Seabass's Fish Taco Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Seabass, May 30, 2011.
  1. May 4, 2012 at 1:22 AM
    #21
    SampleFool
    SampleFool Three Percenter
    Steve
    Ga
    Silver
    08 off-road
    I agree man, You have a nice truck!
  2. Aug 16, 2012 at 11:24 PM
    #22
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Love the color :spy:
    that all pro bumper lines up very nicely!
  3. Sep 3, 2013 at 1:56 PM
    #23
    Seabass
    Seabass [OP] Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Finally got my expedition rack all done this past weekend. Big big thanks go out to Bryan (Specalt) for not only the use of his garage and tools, but also his welding experience and overall general know-how-to-get-shit-done. He also dedicated 15 hours to this project on his weekend. Also the same big thanks goes out to Steve (Staticsquelch) for being there with us all day and helping out with angle grinding, cutting, measuring, assembling, and just about every other damn thing we had to do to this rack to get it done.
    Picked the base rack up a couple months ago from Seth, who had it made by another member on TW. Rack was designed to be used with a soft topper, but I had other plans for it. RTT is the ultimate objective, but I don't have a grand laying around to spend so it's going to be my expedition rack until then. The goal with this first build was to make some under-slung baskets to hold my outdoor gear in their storage bins, and also to hold my full-size spare, thus freeing up the entire bed of the truck for much more gear.
    The rack itself was a great base and it's quite strong, especially for being a bolt-together. It came with a very simple aluminum clamp system that installed into the bed rails with cleats, but the clamp that held the footrail of this rack to the bed just didn't seem trustworthy. A little bit of hard off-roading would have probably been trouble on the clamps, especially with any type of load on them. I didn't want friction being the only thing that was holding this rack to my truck bed, so new clamps were also part of the plan.
    First, we had to take the base rack and straighten it all out. It wasn't built perfectly straight to begin with, so we had to break it all down to its bones, fill in the old bolt holes with metal, and level everything back out and drill new bolt holes. Once that was done, it was time to measure and start fabricating the baskets.
    Because of the uneven build of this rack in the first place, and even after 3 hours of "straightening", the two top holes were slightly different sizes but at least now they were squared off. Both baskets had to be fabbed up individually. One basket was built first, installed on the rack, and then new measurements were made for the second rack. The important thing was to get them the exact same width though. Each basket is made out of 1" square steel, welded at 45 degree angles on the corners so there are no open ends. The front basket that holds the spare tire has 2 extra rungs in the middle as runners, made out of 2x1" steel. The other basket has 2 runners in the middle of just the 1" steel, but they are still strong enough to hold my 230# body jumping up and down on them without any flex at all.
    Here's Bryan finishing up the welding on the second basket.
    Last project to do was to install welded rail brackets for the bed. By using the cleats and bolts from the other clamps, all we had to do was to make 6 L-shaped pieces of steel that welded to the foot rail of the rack, and drill a hole in them. Simple.
    Here's the rack after assembly and bolt-on, with my spare loaded in the front basket.
    So, here she sits all prepped and painted 2 days later. I made sure to really clean up the rack and the new baskets good with steel wool and mineral spirits before applying two coats of Rustoleum bedliner spray. Let it all cure up, then re-assembled the rack and put her back on the truck.
    And it all fits in my garage, even with the spare tire loaded. I also can take the spare off the rack and put 4 of my camping gear storage trunks perfectly up top. You can see a couple of them in this pic behind the rack on the shelf. I normally only take 2 of those trunks for even a long multi-night camp trip, so this just means I can leave the spare in place up top and then have the entire truck bed available for coolers, extra water, gas, more gear, etc.
    All in all, I'm really pleased with this project. It's rock solid, holds everything perfectly, and gives the truck a really unique look while also being practical. There's room under the baskets if I still wanted to put a canvas or poly cover on the rack and sleep under it, but I'll just go with a tent for now and wait for the RTT.
    TACOVRD likes this.
  4. Sep 3, 2013 at 3:19 PM
    #24
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Looking good man!
