NorCalTRD's '06 DCLB TRD Sport Build
Old 03-28-2013, 06:31 PM   #1
NorCalTRD [OP] NorCalTRD is offline
NorCalTRD is a splendid one to beholdNorCalTRD is a splendid one to beholdNorCalTRD is a splendid one to beholdNorCalTRD is a splendid one to beholdNorCalTRD is a splendid one to beholdNorCalTRD is a splendid one to beholdNorCalTRD is a splendid one to behold
NorCalTRD's Tacoma Gallery
Alrighty, time to get started on my new to me TRD!
Its my first Toyota and im looking forward to enjoying many miles from her
I always do a significant set of maintenance when I acquire a vehicle, this one wont be an exception.
DAY 1
3/21/2013
240,000 Actual (thanks to carfax check)
99,000 on the Odometer
New/Low Mileage Engine and Transmission
The previous owner was quite the shady character and had swapped the odometer to try and get a higher value for his truck. It does have a new engine and transmission in it and I plan on doing a lift kit which will replace the main suspension components. I figure with a new engine, transmission, and suspension this truck will be like new aside from the body/frame!
3/24/2013
Changed the oil and filter, Mobile 1 5w-30 and OEM Filter w/Washer
Changed the Rear Diff fluid with Castrol 80w-90 + Friction Modifier (TRD Sport has LSD diff)
3/25/2013
Fixed the digital compass and temp gauge by re soldering a 510 transistor, referenced in the TW write up!
Picked up some various plastic fastners that were missing, a new foot rest, along with a new gauge cluster clear face. The previous owner cracked it while putting in the different odometer, what a dumbass.
3/26/2013
Total detail of the exterior including polish and carnuaba wax.
Replaced a leaking Output Shaft Seal and created a DIY for Tacoma World, can be found in 2nd Gen section.
Ordered Aeroturbine AT2525XL (resonated model) from ebay.
3/27/2013
Complete detail of the interior including removal of seats and steam clean of carpets.
Washed the seats thouroughly with a hose and spray attachment, damn those seats were NASTY.
Replaced some more various broken small plastic parts with OEM replacements.
3/28/2013
Picked up a quart of WS ATF fluid to top up the tranny after fixing that leaky seal. Im glad I did, it was at least half a quart low from the slow leak.
Used the Tacoma's debug OBD mode and overflow bolt to properly level the ATF fluid.
Lubed the cabin fan motor and installed a carbonized cabin filter
4/2/2013
Had my Aero Turbine 2525XL installed with a turn down before the rear axle.
Also stopped by the tint shop and had 40% front windows and 5% glare strip done.
4/13/2013
5/3/2013
New tires going on!
Goodyear Wrangler Duratracs in 265/70/17, Load Rating C
10/2/2013
Although it was the last on my list of future to do's the Audio System ended up taking priority because the previous owner had removed the front speakers and I was tired of having shitty music in my taco.
Hardware:
Head Unit Pioneer X5500-BHS DDIN
Subwoofer Image Dynamics 10" IDQ10V4D4 (500w rms @ 4 ohm)
Subwoofer Amp Rockford Fosgate R500 (500W rms x 1)
Speakers Hybrid Audio Technologies Imagine I61-2 (100W rms @ ohms)
Speaker Amp Pioneer PRS-800 (125W rms x 2 @ 4ohm)
Backup Camera TaoTronics Camera
Wiring Kit Rockford Fosgate RFK4D 4 Guage Dual Amplifier kit
Also an AWCS Module to retain OEM steering controls, a scosche dash kit, and a bypass for the head unit so I can watch videos in motion.
Today I managed to get all the doors deadened inside and out using RaamAudio's Raammat and foam sheets.
The back doors i closed up but the fronts are still waiting for the HAT speakers to arrive to be finished.
I ran the 4G power to under the driver seat and then ran 16g speaker wire from there to the front speaker locations, I just a piece of 12 gauge romex and electrical tape to pull the wires through tight spots and the door boots.
It was getting dark as I yanked out the OEM head unit, tomorrow i should be able to get the X5500 installed.
I think both amps will fit under the drivers seat and also I plan on building the sub box on friday or saturday.
Should be finished up by next week.
Built the sub box
FUTURE TO DO'S (In order):
In Channel Window Vents
3" lift with OME Nitro Charger Sports, OME 885 Coils, and OME Dakar Leaf Pack
Grillraft
N-fab step bar
Old 03-28-2013, 07:48 PM   #2
Reserved
Old 04-01-2013, 12:18 PM   #3
I'd rather be skiing...
teneighty is one of the sharper tools in the shedteneighty is one of the sharper tools in the shedteneighty is one of the sharper tools in the shedteneighty is one of the sharper tools in the shedteneighty is one of the sharper tools in the shedteneighty is one of the sharper tools in the shedteneighty is one of the sharper tools in the shedteneighty is one of the sharper tools in the shedteneighty is one of the sharper tools in the shedteneighty is one of the sharper tools in the shedteneighty is one of the sharper tools in the shed
teneighty's Avatar
Law Enforcement:
teneighty's Tacoma Gallery
Old 04-13-2013, 03:56 PM   #4
Uploaded a pic
Old 04-13-2013, 07:32 PM   #5
teneighty's Avatar
Law Enforcement:
Nice! Looking forward to seeing it lifted!
Old 05-04-2013, 12:30 PM   #6
New tires!
The duratracs are so SWEET
Their not loud at all, ride is about the same, and coming from well worn stockers I noticed about an inch of lift just from the tread on these suckers.
Old 10-02-2013, 10:45 PM   #8
Installing an audio system!
new updates in original post and pics will come soon
Old 10-08-2013, 01:40 AM   #9
Got the sub box built
pics uploaded
Old 10-08-2013, 11:37 PM   #10
Carpeted the box and finished the audio install!
Now I just need to break them in and tune them
Old 10-17-2013, 10:53 PM   #11
Loving my audio system, it ROCKS!
Got white interior LED set from Jumper's LEDS here on tacomaworld, they are very bright and really add that newer vehicle look.
Also got a rear window security bar from the guy that sells em here on TW, and waiting on my new Weathertech Mats that I bought from the group buy.
Udy's '06 TRD Sport Build udy2554 2nd Gen. Builds 194 01-12-2015 05:18 PM
Sunnyz Autosports 06' Tacoma TRD Sport Build Sunnyz Autosports 2nd Gen. Builds 0 07-30-2012 08:39 PM
808TacoMan's 06 DCSB TRD Sport Build 808TacoMan 2nd Gen. Builds 9 07-01-2012 08:07 AM
2005 DCLB TRD SPORT BUILD Irish020 2nd Gen. Tacomas 1 01-08-2012 09:44 AM
Nick_701 06 DC TRD Sport Build Nick701 2nd Gen. Builds 8 07-21-2011 04:38 PM
