Team Lombardo 2012 Build
Old 07-02-2012, 10:48 PM   #1
WE'VE LANDED ON THE MOON!
TeamLombardo is one of the sharper tools in the shedTeamLombardo is one of the sharper tools in the shedTeamLombardo is one of the sharper tools in the shedTeamLombardo is one of the sharper tools in the shedTeamLombardo is one of the sharper tools in the shedTeamLombardo is one of the sharper tools in the shedTeamLombardo is one of the sharper tools in the shedTeamLombardo is one of the sharper tools in the shedTeamLombardo is one of the sharper tools in the shedTeamLombardo is one of the sharper tools in the shedTeamLombardo is one of the sharper tools in the shed
TeamLombardo's Avatar
Army:
TeamLombardo's Tacoma Gallery
Pre-lift:
Lifted:
*Pre-Lift Drive Shaft Measurements (Flange to Flange):
Top: 68"
Bottom: 67 15/16"
Difference top from bottom: 1/16"
**Post-Lift Drive Shaft Measurements (Flange to Flange): (Taken on 7/15/12 with 4,267 miles)
Top: 68 13/32"
Bottom: 68 1/16"
Difference top from bottom: 11/32"
***Measurement Difference from Pre-Lift to Post-Lift: 9/32"
__________________________________________________ ____
*Pre-Lift Hub Center to Bottom of Fender Measurements:
FD: 20 1/4"
FP: 20 3/8"
RD: 22 1/16"
RP: 21 5/16"
**Post-Lift Hub Center to Bottom of Fender Measurements: (Taken on 7/15/12 with 4,267 miles)
FD: 23 1/2"
FP: 24 1/8"
RD: 25 1/8"
RP: 25 1/16"
***Measurement Differences from Pre-Lift to Post-Lift: (As of 7/15/12 with 4,267 miles)
FD: 3 1/4"
FP: 3 25/32" (pretty much 3 3/4")
RD: 3 1/16"
RP: 3 3/4"
****Hub Center to Bottom of Fender Measurements taken again at 5,421 miles on 9/16/12 (1,154 miles since suspension install)
FD: 23 1/2" (no change)
FP: 24 1/8" (no change)
RD: 25 1/8" (no change)
RP: 25 1/4" (+ 3/16") Not sure what happen here....
*****Hub Center to Bottom of Fender Measurements taken at 7,200 miles on 11/2/12. Additional weight added: Bumper, Sliders, VR8000-s, RI 20" SR LED, RI Duallys (2,933 miles since suspension install)
FD: 23 3/16" (-5/16" from previous measurement)
FP: 23 13/16" (-5/16" from previous measurement)
RD: 25 1/16" (-1/16" from previous measurement)
RP: 25 1/16" (-3/16" from previous measurement)
Based on the measurements above the Front Driver's side is 5/8" lower than the Front Passenger's side, despite having an OME 5mm trim packer installed.
I installed a 10mm top plate spacer w/extended studs to the Front Driver's side, which was supposed to give me an additional 1/2" to 5/8" lift according to Wheeler's Off-Road. Below are the measurements AFTER installing the 10mm spacer to the Driver's Side only.
