Longer wheel stud question...Need help
Old 12-04-2012, 05:32 PM   #1
dad32509 [OP] dad32509 is offline
Thinking of something clever
dad32509 is one of the sharper tools in the sheddad32509 is one of the sharper tools in the sheddad32509 is one of the sharper tools in the sheddad32509 is one of the sharper tools in the sheddad32509 is one of the sharper tools in the sheddad32509 is one of the sharper tools in the sheddad32509 is one of the sharper tools in the sheddad32509 is one of the sharper tools in the sheddad32509 is one of the sharper tools in the sheddad32509 is one of the sharper tools in the sheddad32509 is one of the sharper tools in the shed
dad32509's Avatar
dad32509's Tacoma Gallery
Ive searched and searched but cant get the exact answer I need. So I'm running Wheelers 16x8's and when I first put them on, I took my 1" spacer off and realized the wheels were rubbing on the caliper so I put the 1" spacers back on the front. I looked around and decided to get the 1/4" spacers from wheelers to avoid rubbing without shaving the caliper, and got the et lugs. Go to find the et lugs dont fit in the lug holes. So I figure extended studs are the best bet. After looking around and talking to arp, the IS300 studs are probably my best bet, but they are an inch longer than stock. I dont wanna bottom out the lug before tightening the wheel down so should I just get open ended lugs? Or does anyone have any idea if I can get a stander lug all the way on(would like to get gorilla lugs)? Also is there any better options out there as far as studs? Thanks for the help
Old 12-04-2012, 10:23 PM   #4
Matt123 is one of the sharper tools in the shedMatt123 is one of the sharper tools in the shedMatt123 is one of the sharper tools in the shedMatt123 is one of the sharper tools in the shedMatt123 is one of the sharper tools in the shedMatt123 is one of the sharper tools in the shedMatt123 is one of the sharper tools in the shedMatt123 is one of the sharper tools in the shedMatt123 is one of the sharper tools in the shedMatt123 is one of the sharper tools in the shedMatt123 is one of the sharper tools in the shed
Matt123's Avatar
Matt123's Tacoma Gallery
I think you will be better off with your bolt on spacers. I constantly had problems with my ARP studs. They worked fine at first, but once I had taken my wheel off a few times they began to slip and lose there bite. I find that the ARP knurl (at the bottom) of the stud is a bit smaller then the ones we have on our stock wheel studs.
Old 12-04-2012, 10:34 PM   #5
dad32509's Avatar
The spacers wouldnt be a problem, but they are lug centric and the steering wheel shims around 65mph. And with the BS of the wheels, they stick out about 2" past the fender.
Old 03-08-2013, 11:00 AM   #6
DaveSmith has a spectacular aura aboutDaveSmith has a spectacular aura aboutDaveSmith has a spectacular aura about
Army: Navy / Army
DaveSmith's Tacoma Gallery
To the OP (dad32509) what is the length of the lug in the above picture that isn't deep enough? Specifically what is the depth of the lug? I'm facing a similar situation. I want to replace my studs with something stronger and longer (better then the OEM crap). I'm wondeirng if gorilla makes a longer/deaper lug? Have you checked with them?
Did you think about using the shorter ARP studs for the Celica (100-7718) at 2.340" long vice the longer Lexus IS 300 studs (100-7715) at 2.60" long? Would the .26" difference be enough?
Is anyone running the ARP lexus studs? If so what lugs are you using and on what wheels?
Old 03-10-2013, 12:46 AM   #7
Relentless
jjhitchen is one of the sharper tools in the shedjjhitchen is one of the sharper tools in the shedjjhitchen is one of the sharper tools in the shedjjhitchen is one of the sharper tools in the shedjjhitchen is one of the sharper tools in the shedjjhitchen is one of the sharper tools in the shedjjhitchen is one of the sharper tools in the shedjjhitchen is one of the sharper tools in the shedjjhitchen is one of the sharper tools in the shedjjhitchen is one of the sharper tools in the shedjjhitchen is one of the sharper tools in the shed
jjhitchen's Avatar
jjhitchen's Tacoma Gallery
bump
Wheel stud specs MetalMiller 2nd Gen. Tacomas 3 02-29-2012 10:34 AM
WHEEL STUD REPLACEMENT socal4x 2nd Gen. Tacomas 5 10-25-2010 10:30 AM
Longer Stud Question~! PhilipRoth Wheels & Tires 7 07-14-2010 11:40 AM
Broken Wheel Stud Armkb 2nd Gen. Tacomas 8 08-17-2009 07:13 PM
Wheel stud size MyTaco Wheels & Tires 2 11-07-2008 10:15 AM
