MattGecko's Build - 11 DCSB MGM OR 4x4
Old 09-18-2011, 12:49 PM   #1
mattgecko [OP] mattgecko is online now
Super Taco
mattgecko is one of the sharper tools in the shedmattgecko is one of the sharper tools in the shedmattgecko is one of the sharper tools in the shedmattgecko is one of the sharper tools in the shedmattgecko is one of the sharper tools in the shedmattgecko is one of the sharper tools in the shedmattgecko is one of the sharper tools in the shedmattgecko is one of the sharper tools in the shedmattgecko is one of the sharper tools in the shedmattgecko is one of the sharper tools in the shedmattgecko is one of the sharper tools in the shed
mattgecko's Avatar
mattgecko's Tacoma Gallery
Bought stock in July 2011:
2011 Tacoma Double Cab Short Bed Off-Road 4x4
Magnetic Gray Metallic
Jan 2015
Engine & under the hood:
TRD Super charger,
TRD CAI (new style),
TRD Cat-Back exhaust (chopped off behind axle),
Fuel pressure mod (for super charger) http://www.xr-underground.com/forum/...sure+regulator
42 draft designs - Stealth Oil Catch Can with external filter
ARB Air Compressor (CKMTA12),
Blue Sea 5028 external fuse block,
Redline Quick lift plus hood struts,
Interior:
Toyota alarm system,
Boost / Vacuum Gauge (PLX DM-5),
110v outlets in cab,
Back-up cam - anytime switch,
Weathertech mats,
4x4 Illuminated Switch ………………. TacomaWorld user: rcbs204,
Rear-View Mirror Lift Bracket ……….. TacomaWorld user: ImMrYo,
Contura V - compressor & off-road light Switches (from OTRATTW.com)
Uniden 520XL CB,
Sliding Window Security bar (powder coated) - Available here: http://www.tacomaworld.com/forum/2nd...urity-bar.html
Motion sensing glove box / arm box light - Available here: http://www.tacomaworld.com/forum/2nd...ion-light.html
Exterior:
All-Pro rock sliders (powder coated),
De-badged Doors and tailgate,
Front & rear mud flaps Removed,
Rear diff Breather relocate,
3' Firestik Firefly Antenna,
MGM Sleeper eyelids ...................... TacomaWorld user: Toyota Man
OEM MGM Color Matched Grille .…. TacomaWorld Vender: Camelback Toyota
Relentless front aluminum plate bumper - powder coated black
Relentless rear plate bumper - powder coated black
Lighting:
BI-Xenon FX-R stage IV HID kit with factory smoked headlights....... TacomaWorld vendor: TRS
Rigid Industries - Dually flood lights (mounted in front bumper)
25" LED Light Bar (120w) 10,800 lumens
Under hood LED lighting kit - Available here http://www.tacomaworld.com/forum/2nd...ed-lights.html
Bed rail LED lighting kit - Available here http://www.tacomaworld.com/forum/2nd...ed-lights.html
LED mini Pods (mounted in rear bumper, 10w ea)
Suspension and Stuff:
Camburg UCA 1.25 uni-ball,
Toytec/ Eibach springs,
(4) Bilstein 5100's,
WHE 3 leaf pack,
1/4" driver side spacer (Taco lean fixed),
3/8" top plate spacer kit with studs,
U Bolt flip kit,
Wheelers F&R super bumps,
OME Carrier bearing drop FK29
Axle shims
Shoes and Brakes:
ATX Ledge 17" (Teflon coating),
BFG AT KO 285/70/17,
Steel Braided Brake Lines (+3") .....http://www.tacomaworld.com/forum/gro...group-buy.html
ATO Dot 4 brake fluid - blue,
[/FONT]Future Mods:
Skid Plates
Old 09-18-2011, 01:30 PM   #2
Super Taco
mattgecko's Avatar
110v power outlet in cab
A few shots from the receptacle install.
I couldn't find the special clip in outlets that some of the other guys used so I just bought a regular dark gray one from Low's.
I cut a section out of a 1" PVC bushing and epoxy it in to place. You can push as hard as you want, the receptacle won’t budge.
Old 09-18-2011, 01:36 PM   #3
precoma is one of the sharper tools in the shedprecoma is one of the sharper tools in the shedprecoma is one of the sharper tools in the shedprecoma is one of the sharper tools in the shedprecoma is one of the sharper tools in the shedprecoma is one of the sharper tools in the shedprecoma is one of the sharper tools in the shedprecoma is one of the sharper tools in the shedprecoma is one of the sharper tools in the shedprecoma is one of the sharper tools in the shedprecoma is one of the sharper tools in the shed
precoma's Avatar
precoma's Tacoma Gallery
Do you have a close up shot of your rims
Old 09-18-2011, 01:54 PM   #4
Super Taco
mattgecko's Avatar
I cant decide if I like the center caps.
