The Frustrated Taco Build
Discussion in '2nd Gen. Builds (2005-2015)' started by FrustrationFabTaco, May 26, 2012.
  1. Dec 30, 2014 at 6:44 PM
    #1241
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Holy fook that shit is expensive!
  2. Dec 30, 2014 at 6:45 PM
    #1242
    loco
    loco Who wants to ride my Brack Burrito???
    Phil
    Virginia Beach, VA
    1996 Diesel Land Cruiser AKA Brack Burrito
    Well its a land Cruiser with a diesel so I've got that going for me.
    I still think there is more value in a full bedslide for 800 than an ARB fridge slide for 300...
  3. Dec 30, 2014 at 6:57 PM
    #1243
    ckeene9
    Chesterfield, VA
    See Build Thread
    Agreed!
  4. Dec 30, 2014 at 7:01 PM
    #1244
    FrustrationFabTaco
    FrustrationFabTaco [OP] Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    Can make both for cheap ;)
  5. Jan 10, 2015 at 11:03 AM
    #1245
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    Will probably pick up a group 31 battery within the coming month or so. OBA setup is still in progress, I want to get a bigger tank and find a better place for the compressor so its not in the tool box. Skids and rear bumper will be built over spring break in March. Bumper plan is identical to ATO using 3/16 for the main section and 10 gauge for the sides. Tire carrier will swing up like , be able to hold a 35, and have brackets for a set of reverse light pods.
    Going to measure the pelfrey to see if I can squeeze a 30" led bar inside or on top of it. :spy:
  6. Jan 10, 2015 at 12:12 PM
    #1246
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    I'm certain at one time I measured and a 30" will fit. And skids you say :spy:
  7. Jan 10, 2015 at 2:05 PM
    #1247
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    :D artificial sun time!
    Yez, skids :spy:
  8. Jan 10, 2015 at 2:38 PM
    #1248
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    If you have extra metal and want to build a set to sell I ma be interested after basic
  9. Jan 10, 2015 at 9:34 PM
    #1249
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    I'll see what I can do about making a couple extra sets
  10. Jan 10, 2015 at 10:17 PM
    #1250
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    mad respect for you fabbing your own armor :thumbsup:
  11. Jan 10, 2015 at 11:34 PM
    #1251
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Itd be a no brainer for some extra cash!
  12. Jan 11, 2015 at 2:50 PM
    #1252
    NC15TRD
    Nick
    PA
    I have dibs on set 2.0
  13. Jan 15, 2015 at 9:49 AM
    #1253
    NC15TRD
    Nick
    PA
    Stop funding this build and tell me a proposition you tease!
  14. Jan 16, 2015 at 8:31 AM
    #1254
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    Still need to get you a retro
  15. Jan 16, 2015 at 8:41 AM
    #1255
    NC15TRD
    Nick
    PA
    :brianr: Bish please that'll happen whenever a deer takes out the bumper, fogs, and headlights so insurance pays for it!
  16. Jan 16, 2015 at 8:44 AM
    #1256
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    And I don't have to worry about that now :D
  17. Feb 14, 2015 at 2:41 PM
    #1257
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    Current plan: Compressor in tool box, 2.5 gal viair tank under the truck, manifold with secondary regulator for lockers and pressure relay in the larger bed storage compartment, air line running to open bed cubby area for easy access.
    -Rear bumper
    -Skids
    -Rock lights
    -OBA completed
    -Change oil
    -Paint bumpers, sliders, skids, frame with rust reformer and rustoleum
    -New (smaller) ground harness for otrattw switches
    -Epoxy top radio bracket
    -Permanent windshield GoPro Mount
    -Group 35 Diehard platinum battery
    -Diagnose shorting? problem with otrattw panel (sometimes power is activated to them when parking lights turned on) not really sure whats going on, going to try a different source for the dash light tap.
    -Reverse light pods
    Going to have me some work to do over spring break. Hopefully I can get all of it knocked out.
  18. Feb 14, 2015 at 5:39 PM
    #1258
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    Yeah just installed it over Christmas. I have no idea what the problem is. I thought I solved it after undoing all the connections then doing it again but it's started acting up again. They are wired for the indicator to come on with dash lights but sometimes after I hit a bump or something the switches will indicate they are switched on and the fog lights will come on (since they're the only things currently hooked up). Then it'll go out and back to the indicator. Only happens when the parking lights/ halos or headlights are on. I currently have the dash lights tapped to the factory fog light wire so I'm going to pull that and use a fuse tap to a blank spot instead as well as wrap the three connections where the harnesses run to the single wire. Hoping one of those two things solves the problem.
    Only drive once a week so hoping the salt doesn't molest it too bad :eek:
  19. Feb 23, 2015 at 6:20 PM
    #1259
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    Just ordered LED strips to do the rock lights. Steel order will happen within the next couple days. I'll pick up other misc stuff when I get home.
    Decided not to jump to the 2.5 gal tank. 1 gal isn't really going to make much difference and may as well use the tank included with the puma. Whole setup is going to be divorced in the tool box, kinda makes sense since I have to get into the tool box to get the air hose anyway.
  20. Feb 25, 2015 at 4:29 PM
    #1260
    NC15TRD
    Nick
    PA
    My skids done yet?
