RedLantern's "Brokanic" build
Discussion in '2nd Gen. Builds (2005-2015)' started by RedLantern, Feb 9, 2013.
  1. Aug 30, 2013 at 8:48 AM
    #101
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    subb'd as well
  2. Aug 30, 2013 at 8:51 AM
    #102
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
  3. Sep 1, 2013 at 2:17 AM
    #103
    RedLantern
    RedLantern [OP] Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Nothing ordered yet. I'm tryin to decide on some gauges though.
  4. Sep 14, 2013 at 12:24 PM
    #104
    RedLantern
    Honolulu, Hi
    Works been cutting into my time so haven't been able to do anything. I did however have time to buy some gauges.
  5. Sep 16, 2013 at 6:49 PM
    #105
    RedLantern
    Honolulu, Hi
    Ooooooh yeahhhh. Cometic head gaskets and arp head studs.
    These came in today which I totally forgot about. Got a good deal on these that was hard to pass up. This project is still on the back burner until I get the turbo installed and tune. Then the funds can go to the motor build.
  6. Sep 17, 2013 at 5:58 AM
    #106
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    So going to install the turbo kit, and get that running properly. Then focus on the engine build, to get it swapped in?
  7. Sep 17, 2013 at 5:26 PM
    #107
    RedLantern
    Honolulu, Hi
    Yes. Well That's the plan anyway. I just don't know how long the motor build will take. I just got word regarding my workplace may shutdown within the next year for renovations which kinda sucks. I'm gonna have to start job hunting soon depending on what they say at the associates meeting. Then again it's up in the air but we'll see. I started seeing the general contractor around doing some inspections and doing some soil samples. It's just a matter of time.
  8. Dec 22, 2013 at 1:28 PM
    #108
    RedLantern
    Honolulu, Hi
    Hmm...
    FEAB5E04-B25C-4096-B88D-3B672137AA8D_zps_9121875ed6baa1767c45ac5637744853c6f40a7a.jpg
    Thanks paul @dezod
  9. Dec 23, 2013 at 8:57 AM
    #109
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Inching closer.
    What the deal with the transmission line? Get those squared away yet? Been so long that I don't remember.
  10. Dec 23, 2013 at 9:57 AM
    #110
    RedLantern
    Honolulu, Hi
    Indeed, Been busy this month but lines will be moved this Saturday. Going to be using aluminum flex lines and flaring the ends to the trans. Was going to use compression fittings but realized it was steel. Will get photos when done.
  11. Dec 23, 2013 at 6:08 PM
    #111
    RedLantern
    Honolulu, Hi
    Another important piece. Thanks Gadget!
    DB203430-FCC2-4E88-8234-EB565B179F0A_zps_3e38e94c2c1f88baf61358aaaaf09cc8d9da7622.jpg
    2BAFC532-9CF9-4057-8B0E-8EE0EF7B8DE3_zps_14314f9ce96b265c41ad6ef2b5a4fc9e3c9e4f53.jpg
    From this point I think I have almost everything I need. Time frame for starting install
    Will be in January and hopefully tuned and boosted by early
    February....Stay tuned!!
  12. Jan 8, 2014 at 11:42 PM
    #112
    RedLantern
    Honolulu, Hi
    As for updates, I redid the bolting up the headers and they clear the lines! I forgot to take pics but I'll make up for it. Truck will be going through the installation process this Saturday and throughout the week....
    But for now I ended up dipping my stocks...
    FD6B7114-2B03-4D40-A80F-6F3D6E6F67F6_zps_d71beb9bea64ee1f9b191c58f6c0f0b298963fca.jpg
    Then I said screw and got these! Enkei ST6 20" x 9.5
    B9D2B796-E873-490E-A8A6-284D1476E4BD_zps_ded57bb398dcf44a137793efd481ae5aebe0a2e9.jpg
    Sorry but i only got to take these blurry pics with them on. I'll get more at day light.
    AE087759-1B0E-40A2-AA95-1303CEB4A0A5_zps_9f015fbe88e4488e4372971e00634c7b36df7211.jpg
    C23D8A54-5E17-45F7-916C-97972C022B68_zps_88cfc09d71d19648ca042dffdc4976d88f9ca531.jpg
  13. Jan 12, 2014 at 2:03 AM
    #113
    RedLantern
    Honolulu, Hi
  14. Jan 12, 2014 at 2:28 AM
    #114
    RedLantern
    Honolulu, Hi
  15. Jan 12, 2014 at 12:28 PM
    #115
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Houston, we have lift off!
    Looks like it is running good now. How much have you gotten done today?
  16. Jan 12, 2014 at 12:38 PM
    #116
    RedLantern
    Honolulu, Hi
    I got the hot side on and turbo clocked. Flipped the inter cooler and figured out how to route the plumbing for the cold side. Still gotta fab it up tho. Will be working on it after work throughout the week. Things still needed to be done on my end is dropping the tank to install fuel pump, install gauges, and plug up a few vacuum lines and a bunch of little stuff. Then off the the exhaust shop and then I can schedule for tuning.
  17. Jan 12, 2014 at 12:42 PM
    #117
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Not to far now. That's good progress! Our are coming together about the same time.
  18. Jan 12, 2014 at 12:44 PM
    #118
    RedLantern
    Honolulu, Hi
    Yea man. Excitement is getting to me. But at least you have a garage. I'm working in a driveway. It poured yesterday but it was a good thing I had a popup tent for some shelter lol
  19. Jan 12, 2014 at 3:30 PM
    #119
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    :rain: :popcorn:
  20. Jan 13, 2014 at 8:12 PM
    #120
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    The wheels look dope but I almost jizzed my pants when you reved it brah
    Chee hee please bring this out one night I gotta see it in person I
    Guaranz you going sleep ppl!