Old 09-18-2011, 02:09 PM   #5
Super Taco
mattgecko's Avatar
All Pro Kickout rock sliders
I decided to go with the silver/black speckled paint because the powder coat guy said it would take the most abuse.
60LBS each and 12 bolts into the frame per bar, these are some kick a$$ bars!!
Old 09-18-2011, 02:13 PM   #6
Super Taco
mattgecko's Avatar
Originally Posted by nmcqueen280 View Post
im no fan of center caps but without them it really looks like its missing something. id keep em.
I am thinking about have some 5 1/2" round x 1/8" think aluminum discs made up to replace the caps.
Old 10-10-2011, 07:33 AM   #7
Super Taco
mattgecko's Avatar
Westin Light Bar and 6" Procomp lights
I drilled and wire the bar.
Took a palm sander to the white KC letters.
Old 10-25-2011, 07:48 AM   #8
Super Taco
mattgecko's Avatar
Finally made it to the Hollister off-road park. Man the truck handles great!!
Old 10-25-2011, 07:52 AM   #9
What is this "search" you speak of?
Andrew H is one of the sharper tools in the shedAndrew H is one of the sharper tools in the shedAndrew H is one of the sharper tools in the shedAndrew H is one of the sharper tools in the shedAndrew H is one of the sharper tools in the shedAndrew H is one of the sharper tools in the shedAndrew H is one of the sharper tools in the shedAndrew H is one of the sharper tools in the shedAndrew H is one of the sharper tools in the shedAndrew H is one of the sharper tools in the shedAndrew H is one of the sharper tools in the shed
Andrew H's Avatar
Firefighter:
Andrew H's Tacoma Gallery
great looking truck. i have some family out in hollister. you know the Fowles?
Old 10-26-2011, 08:26 AM   #10
Super Taco
mattgecko's Avatar
Moved here not to long ago and don't know a lot of people here.
Old 03-23-2012, 02:30 PM   #11
mortifer is on a distinguished road
mortifer's Avatar
mortifer's Tacoma Gallery
Nice, that's my second favorite color on a Tacoma!
I like it with the center caps on.
Old 03-24-2012, 08:25 AM   #13
Super Taco
mattgecko's Avatar
Hey Mike - Yes definitely better with the center caps.
Originally Posted by Kidd View Post
Diggin the build!
Thanks! Nice wheels to you.
Old 05-17-2012, 07:37 AM   #15
Super Taco
mattgecko's Avatar
Just finished my HID retro's, saved 25% on through a TW group buy, thanks TRS for the great deal!!
I went with: FX-R 4, Orbit shrouds, Denso slim ballasts and 4300K bulbs.
The headlights are OEM black chrome and I painted the inner bowls MGM (color match).
Old 07-26-2012, 08:00 AM   #16
Super Taco
mattgecko's Avatar
The chrome shrouds just weren't working for me so cracked open the headlights and I painted them.
The local CHP kindly recommended that the off road lights get covered or I get ticketed, so I color match painted the ugly white pro-comp covers.
Old 09-16-2012, 01:01 PM   #17
Super Taco
mattgecko's Avatar
After a long 5 months of saving, tomorrow I am finally ordering a TRD supercharger. My brother and I are going to install it.
I can't wait!!!
Added sleeper eyelids a couple weeks ago:
Old 09-23-2012, 10:07 AM   #18
Super Taco
mattgecko's Avatar
It's like Christmas morning, but I'm not going to have time it install it for 2 very long weeks.
Old 09-24-2012, 02:37 PM   #19
mortifer's Avatar
Can you buy one for me too please!
What's the estimated HP/Torque?
Old 09-25-2012, 08:35 AM   #20
Super Taco
mattgecko's Avatar
Hey Mike,
You can have mine.... J/K
From 240HP ---> 304HP @ 5,400 RPM and 334lb/ft of torque at 3,600 RPM
Toyota Man's 11 DCSB Build Toyota Man 2nd Gen. Builds 115 03-15-2015 05:39 AM
eagle5521's - `11 DCSB TX Build eagle5521 2nd Gen. Builds 64 02-07-2013 11:41 PM
( Feeler) 2010 DCSB 4x4 Sport MGM Asterisk 2nd Gen Tacoma Marketplace 25 03-17-2012 10:22 AM
DCSB SR5 V6 6spd 4x4 MGM w/ camper shell for sale - ATL wordtothis 2nd Gen Tacoma Marketplace 0 12-02-2011 09:12 PM
My '11 MGM DCSB city box Mtek 2nd Gen. Builds 7 09-25-2011 02:18 PM