  5. Sep 3, 2013 at 3:33 PM
    #25
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    Very nice... If i ever get a deal on a softopper/bestop this will be the route i'll go. Slick.
  6. Nov 4, 2013 at 2:49 PM
    #26
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    That expedition rack is exactly what I am looking for...
  7. Dec 10, 2013 at 3:31 PM
    #27
    skygear
    skygear                    
    Teach me how to weld.
  8. Feb 20, 2014 at 3:30 PM
    #28
    Baoser
    Baoser Well-Known Member
    George
    Pittsburg, CA
    2012 DCSB Offroad
    Any more pictures of the Rack and where you altered it and the mounting feet? I got the same one and need to make "adjustments/repairs" to make it better...
  9. Feb 20, 2014 at 3:33 PM
    #29
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Yeah I will take some new pics showing it closer up to the brackets we put on it. They were simple... just took some 3/8 flat steel and bent it into a 90 degree with a vise. Welded them to the foot rails in 6 places, and drilled some 1/4" holes in them for the bolts that go into the rail cleats.
    We also just added some mount points to the top of it for my ARB awning. It's now all set up with my RTT and awning and it's solid as a rock. Next up... mount spots for jerry can holders.
  10. Feb 21, 2014 at 12:25 PM
    #30
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Ok so here's the really simple bracket system we added to it. This is a somewhat close-up of one of the 6 total brackets we welded on. Just took some 3/8" and bent it in the vise, ground the edges smooth, and did a super quick weld job all around the bracket. Drilled a hole in each bracket for the bolt that goes to the rail cleat, and threw a coat of bedliner spray on it.
    TACOVRD likes this.
  11. Feb 21, 2014 at 12:31 PM
    #31
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Recent work:
    - New CV axles
    - New UCA and LCA bushings
    - New upper ball joints on the LR's
    - Tepui Kukenam RTT added
    - ARB 6' awning added
    - Seafoam treatment through brake booster (worked nicely!)
    - Moved UltraGauge from the windshield mount to new adhesive mount over the rearview mirror
    - Tuff LED 4" round fog lights added to bumper
    Coming up:
    - Replace valve cover gaskets
    - PCV valve
    - Plugs/tune-up
    - New serpentine belt
  12. Feb 21, 2014 at 12:43 PM
    #32
    Papa Taco
    Papa Taco HARD CAAAAAAARRRRRRRL
    Jared
    Socal
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
    nice build.... that indigo is my favorite color
  13. Feb 21, 2014 at 1:02 PM
    #33
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Thanks Jared. It's still my favorite, too. So glad I didn't go with Speedway. But, I'm planning to Plasti-Dip the whole thing army drab green this summer so it might be bye-bye to the indigo. At least the dip is removable.
  14. Feb 21, 2014 at 1:03 PM
    #34
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Just updated front page with all current specs, and will be updating with latest pics soon.
  15. Feb 23, 2014 at 7:54 PM
    #35
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Every-time I scroll and see this thread, I'm all like, "KICK HIS ASS SEABASS!" :laugh: :wave:
    I hope you've seen the movie I'm referencing, if not... :spy: nothing to see here. :D
  16. Feb 26, 2014 at 5:31 PM
    #36
    Baja1981
    Baja1981 Active Member
    Carlus
    Philadelphia
    07 SR5
    Nice build man. It looks good.
  17. Apr 7, 2014 at 4:28 PM
    #37
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    As she sits now. This was from last weekend. Damn she sits low in the rear when loaded. This year is going to be the year of the expedition leafs and 10" rear shocks.
    TACOVRD likes this.
  18. Apr 7, 2014 at 4:35 PM
    #38
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    One more, on our way to our wedding photo shoot (how many of you wheeled in a tux before?)
    TACOVRD likes this.
  19. Apr 7, 2014 at 4:37 PM
    #39
    Seabass
    Adam
    AZ
    '06 Sport 4x4
  20. Jun 20, 2014 at 10:37 PM
    #40
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
