A build
Discussion in '2nd Gen. Builds (2005-2015)' started by Round II, Aug 25, 2012.
  1. Aug 14, 2013 at 9:52 AM
    #281
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Sorry chad I lost this post!
    I have some serious vibration in the front end. Feel it in the floor boards and the steering wheel. I recently changed inner and outer tres, uca bushings. I have new uniballs ready to install but they seem to be tight still. I have new wheel bearing hub assemblies ready to install but need to check the old ones. Last time I jacked the truck up and looked for play in the wheel it was only side to side so I changed tres and it seemed good up and down. Idk how bad my alignment is but it seems to drive semi straight. I also have dyna beads in my wheels for balancing and they have always worked great so I'd be surprised if the wheels are unbalanced but I suppose its possible. Wondering if front diff needle bearing could be cause of these issues since you guys were talking about it. How do you know when it's bad? What issues were you having with yours Scott?
  2. Aug 14, 2013 at 9:53 AM
    #282
    JLink
    Josh
    Ocean, NJ
    Btw thanks in advance :thumbsup:
  3. Aug 14, 2013 at 12:03 PM
    #283
    Round II
    Round II [OP] Member #12005
    The needle bearing will absolutely cause slop but shouldn't be a big issue for Vibs? When does it start to vib (MPH) as I was having this issue as well and it turned out that the ADD was locked and causing it:eek:. Now I know it can happen with mine because I have to hit a switch to lock the ADD, just wondering if maybe your actuator might be stuck?
  4. Aug 17, 2013 at 8:48 PM
    #284
    Round II
    So as posted before I had some Hella Black Magic 500's that have been sitting around for some time, and I recently decided to toss them on. Well, to say the least I was unimpressed with the output though I like the subdued look when their off.
    I ordered up some
    HID H3c xenons and retrofit them into the housings. Now I have pretty impressive set of lights for a low price point.
    This was before with the halogens:
    ...and now with the HID's
  5. Aug 18, 2013 at 4:34 AM
    #285
    Namyo
    Namyo -
  6. Aug 18, 2013 at 6:44 AM
    #286
    Round II
    A lil over a month to go! :cool:
  7. Aug 28, 2013 at 7:34 AM
    #287
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    LT yet?
  8. Aug 29, 2013 at 12:01 PM
    #288
    Round II
  9. Aug 29, 2013 at 12:39 PM
    #289
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    Pass dat chit!
    :popcorn:
  10. Sep 7, 2013 at 3:54 PM
    #290
    Round II
    Buff buff buff buff buff buff buff buff............:homer:
  11. Sep 7, 2013 at 7:41 PM
    #291
    JLink
    Josh
    Ocean, NJ
    ... and you wanted to re paint it... pshhhhh
  12. Sep 7, 2013 at 7:49 PM
    #292
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    Looks good.
    One day I will get around to buff out my pinstripes.
  13. Sep 7, 2013 at 8:33 PM
    #293
    Round II
    :p Oh and figure out some dates for VT... I'm running down to the Outer Banks in early Oct soooooo?
    Oh the stripes are still there its just now they have a high sheen on top of them.:D
  14. Sep 7, 2013 at 8:39 PM
    #294
    JLink
    Josh
    Ocean, NJ
    2 weeks from yesterday. I'm going to camp friday night at the site in vermont and then head over to mt washington area saturday. I have monday and tuesday off as well so i'll take my time exploring saturday, drive up to the top of mt washington sunday, do some sight seeing monday and then drive home tuesday.
    so actually.. if you just want to make a normal weekend out of it you could just camp at the site in vermont and maybe bgr will go too
  15. Sep 7, 2013 at 8:41 PM
    #295
    Round II
    Hmmm going down to the shore this coming w/e, and thats the w/e after that.....:goingcrazy:
  16. Sep 8, 2013 at 6:27 AM
    #296
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    looks window licking good :D
    just missing an Eagles sticker :spy:
  17. Sep 8, 2013 at 4:23 PM
    #297
    Round II
    piift wont be saying that after tomorrow night...;)
  18. Sep 8, 2013 at 7:04 PM
    #298
    JLink
    Josh
    Ocean, NJ
    so today my truck was making a bunch of noises, so I pulled over to take a look. the driver side cv boot was sucked in all the way and cv grease had sprayed all over. I grabbed the cv and it has a little play in and out, which seems normal, but it has a lot of play left and right and up and down. makes me think its the needle bearing...
    I'm going to call Chase at ECGS tomorrow to talk to him about the bushing and see if thats what he thinks it is.
    Sound right?
  19. Sep 8, 2013 at 7:17 PM
    #299
    Round II
    Mine had a ton of play as well but it never spat its blood. It doesn't sound like the needle bearing is the cause of the boot letting go? If you need a replacement boot I have a spare OEM kit with grease and all. Let me know if you want it?
  20. Sep 9, 2013 at 4:05 AM
    #300
    JLink
    Josh
    Ocean, NJ
    yea I'm not sure what caused the boot to slide.. the tie rod boot slid a little as well so something may have happened the last time I wheeled.
    You have the removal tool for the needle bearing right? Probably cheaper to pay for shipping than to buy one from ECGS right? I'm not sure if the boot is torn at all, but I figured it would be a good time to replace it while I have the cv off anyway. what do you want for the boot?
