big sky's modest 12 build
Discussion in '2nd Gen. Builds (2005-2015)' started by big sky, May 6, 2012.
  1. May 6, 2012 at 5:28 PM
    big sky
    big sky [OP] Well-Known Member
    Montana
    2012 TRD Sport DCSB 4x4
    nothing too fancy, but then again I've only had it for two weeks :D
    day I brought it home, 2012 Double Cab Sport 6 speed
    didn't like the front mud flaps (looked like they were just begging to get torn off :)), so they were the first to go
    ^ also pic'd are some silver FJ TRD center caps :D
    installed a TRD exhaust this weekend
    comapro vs oe, smaller diameter muffler and larger diameter pipe (2.5" vs 2.25")
    shiny tip :D
    wasn't happy w/ the rear mudflaps, but wanted to leave some on there- so just trimmed the oe ones, marked a line w/ a straight edge and cut w/ tin snips, used the lower portion to trace the curves and cut those- smoothed it up w/ a sanding drum
    finished
    installed an Avid lightbar- very high quality piece; had it Rhinolined as it comes bare metal
    also rattle canned the Toyota emblem super white w/ a couple light shots of clear
    rear quarter shot w/ shortened mudflap, TRD exhaust and TRD center caps :D
    I've got to get a high lift jack and shovel mounted as my next project
  2. May 7, 2012 at 12:53 AM
    COMAtose HI
    COMAtose HI Well-Known Member
    2012 TRD SPORT 4x4
    6" Procomp Stage 1 Suspension Lift, Custom 6" Alcan Springs, N-Fab Side Steps, Husky Floor Liners, Wet Okole Seat Covers, Debadged, Weathertech Side Window Deflectors, 13" Antenna from AntennaX.com, 35% Tint for front windows, Procomp 7032 Series 18x9 wheels, 33x12.50 Nitto Mud Grappler tires
    nice!!! i like the fj caps for the wheels...those look super clean!!!
  3. May 7, 2012 at 6:36 PM
    big sky
    Montana
    I used ATO mounts that I had rhinolined to mount the hi-lift, very well designed and the jack is very secure
    have an idea for the shovel, see if it works out
  4. May 8, 2012 at 1:14 PM
    gusher
    gusher SUPERCHARGED!!!
    Greg
    Hudson NH
    08 Tacoma Double Cab 4x4 long bed, TRD Sport
    '08 Indigo Double Cab TRD Sport 4x4 Long Bed, Grillcraft grill, Pioneer AVH-P3200BT head unit, XM receiver, Boyo backup camera, Custom devil horns Toyota logo, Black headlight mod, Fog lights on anytime mod, Maglight mount, Weathertech floor liners, Debadged, Trex color-matched eyelids, Access tonneau cover, Toyota bed divider, Sno-way 7'4" snow plow, Auxiliary backup lights, Rear spring TSB, Removed front mud flaps, 2.5" Hell Bent Steel front lift, 285/70-17 Goodyear Wrangler Duratracs, Satin black MB TKO wheels, Black Go Rhino Dominator II nerf steps, custom HomeLink install, CompuStar remote starter, Redline Tuning QuickLift Elite hood struts, Toyota bed mat, Custom short Taco antenna, TRD cold air intake, TRD exhaust, TRD supercharger
    Looks good man! Great start on a clean looking ride... :thumbsup:
  5. May 9, 2012 at 7:14 AM
    big sky
    Montana
    I think I've got the shovel mount figured out, I'm going to use a couple of quick fist clamps
    and a couple of t-nuts to slide into the rails to hold the clamps
  6. May 27, 2012 at 1:35 PM
    big sky
    Montana
    this makes for an easy and clean way to mount a shovel/axe/similar item utilizing the bed mount system
    first you'll need a pair of quick fists
    http://www.endroad.com/index.php/quick-fist-mounts.html
    then a pair of t-slot nuts
    http://www.zorotools.com/g/00063230/k-G1777921/
    and finally a pair of 3/8" bolts (I used a round head hex socket)- I went 3/4" length, but I think 1" might be better
    you have to drill the hole out a little in the quick fist to get the 3/8" bolt in
    I assembled the t-slot nut on loosely, opened up the rail and slid both quickfists in, get them to the right location and simply tighten- done :)
  7. Jul 25, 2012 at 7:34 AM
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    Wet Okole's (front & rear), Weathertech Floormats (front & rear), cheap tailgate theft mod, extra d-rings, low profile toolbox (flat black), Thule Roof Rack (58" load bars), Thule Ski/Snowboard Roof Rack, Blacked Out Badges, Fishing Bobber Trailer Ball Cover, AVIC-X930BT w/ XM & steering controls, 5100s All Around (front set at .85), Eibach Coils, Rear TSB, rear AAL, LR UCAs, Toytec Diff. Drop, Mudflap Delete, Tailgate Reinforcement, Spidertrax (all 4), 285 Nittos, Rear Diff Breather Extension, TRD Exhaust, Powered Rear Sliding Window, DeeZee Bedmat, rear-view anytime mod, trailer bracket relocate, fog light anytime mod, redline hood struts, Satoshi with Homertaco Custom TRD Mesh, Hella 500s behind the grill, Brighter Reverse Lights
    good start! were those t slot nuts the 9/16 (table) and 7/8 (base) w/ 3/8-16 thread? Looking to mount something similar and want to get the right size.
    thanks!
  8. Jul 25, 2012 at 11:36 AM
    big sky
    Montana
    danke :) those are the correct dimensions- cheapest I could find them was at Zorotools @ $2.50 a pop- might be cheaper elsewhere????
  9. Jul 25, 2012 at 12:29 PM
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    awesome thanks! just ordered 6 so i can start putting that rail to better use.
  10. Sep 9, 2017 at 7:06 PM
    big sky
    Montana
    been awhile- add a softtopper that I can use as a "camper"
  11. Sep 9, 2017 at 7:20 PM
    big sky
    Montana
    oh and powdercoated the oe rims too
  12. Jun 17, 2020 at 5:29 PM
    big sky
    Montana
    loving my near stock Taco- it's taken on dozens of great trip and great elk hunts; loving the soft top- have slept in the back a bunch of different times
    I do have a couple of aluminum skid plates on the way, will snap some pics when I get them
    as she sits now
  13. Jun 28, 2020 at 3:17 PM
    big sky
    Montana
    got the Ricochet Off Road aluminum bash plate and LCA plates installed; very nice build quality and very beefy- the oe front skid plate, not so beefy
  14. Jul 3, 2020 at 12:23 PM
    big sky
    Montana
    got one of the beefier front hooks (oe on the Off Road) and had it and the rear recovery hitch powdered coated red; finally got around to relocating/modifying my hi lift and shovel attachments- I had to remove them w/ the soft topper
  15. Apr 7, 2022 at 2:09 PM
    big sky
    Montana
    New Method Racing rims; truck looks more tan than white these days :D
  16. Apr 21, 2022 at 2:19 PM
    big sky
    Montana
    Finally installed a 20" led bar (Cali Raised) that's been sitting in my garage for over a year. They had nice looking oem looking switches too.
