TT4Ever S/C Build Thread
Old 02-20-2013, 07:40 PM   #21
Get Boosted
ToyotaTacoma4Ever is a jewel in the roughToyotaTacoma4Ever is a jewel in the roughToyotaTacoma4Ever is a jewel in the roughToyotaTacoma4Ever is a jewel in the rough
ToyotaTacoma4Ever's Avatar
ToyotaTacoma4Ever's Tacoma Gallery
I dont think this counts as an update but more of like a concern that came up that I noticed. So I wanted to share this with all of you!
Now this picture has two fuel gauges which are going on the fuel regulator but one gave me quite an uncertain feeling.
Now the gauge on the left was the first gauge i bought for 20$ and the one on the right was the second for 50$.
Now the issue is on the gauge on the left, can you find exactly where 10 PSI, 30 PSI or 50 PSI stands? Now try imagining that with 43.5 PSI with how awkward the spacing is (LOOK CAREFULLY).
The gauge on the right makes things WAAYY simpler to find those exact PSI marks. So i guess dont go tooo cheap on gauges ! lol
Old 02-27-2013, 05:29 PM   #22
Get Boosted
Well today put in some of the LED's i ordered from Whitebeauty (Mark)
They are probably the most easiest ones out there but its the high power reverse lights and third brake light.
So first was the third brake light, pretty straight forwad with removing the two hex screws and taking off the red lenses.
So here you have the regular halogen bulb (left) then the LED bulb (right)
So the bulbs pop out and so on so forth
Put the red lenses back in and there you go got a third LED brake light
Now for the reverse lights you'll have to remove your tail lights by taking out theses 2 - 10mm bolts. (This is pretty straight forward as well)
So once you go the bolts out you'll have to pop the lights out from the bottom and they should come out pretty easy
Then twist and pull out the reverse bulb. Pull out the halogen bulb and put in the high power bulb in. Twist the bulb back in.
Once you've got that done pop back in the tail lights and screw back in the 10mm bolts and do the same to the other side!
Heres the difference between the regular halogen (left) to the high power bulbs (right)
Here they are installed
I know this is all simple stuff for most but you never know who can use the info on this lol
As well im working on the exhaust video, got the first half done already and does it ever sound terribly raspy! haha The other half will be done once i get that resonator in!
Old 02-28-2013, 08:55 AM   #23
Get Boosted
Just notices you can see where I put my go-pro for the exhaust video in the pictures haha
Old 03-01-2013, 09:57 PM   #24
Get Boosted
Alright the day fianlly came to do some cosmetic work on the truck! I had the grill and the headlights installed and they look awesome!! As well a few more LED's with a minor mistake.
Before
After
These are the LED's (Map & Dome)
Here's a few more night time shots
Here's the minor mistake that happened with the LED's
All the LED's were suppose to stay blue, not red and blue haha
The headlights output feel 10 times better then my old ones! They are incredible! So i'l show the low beam and high beam after a few minor adjustments.
Low Beams
High Beams
Old 03-02-2013, 10:29 AM   #25
Instagram: stormtrooptaco
HighTQCummins has much to be proud ofHighTQCummins has much to be proud ofHighTQCummins has much to be proud ofHighTQCummins has much to be proud ofHighTQCummins has much to be proud ofHighTQCummins has much to be proud ofHighTQCummins has much to be proud ofHighTQCummins has much to be proud ofHighTQCummins has much to be proud ofHighTQCummins has much to be proud of
HighTQCummins's Avatar
HighTQCummins's Tacoma Gallery
id love to get some of those interior lights, they look pretty bright
Old 03-02-2013, 01:11 PM   #26
Get Boosted
They are very bright indeed!! its a nice touch to have
As well for everyone i have updated the cover page for this build! check it out!!
