Jsmarine's Build Thread
Discussion in '2nd Gen. Builds (2005-2015)' started by jsmarine, Jul 5, 2011.
  1. Jul 29, 2011 at 8:24 AM
    #21
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    Great looking truck. How much did it run you to re-powder coat the bumper?
  2. Jul 29, 2011 at 8:30 AM
    #22
    jsmarine
    jsmarine [OP] Well-Known Member
    Jeff
    Dallas, TX
    2005 Tacoma SR5 Crew Cab 4x4
    ARB front & rear lockers ARB bull bar Warn XP9000 winch IPF lights
    $325 total. Included burning off old paint, sand blasting off the rust, and new powder coating.
  3. Sep 17, 2011 at 4:58 AM
    #23
    desertrock
    desertrock Well-Known Member
    Keoni
    El Paso, TX / Fountain, CO
    Tacoma TRD Off Road
    ToyTec Adjustable Coils W/Bilstein 5100's, Lower front Dif Kit, Rigid Industries Dually s, Throttle body spacer, ARB Front Bumper (some mods), ALL Pro Rear Bumper, Rear Expedition Leaf Springs, Rock Sliders, upgraded Tie Rods, Budbuilt fuel tank skid plates, KN Cold Air intake, Warn HID Lights-4", Banks CatBack Exhaust, Total Chaos UCA, AllPro Transfer Case Skidplate, 886 Rear backlight mod, rock lights, TRD Hawaii Off Road decal (sockmonkey), Garage built Tire Carrier.
    exactly what part number for the LED front turn signal/marker lights? Not an electrician here but what mods did you have to do to make them work on the ARB bumper? any pics to go along with the wiring?
  4. Sep 17, 2011 at 5:14 AM
    #24
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    nice truck man!
    after installing the snorkel on my truck I really didn't like the look of the white fenders, so I bedlined them. It looked too much like a city slicker for me. :laugh:
    I like the way yours looks though. THE FENDERS I MEAN!!!
  5. Sep 17, 2011 at 9:54 AM
    #25
    jsmarine
    Jeff
    Dallas, TX
    Thanks man!
  6. Sep 17, 2011 at 9:58 AM
    #26
    jsmarine
    Jeff
    Dallas, TX
    As far as the LED lights, I wish now I had taken more pictures of how I did it at the time. I bought the lights at Northern Tool and Equipment, but I just looked online and found the same lights on walmart.com, and they are cheaper than what I paid. (I paid $18.99 each) BTW, the brand is Blazer if you can find them elsewhere. Also, just an FYI they are sold individually, so buy two. http://www.walmart.com/ip/Blazer-LED-Oval-Stop-Turn-and-Tail-Light-Kit-Amber/15111215
    Basically what I did was drill two small holes on either side of the light that matched up to the holes in the ARB bumper. The holes will be on the edge of the light, and you are only drilling through the plastic housing, none of the LED's or wiring will be affected by the hole. Then I used a little silicone and filled the holes on both the front and back and put in a screw and attached it to the bumper. The silicone set up with the screw in place and should keep them sealed up from moisture and dirt. As for wiring, I saved the pigtail from the original lights that came with the ARB so I could reuse the connector; I just wired these lights to that pigtail. It took a little trial and error as the wires were different colors and I didn't know which was which, but I got it. The lights are turn signals and can stay on as marker lights.
    EDIT: Heres a couple pics of the lights from the inside of the bumper, kind of gives you a better idea of how they are mounted.
  7. Sep 18, 2011 at 5:20 AM
    #27
    desertrock
    Keoni
    Tacoma TRD Off Road
    Thanks for the info and pics. Gotsa do this mod ASAP
  8. Sep 18, 2011 at 12:12 PM
    #28
    92LandCruiser
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Nice build man!
  9. Sep 18, 2011 at 12:30 PM
    #29
    jsmarine
    Jeff
    Dallas, TX
    thanks!
  10. Sep 18, 2011 at 2:43 PM
    #30
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    Truck looks clean!
    White Out :taco:
    Keep it up! I hope mine will look badass one day.
  11. Oct 9, 2011 at 11:17 AM
    #31
    jsmarine
    Jeff
    Dallas, TX
    Put in an Optima Yellow Top battery this weekend; and also cleaned up all the wiring while I was at it. I also picked up a steel optima battery holder off eBay, which works much better than the factory battery hold down, since the Optima is a little smaller than the factory battery.
    #31
  12. Oct 20, 2011 at 3:11 PM
    #32
    jsmarine
    Jeff
    Dallas, TX
    Bought a 2011 white grille off of TW a few days ago, just got it today. Painted the emblem red and slapped everything on the truck. :)
  13. Oct 20, 2011 at 3:19 PM
    #33
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    Damn the white looks good!
  14. Oct 20, 2011 at 3:21 PM
    #34
    jsmarine
    Jeff
    Dallas, TX
    Thanks, I agree!
  15. Jan 13, 2012 at 1:34 PM
    #35
    chaN123
    chaN123 Well-Known Member
    Carlos
    Ft Bragg NC
    2012 Tacoma Prerunner
    Toytec lift 3" ,with LR upper control arms, UWS tool box, ARB recovery Kit, ARB bullbar, IPF 968, Warn winch M8000
    Hey, what model of compressor is that one, I want to get one but i want to make sure fits ok.
    nice build man
  16. Jan 13, 2012 at 1:37 PM
    #36
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    how did i miss this build thread!
    awesome truck love the color matched arb on there. and the leds signals are freaking great!
    really like what you done with it.
    subbed for future ideas :)
  17. Jan 13, 2012 at 1:38 PM
    #37
    chaN123
    Carlos
    Ft Bragg NC
    Hey, nice build man!!!....what model of compressor is that one, I wan to get it but i want to make sure it will fit perfect
  18. Jan 13, 2012 at 1:40 PM
    #38
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    this looks awesome excellent idea you had there. wow i think i'm going to try this in the future.
  19. Jan 13, 2012 at 2:29 PM
    #39
    jsmarine
    Jeff
    Dallas, TX
  20. Jan 13, 2012 at 2:30 PM
    #40
    PLC721
    Patrick
    Chandler, Az
    what battery mount is that for the optima?
