have to use a dremel and take off some of the plastic to get it to fit - luckily the coin holder detaches. I drilled a hole in the back and passed the cable through there, the obdII port is really close.
The only problem is that it's blocked if you turn the wheel sometimes so it might not be the best idea if you constantly need it
Old 06-02-2011, 06:27 PM   #7
Swinkey Dan is on a distinguished road
Swinkey Dan's Tacoma Gallery
I have been looking at 235 85 16 tires too and wondered if you have had any issues now that you have put a few miles on them. Nice work on the interior of the shell! I like it.
Old 06-08-2011, 12:38 AM   #8
I've put about 300 miles on them so far. No issues as of yet. My gas mileage has remained about the same; I attribute it to the decreased width (increasing mpg), increased rolling resistance of MT tires (reduced mpg), as well as slight mis-calibration due to the change in tires diameter (artificially low reading).
Sadly my TPMS light wasblinking - suggesting some sort of sensor/system error. I suspect a sensor was bumped/damaged while mounting, so what I did is cut the power to the TPMS module as well as wire up the light on the gauge cluster to go out; effectively disabling the TPMS system completely, not just muting it.
Old 06-08-2011, 12:44 AM   #9
Hiatt1991's Avatar
Glad the truck is doing well
Old 07-07-2011, 10:21 PM   #10
Shoeless
jessea1a is on a distinguished road
jessea1a's Avatar
Coast Guard: SAR!
jessea1a's Tacoma Gallery
truck looks great! i love the sleeper platform, great idea.
Old 07-21-2011, 08:48 AM   #11
Tacoma at 12,500 ft
Stock tacoma performed well going up to 12,500 ft for a research project. Tires (Toyo M55) were amazing; never lost traction.
View going up:
At the station:
One thing I did notice was that lack of power at altitude with the 4cyl. I spent 40 miles in 4lo 1st or 2nd gear
Old 07-21-2011, 07:55 PM   #13
it's a leer 100r
Old 07-21-2011, 11:01 PM   #15
it came with the truck when i bought it
Old 02-20-2012, 11:40 PM   #17
OME Installation
So after a year or so of CL/forums I finally pieced together a full OME kit and ARB bumper. I actually ended up with 2 OME sets; one with 885 springs and another with 884's. I decided to try 885's first since they already were on the strut.
FRONT INSTALL
Front install was very straightforward - much easier than I was expecting it to be from reading up online. I did not need to disconnect the steering arm. I had to remove the swaybar to allow room to remove the strut, and then remove 2 bolts that connect the lower control arm to the spindle (on either side of the lower ball joint). Once disconnected it allows that lower control arm to swing down independently. The reason people step/pry/force it down is because the attachment to the frame is on rubber mounts on bolts that are used for alignment; if you loosen them up it swings down easily (you'd have to re-align afterwards anyways). Luckily just putting my weight on the lower control arm afforded enough room to maneuver the strut into place.
Old suspension:
New Suspension:
REAR INSTALL
I have a camper & sleeping platform which together weigh in at about 300lbs. Jason at Demello Offroad suggested I install the Dakars without a shim. I read up on drivetrain geometry as well; I think shims would offset the normal angular velocity canceling designed into the stock U joints. My main concern would then be increased driveshaft operating angle - my hope is that my increased everyday load will keep the angle down compared to guys running open beds.
Installation was also straightforward; I unbolted the old leafs, moved the shackle to the Dakars, made sure everything was given a healthy coat of lithium grease, and installed. I ran into problems centering the axle and getting the front/rear eyelets in place - I had to place a jack under the axle as well as a bottle jack between the top of the leafs and the frame in order to get the springs into place. A few taps with a hammer and use of a screwdriver to pry into position were useful as well. I was able to maneuver the springs in place without having to drop the axle beyond the brake lines.
References I used:
FSM: http://www.ncttora.com/fsm/05+/index.htmlSMTRDSPORT's install: http://www.tacomaworld.com/forum/2nd...mtrdsport.html
Old 02-20-2012, 11:51 PM   #18
ARB install
I found a great deal on an ARB bumper and purchased it sight unseen (lesson learned - don't do that!). Reason being is that the bumper was bent inward slightly on the passenger side. Structurally it is still solid, but some creative grinding had to be done in order to get it to clear the body. Also, the seller did not include the stone guard or tension brackets. Luckily, Mitch at ARB was amazing and through some sort of wonderful coincidence he shipped me the parts I needed for free (left overs from another install they did). Those guys at ARB are really stand up folks and definitely made my day!
I did drive it with the stock suspension before installing the OME; the ARB (no winch) dropped the suspension about 0.5" in the front, which is not as much as I expected after reading online. However in driving around I did notice the weight and did not want to drive with it like that for an extended period of time.
Old 02-21-2012, 12:01 AM   #19
Initial Impressions
Lift Amounts
The front was lifted 2", rears 4". My concern installing 885's was CV angles, but they don't look extreme:
I realize it's hard to see the fins on top but they still have clearance.
The rear was lifted much higher than I expected, and higher than what I would like. Hopefully with settling they both will come down.
All said and done:
Driving Impressions
This suspension is much more firm, and is a pleasure to drive. I did not reinstall the sway bar as the springs had paint rubbed off from sway bar contact (previous owner) and I did not want to run into that problem again. I took a trip up north to Lassen National Park during which a piece of sheet metal flew into the middle of the highway; I was happy to find out that it still handles well without excessive sway in an emergency-maneuver environment.
However, one thing I did notice is a grinding/dry bearing sound when I let off the gas over 60 mph. I grease the U joints every oil change but I still think it may be related to the increased driveshaft operating angle.
Old 02-21-2012, 12:04 AM   #20
welcome to the incredibuild
Twistedfreedom is one of the sharper tools in the shedTwistedfreedom is one of the sharper tools in the shedTwistedfreedom is one of the sharper tools in the shedTwistedfreedom is one of the sharper tools in the shedTwistedfreedom is one of the sharper tools in the shedTwistedfreedom is one of the sharper tools in the shedTwistedfreedom is one of the sharper tools in the shedTwistedfreedom is one of the sharper tools in the shedTwistedfreedom is one of the sharper tools in the shedTwistedfreedom is one of the sharper tools in the shedTwistedfreedom is one of the sharper tools in the shed
Twistedfreedom's Avatar
Twistedfreedom's Tacoma Gallery
Nice truck!
that bearing sound is your drivers side needle bearing in the front differential common problem with lifting 2nd gen 4x4s.
East coast Gear supply is wiring on a fix for the problem should be out in a few weeks.
MartyMcfly's Build: Reg-Cab Long-Travel MartyMcfly 2nd Gen. Builds 441 04-06-2015 06:44 PM
((( JAZZYSTOY69 MY REG CAB BUILD ))) jazzystoy69 1st Gen. Builds 1 06-14-2014 01:29 PM
GARYRED REG CAB 4X4 BUILD GARYRED 2nd Gen. Builds 10 09-14-2011 06:13 AM
Trading a modded Dbl Cab for a stock 4x4 Reg Cab...Thoughts? KEG'sTACO General Automotive 25 06-08-2011 10:30 PM
Triumph843's reg cab build Triumph843 2nd Gen. Builds 20 09-25-2010 07:43 AM