Old 03-06-2013, 01:34 PM   #27
Get Boosted
I notice myself buying goodies for my truck through the vendors here a lot more then going to a shop. Thats a good thing since they can keep up their services up here on the websites. To all the vendors out here, gotta say your making Tacomas/X-Runners look awesome
Here's Coupes TRD Battery Hold Down piece.! Another nice add-on to the engine bay
Here's the before
And the after
Old 03-06-2013, 01:59 PM   #28
Fightman80 is one of the sharper tools in the shedFightman80 is one of the sharper tools in the shedFightman80 is one of the sharper tools in the shedFightman80 is one of the sharper tools in the shedFightman80 is one of the sharper tools in the shedFightman80 is one of the sharper tools in the shedFightman80 is one of the sharper tools in the shedFightman80 is one of the sharper tools in the shedFightman80 is one of the sharper tools in the shedFightman80 is one of the sharper tools in the shedFightman80 is one of the sharper tools in the shed
Fightman80's Avatar
Fightman80's Tacoma Gallery
Smile
Nice truck man! I like what you've done to it so far! Check out my SWB sometime... let me know what you think!
Old 03-06-2013, 03:06 PM   #29
Get Boosted
Thanks for the compliment!
Sure il check out your SWB as well! Almost like one view for another view haha
Old 03-18-2013, 07:39 AM   #30
Get Boosted
Bring on the BOOOOST!!
Today i was able to install URD's 2.8 pulley. I'm sooo exited to keep testing out the pulley on my truck. Gotta thank my dad for lending me part of his shop (for i dont have to do this outside) and for giving me a hand on the install.
Lets get started with what i did to install the pulley
First thing was fiding out all the tooling and scope out what i needed to find. I found out its MUCH EASIER pulling off the skid plates to access the tensionner pulley.
To take off the skid plate there are 4-12mm bolts that hold it up, once unscrewed the skid plate will simply fall out. I did this in my driveway ealier today and it was COLD!!
Later that day i drove to my dads shop after he got off work. First thing was first is to remove the belt. The instructions said something about a 1/2" ratchet when it was meant to say 1/2" DRIVE ratchet for it can fit into the small square for the tensioning pulley. I did need to use a snipe to pull the rachet towards me so it can pull the pulley upwards.
Now with the belt out of the way it was time to remove the OEM pulley. I went out to my local supply store to buy a 5 TON puller. *ive been warned to buy a 5 TON and NOT the 2 or 3 TON, since the 5 TON will have an easier time pulling the OEM pulley.*
Here's the pulley in action (sorry about a blurry picture but you get the idea) I needed to use a snipe since the pulley was on pretty tight once it broke loose it was easy sailing from there
Then the OEM pulley removed
With the OEM pulley removed it was time to prep the s/c shaft. I used scotchbright to make sure it was clean from debris and have a nice smooth finish. *With that done added a few drops of conventionnal motor oil to lubricate when the pulley gets pressed on.*
My father and i had a mis-communication on how to heat up URD's pulley. I told him the water has to stay at a steady boil when he thought a kettle would work just fine. With what i mentionned we came up with this rig to keep the water at a boil.
This is probably the most rugged way to do this but this was all we had at the shop! LOL!!!
I dont have any pictures of URD's press on tool since it was a race against time to make sure the pulley didnt have enough time to cool off for it would get stuck onto the s/c shaft. This part here was the one i was most concerned about since i couldn't efford to make a mistake and restart all over again.
When the pulley did get aligned with the s/c shaft i had my dad hold the pulley with a strap wrench. This was to prevent the pulley from spinning while i was pressing it on. Once it started it did get tight but we did get it on.
*Make sure to have the pulley flush with the outside edge of the s/c shaft for proper routing of the belt*
Once the pulley was flush you can remove the press on tool and put the belt back on.
*Before*
*After*
This is my most up to date picture of "underneath the hood" (Yes i know its dirty)
Old 03-18-2013, 03:43 PM   #31
Get Boosted
Well after driving the truck some more today you do notice a gain on the supercharger with URD's 2.8 pulley. Pretty stoked that stage 2 of the supercharger/engine is now complete.
Old 03-20-2013, 11:35 AM   #32
Get Boosted
I'm not to sure what's my next bigger upgrade will be for my truck, after that 2.8 pulley most upgrades ive got now will be cosmetic changes. I've had three ideas but some will have to look further into it with more details.
