Mountain Man Limo-ILuvtheMountains DCLB Build
Discussion in '2nd Gen. Builds (2005-2015)' started by NativeTaco, May 31, 2012.
  1. Mar 21, 2013 at 8:44 PM
    #201
    NativeTaco
    NativeTaco [OP] Mountain Man
    Travis
    Fort Collins, CO
    '08 DCLB
    ARB, OME, BAMF, ATO, Rigid, more... Mountain Man Limousine
    Is that factory? I never even thought of that problem.
    Always good to hear of someone getting the best of Vegas. :cool:
  2. Mar 21, 2013 at 8:45 PM
    #202
    Manwithoutaplan
    ID
    Yep that comes factory been on mt for while. Was on the 1st gen to.
  3. Mar 21, 2013 at 8:49 PM
    #203
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    Haven't spent too much time in the trd models... That's a cool feature.
  4. Mar 21, 2013 at 8:51 PM
    #204
    Manwithoutaplan
    ID
    I use it all the time because I am lazy to press the clutch in haha.
  5. Mar 22, 2013 at 5:15 PM
    #205
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
  6. Mar 22, 2013 at 5:23 PM
    #206
    Tonto27
    Tonto27 We came, we saw, we kicked its ass!
    Joey
    Denver, CO
    2004 double cab
    A bumper here, some tires there..... you know, stuff.
    :woot: just look at all that new rubber.... and those rims :drool:
  7. Mar 22, 2013 at 5:28 PM
    #207
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    THanks Buddy! Off to the cabin, see you guys in a few days!
  8. Mar 22, 2013 at 11:12 PM
    #208
    Turbofed
    Turbofed Well-Known Member
    Kevin
    Roseville, CA
    13 O/R Dbl-Cab SB 4x4 6-Speed
    Color Matched Sports Grill, Front Skid Plate, Bed Mat
    Nice set up Travis I love the build, those wheels and tires look awesome!!!!
  9. Mar 23, 2013 at 10:07 AM
    #209
    elk340
    elk340 Well-Known Member
    Justin
    Fort Collins, CO
    '11 Tacoma TRD Off-Road
    Toytec ULK; OME Dakar leaf packs; Light Racing UCAs; OME carrier bearing drop; Toytec 3 degree axle shims; Toytec sway bar relocate kit; Toytec extended rear brake lines; ARE CX topper; BAMF rear differential skid; BAMF LCA skids; BAMF sliders; Budbuilt IFS, mid, transmission, and gas tank skids; HomerTaco mesh; River Rat 69 satoshi grille; Toyota Land Cruiser radiator grille emblem; tinted windows; Toyota all-weather floor mats; Toyota bedmat; I-Pod interface; block heater; ATO hi-lift bed rail mounts; HL-605 Hi-Lift; RotoPax 4-gallon gas can and bed rail mounts; mattgecko sliding window security bar; Sockmonkey decals.
    Looks good man!
  10. Mar 23, 2013 at 10:18 AM
    #210
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    :jellydance: of those tires :drool:
  11. Mar 24, 2013 at 10:06 AM
    #211
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    Thanks for the compliments guys!
    First report of the km2s in the snow... Awesome! Wasnt more than 8" deep but still did great! These wheels really tied the rest of the black stuff together, I'm loving it!
  12. Mar 30, 2013 at 9:48 PM
    #212
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    Got started on the sliders today. Will probably be done by Monday, but Easter stuff is happening tomorrow, so I'm not sure how much progress will happen. Anyway, here they are:
    Here is the material pile. 1/8" 2x2 square tube for the majority. 3/16" square for the legs and 3/16" flat for the gussets. 3/16" 3x2 angle for the frame plates. Grade 8 flange-head nuts and bolts to bolt them to the frame.
    My Dad doing some cutting
    I cut out a wedge so that I can bend out the 2x2 for the kickout.
    A little better view of the rear section
    And of the front
    My Dad lit his shirt on fire while using the grinder!
  13. Mar 31, 2013 at 7:34 AM
    #213
    elk340
    Justin
    Fort Collins, CO
    Amazing progress man! Cannot wait to see them all painted and mounted up. How come you decided to bolt them up instead of welding them on? I went bolt on just so that I could sell them if I ever had to and/or remove them to touch-up the paint.
  14. Mar 31, 2013 at 9:11 AM
    #214
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    I wanted to be able to remove them if my design was too weak and folded under impact. Plus i figured that if I used grade 8 bolts and put enough of them, it won't be any weaker than welding. My dad is a very experienced welder and said that welding can weaken material just like drilling, so if that is the case might as well make them removable for the same reasons as you stated. I just need to figure out if I will put some on the bottom of the frame too. Ideas?
    Anyway thanks and I can't wait till they are done!
  15. Mar 31, 2013 at 9:18 AM
    #215
    hard2kill
    hard2kill Well-Known Member
    John
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    looking good man
  16. Apr 1, 2013 at 10:00 PM
    #216
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    Slight progress. Still need to get the legs and gussets cut, then work on a plan for mounting. I have grade 8 bolts, but some of the ones I bought aren't going to be long enough. Or I can weld them and have to wait longer until I can get someone more skilled in vertical welds to help me with the mounting...
    Can't see the detail very well yet, but the shadow on the ground gives an idea of what the supports look like.
  17. Apr 3, 2013 at 7:57 AM
    #217
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    Cut the legs and gussets yesterday. This is taking WAY longer than I thought it would. Now to start looking at the frame plates. Since I decided to bolt them on I need to pick strong places and make wide plates, but avoiding rivets, etc. makes cutting the plates tricky (since I am cutting everything with a hand grinder). Then I have to start trying to drill out the frame. I have heard the frame destroys bits, so I will probably have to go buy a couple really nice bits...$$$ :( There have been several expenses that I did not expect, such as grade 8 hardware (almost $80!). It may have been cheaper to just buy these things, but I wanted AT LEAST one thing on this truck to be DIY. Despite the time and the money, I am still glad I am building these myself (with some good help from friends and family). :cheers:
  18. Apr 3, 2013 at 10:53 AM
    #218
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    If you can..angle the it up a tad..
    this will do 2 things.
    1) The main rail that is right next to the frame wont be flat side down. This allows just the corner of the square tubing to slide over the rock or whatever. Less surface is touching allowing it to slide easier and it'll be in a triagle for impacts the strongest shape ever.
    2) the outer rails won't be flush with the frame therefore if you pass by something close you wont get them caught on something.
    unless you already did all that and i just can't tell from the pics :p haha
    lookin good though
    i want rims just that that for when i go to 17s and 35s..
  19. Apr 3, 2013 at 7:11 PM
    #219
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    I wanted to do that but the wife is pregnant again and these have to at least look like I attempted to have them double duty as steps!
  20. Apr 3, 2013 at 7:56 PM
    #220
    Blackdawg
    Monte
    Wyoming/St. Louis
    Do t worry even mine are angled and still work great as steps.