******Hub Center to Bottom of Fender Measurements taken at 7,713 miles on 11/17/12 (3,446 miles since suspension install)
FD: 23 7/16" (+1/4" from previous measurement)
FP: 23 7/8" (+1/16" from previous measurement)
RD: 25 1/16" (no change)
RP: 24 13/16" (-1/4" from previous measurement)
CV Angle Before Lift (Driver's side)
CV Angle After Lift (Driver's side)
Armor:
-Pelfreybilt (socalduckslayer) Front Bumper
-Demello Hybrid Bolt-on Sliders
Exterior:
-Derped Emblems (TOYOTA lettering removed from tailgate)
-Derped Grill
-Stubby Antenna
Interior:
-Salex Center Console Organizer www.salexorganizers.com
-WeatherTech Digital Floor Liners
-20% Tint all A-round
Lighting:
-RI 20" LED Light Bar (www.amazon.com)
--Black Light Bar Covers
--Flood Duallys (www.truckcustomizers.com)
-BHLM
-Anytime Fogs
Performance:
-TRD Exhausted
-SS Braided Front/Rear Brake Lines
Recovery:
-Warn VR8000-s (www.4wheelparts.com Coupon Code CC5OFF for 5% off)
-Wheelers Snatch Strap
-Smittybilt 3/4" Black D-Ring Shackles
Suspension:
-OME Suspension
--886x Coils
--90000 Nitrocharger Front
--N182 Rear
--CB Drop Kit
--5mm Trim Packer (D.S. only to level out)
--10mm Top Plate Spacer (D.S. only to level out)
-Dakar Leaf Packs
-Toytec 3 deg Shims w/Longer Center Pins
-LR UCAs
Wheels and Tires:
-Pro Comp 7069-6883
-GY Wrangler MT/R 285/75/16
Misc:
-CV Boot Mod (My write up: http://www.tacomaworld.com/forum/2nd...ml#post5972612)
-TacomaWorld.com Sticker (Thanks tcBob )
-Modified Grill for Access to Winch Solenoid
-WARN Black Fairlead
-CMC
On Order:
-N/A
Sitting in the Garage Waiting to Install:
-N/A
Later Mods:
-Pelfreybilt HC Rear Bumper
---Skids
----Front/IFS Skid
-----Trans/Mid Skid
------Transfer-Exhaust/Rear Skid
-60" All-Cast Hi-Lift
-ATO Hi-Lift Mounts
-Toytec U-bolt Flip Kit
-Color Matched Grille Surround
-TOYOTA Lettering from MetalMiller/Emblemart.com
-PIAA Xtreme White Plus Anti-Vibration Bulbs Part# 70856 ($70 from amazon)
-Soft topper
-Custom Fenders
Old 07-02-2012, 10:58 PM   #4
Army:
Originally Posted by OZ-T View Post
Lift
Lift
Lift
I can safely say that tomorrow I will be ordering said lift. About 99% sure of this....
Old 07-02-2012, 11:00 PM   #5
attack ships on fire off the shoulder of Orion
OZ-T's Avatar
OZ-T's Tacoma Gallery
886's ?
Old 07-02-2012, 11:05 PM   #7
OZ-T's Avatar
Yes. Penguins cc has convinced me
I think it's a good call
Get OME shocks if you are going to run 886's
Old 07-02-2012, 11:12 PM   #8
Army:
Fo shizzle. OME all the way!
Old 08-22-2012, 08:36 AM   #10
evanmb31's Avatar
evanmb31's Tacoma Gallery
Nice, very detailed lift specs, thanks for the info this should help me with my lift, the truck looks awesome.
Old 09-07-2012, 08:13 PM   #11
Army:
Warn winch and Rigid fogs arrived......Now, just waiting on the bumper to get here so I can bloody up the knuckles
Old 09-08-2012, 09:55 PM   #13
Army:
Originally Posted by PSU Taco85 View Post
Good looking '12. Gonna look sweet with all those future mods you have in store
Thanx. I really can't wait to get it all on. I don't know why the hell my sliders haven't got here yet though. Starting to chap my ass
Old 09-16-2012, 12:48 AM   #14
Army:
Red Sands, El Paso, TX.
Airing down a bit (18psi)
This was a pretty steep climb (4lo w/diff locked)
The old lady pretending to like going on the trails
Trying to figure out what the hell I am doing
Getting off the hill cause I couldn't go up any further. The trail was too narrow.
Airing back up (An onboard compressor would be nice....)
Old 09-16-2012, 01:05 AM   #15
OZ-T's Avatar
Did you not do an OME driver's side trim packer ? Just looking at your post lift numbers
Old 09-16-2012, 11:14 AM   #16
Army:
I did put it in. And it still sits all skiwhompes. It is quite noticable. I will remeasure today to see how it has settled since install.
Old 09-16-2012, 01:05 PM   #17
OZ-T's Avatar
No chance it's on the wrong side ?
Old 09-16-2012, 07:22 PM   #19
Army:
Originally Posted by EATABULLETcom View Post
lookin good cant wait till we get matching bumpers. im thinking of bedlinning it then color matching.
I need to see pics of that! That'll be a pretty penny.
Old 09-16-2012, 07:29 PM   #20
Army:
How dare you! I am offended....but, I have been known to do dumb shit like that, so.......
Here are pics of the driver side.
NorthWest MOAB 2012 Team MapleMoose North West 1715 05-21-2012 12:27 AM
2011 Trail Team FJ Build SilverTacoZack Other Builds 4 05-02-2012 07:19 PM
My 2012 build so far adrstout 2nd Gen. Builds 9 03-27-2012 12:34 PM
2012 Fj crusier trail team edition! linkfeeney FJ Cruisers 29 01-22-2012 11:09 PM