1) A wanna be x-runner -> drop it with the tundra racing lowering kit from URD and find some ground fx pieces. Some of them would have to be custom made since I have a double cab. How cool would that be!? A wanna be Xrunner that's a double cab haha
2) I want more horsepower but I think I'm stuck where I'm at, I'd like to get a 2.7 or even a 2.55 pulley. With no tuner and the need for bigger injectors it just won't happen
3) Lighter aftermarket wheels? Dunno if it would make a difference for getting faster times from a 20" wheel down to like a 18"? but I'd like a rim that I can use all year round. Having two pairs is getting annoying to change every spring/fall
Old 03-24-2013, 05:55 PM   #33
Get Boosted
Out of the thousands of people that use TacomaWorld surprised that its hard to get opinions on builds unless you do something crazy with the truck lol
What's up with that!?
Old 03-24-2013, 08:54 PM   #35
Get Boosted
Originally Posted by Torspd View Post
#2 with a ProEFI, and #3.
Of course you would come chime in xD haha Doesn't that have to be hard wired in?
Originally Posted by SingleCabGuy View Post
Only came here cause i thought your thread title stood for Twin Turbo 4 ever Supercharged build.
Then i realized there arent any turbos
Still a sick build tho
SUBD
lol I was hopin the supercharged part would catch eyes but clearly not to many since its the same road others have took as well. Since its nothin new I suppose it's just another build lol
Thanks though
Old 03-25-2013, 05:26 AM   #37
toon714 is one of the sharper tools in the shedtoon714 is one of the sharper tools in the shedtoon714 is one of the sharper tools in the shedtoon714 is one of the sharper tools in the shedtoon714 is one of the sharper tools in the shedtoon714 is one of the sharper tools in the shedtoon714 is one of the sharper tools in the shedtoon714 is one of the sharper tools in the shedtoon714 is one of the sharper tools in the shedtoon714 is one of the sharper tools in the shedtoon714 is one of the sharper tools in the shed
toon714's Avatar
toon714's Tacoma Gallery
Just cut into the harness!!!
Dont be scared. If u want more power.
I cut into my harness and im happy.
I got more power!!
Just take ur truck to the right shop to hard wire it in and youll be good.
Old 03-25-2013, 05:43 AM   #38
Get Boosted
Yeah, it does. But that is what the wink eye is for. A Haltech Platinum 1000 or AEM standalone would probably easier to deal with in your area though. Those are more common than the ProEFI.
But again, I know that you really don't want to cut into your harness either. So it puts you at an impasse, as far as future power gains are concerned..... o_O
Yeah it's driving me crazy that I can't get my engine to the horsepower I want to get to! I'm getting close I can feel it lol need a dyno soon too! I think a road trip is in order pretty soon
I got more power!!
Finding that right shop to that properly would be tricky, since it would one hell of a costly mess if they messed it up somehow. The shops that are up here probably never did anything like that since some shops are surprised to see a supercharger on the truck haha that tells you they didn't do a whole lot.
Old 03-25-2013, 08:15 AM   #40
Get Boosted
I have no idea where you are, in relation to Darthyota, but he deals with a shop called Unobtainium. There is another shop as well. I will have to look it up.
Alright so Darthyota is in Sherwood Park which about a 5 hr drive south for me. I'm I located in Fort Mcmurray way up north. Il have to look up that shop and see where it's located. If its located in Edmonton that won't be that bad even though its still a 5 hr drive one way.
My Build thread TC yota Other Builds 212 02-13-2014 10:47 PM
Whose build thread is this? BrentPaucke 2nd Gen. Tacomas 8 08-19-2012 12:15 AM
My Build Thread CAN8EN 2nd Gen. Builds 11 07-29-2011 05:20 AM
My Build Thread rberumen2 2nd Gen. Tacomas 4 02-12-2011 02:19 PM
build thread help 98fourbangertaco New Members 0 06-23-2010 06:31 PM
