Vancity4x 1ton SAS
Discussion in '2nd Gen. Builds (2005-2015)' started by VanCity4x, Jul 6, 2013.
  1. Jul 6, 2013 at 9:33 PM
    VanCity4x
    VanCity4x [OP] Well-Known Member
    AB
    05 Tacoma
    3link on tons
    2005 Prerunner, converted to IFS 4wd and now running 1 Ton axles on 40's. Rock Crawling, camping/expedition and snow wheeling in BC. @VanCity4x on IG for current :canada:
    Here's how she currently sits,
    F472BAA3-6650-4C99-BAD7-0ABBDD8A6E51_zps_5a3660c5eb573cc44bf7dd687d811ad31dfec285.jpg
    3CF2082B-7408-4E1A-BD09-E1D2696945AC_zps_b879b60cf423ef103e06b47066fd3cf18abcafe2.jpg
    8A14DF78-D19E-462E-B5F2-CD660A7A42B1_zps_582a25da1c66f6563e1efa03fa02a549a4e69e5e.jpg
    CB8B541A-325F-4445-8DA6-161422FCE27A_zps_55cf12c48ae9bd0e14527e925e5ed15d2cb9f935.jpg
    5e4a02f633a625c0cfe36501aefddef5_zpszebu_395bc6e7d353d365cf0026d3cc0992ed46b8b668.jpg
    64aa504ab0ca167599c5c2c64de2f3cf_zps2tdt_8bdde0f8cd52a09ef5f68d4323c4f2ba4e755f16.jpg
    95F49CA8-E5FD-4418-83FE-57BEB0900242_zps_80dd01c3be31fe999f8d1ffa403f4e311fd643c1.jpg
    a4630389e83076f137612c5bb52a6962_zps0be7_5dce7ccce3c500bab814b319348072e1e564fa8d.jpg
    d4968f7c76926a079e5dd8c151628373_zpse271_a58b3db439793baa61ed9924479ba1c3bb38d52f.jpg
    241b546357ce10707b4e876a4f0f99ad_zps5375_682e9d8f3e6d75734c1d5cb8b957adb2d9e5fb5c.jpg
    4b4fdb01453195683339eb4524f1faed_zps3dc6_2f2fe54af0adbb912488fb79b51a9f887b6cd942.jpg
    d17e55018dcb7228b0b90a6d7972729a_zps45b7_8166989e61676ea0ed38f16842b82230acce28c6.jpg
    2047a87170d90da6534498705870f566_zps83e5_fc5bf24d789522087d1ad8bfcd0c061b2845e278.jpg
    d69941584994dff31f59d24e7898d164_zpsb599_740d7189fdad856136e017d09d9bc2b85bea4c71.jpg
    afc2850657112c5d1824c8d9a8893c08_zps64ac_0be0e0e92534afb291fc6755036b99a9f65c773e.jpg
    456327986c542cf62fe5c36b974d0ccd_zps5ae6_8f1d05abf1f630f6e391cdaf54d2ac7f58d6ce88.jpg
    dffe8af5055b901b06ece669081474fb_zps698c_0e066fff3f1471b6945ae005c81889d94340d49e.jpg
    b9a284a67c16ab5cfef4785d33a896d5_zps6585_fd8095375d2b4d2ab1d87d01e584c360f62d79e7.jpg
    e96c7ea4822e13619a40ce964be85ad8_zps4d43_c2b011b40b7477d25f3098c163cfeab4b8989875.jpg
    Drivetrain:
    04 Ford SD D60 Front
    -Ballistic cover
    -Histeer Arms keyed 6 stud ARP
    -35sp units/stubs
    -Warn hubs
    -JK callipers
    FF 14 Bolt Rear
    -Ballistic shave
    -Eldorado custom disk setup
    Front/Rear ARB lockers
    5.13 Yukon gears
    6x5.5 hubs, ARP Studs, Mcguard lugs
    FJC xfer Front Range twin sticks
    Spicer built driveshaft
    Intake in cab
    Kicks:
    42” Iroks on diy beadlocks
    40” MTR Rock spiders
    Armor:
    Custom Front/rear tube bumpers
    Sliders
    Suspension:
    3 link front w/ Ballistic joints
    14" 2.0 Radflo coilovers
    F911 Hardware
    Chevy 63's rear
    14" Bilsteins custom mounts
    Ballistic Frenched hanger
    1’’ 4crawler Body Lift
    Offroad Recovery/Camping Gear
    Engo 10k winch
    HiLift 60"
    ARB CKMA12
    Tepui RTT on custom rack
    Trasharoo
    Exterior:
    Trailer products Fiberglass
    HomerTaco Satoshi Grill
    Rubber bed mat
    Kobalt tool box –Line-x coated
    Lighting
    Hella 4000i xenon Hid’s
    Hella Supertone horns
    Interior:
    Wet Okole covers
    Weather techs
    Cluster/Int LED Swap
    Fat Mat Sound Deadnd
    Scanguage
    RAM IPAD mount
    Audio/Coms:
    Kenwood dd head
    Alpine sps-600 series front/rear speakers
    Alpine V60 5channel amp
    JL 10'' sub w/custom box
    Cobra 18 cb radio w/ 4' Firestick
    2 Baofeng 5W VHF Radios
    Gamin Glo w/ BC Backroad maps on Ipad
    Progress
    KOH/AZ Rocks/Moab Spring prep
    Rock/rear lighting and fuse box
    50W VHF
    Fiberglass boxsides/rear bumper build
    Softtopper
    Trac bar
    Tundra 2uz V8 build/swap
    Camazon, Joe23, DrFunker and 4 others like this.
  2. Jul 6, 2013 at 9:33 PM
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    Details of swap as outlined by the mastermind - http://www.rocksolidtoys.com/forum/showthread.php?t=396
    So to make a conversion of a 2nd gen prerunner possible will need to find all the parts,
    A750F 4x4 Transmission
    VF2A FJ Crusier (Automatic) Transfer Case
    Tacoma Front Diff w/ mounting hardware
    CV axels
    4x4 hubs/bearings
    CV nut/seals
    Front drive shaft
    ADD Harness - replaces ecu
    Custom tranny crossmember
    Modified rear drive shaft
    modified y-pipe exhaust
    +large assortment of mounting bolts, seals and misc parts
    The swap for me was around $3500 in parts not including the ARB or gears. If pieced together properly it can be done for cheaper. Most of my ability and knowledge came from a lot of research and the factory service manual which details all the parts on the truck.
    Heres how I did the swap
    New Tranny and TCase
    6EFB88AC-D8B6-4998-AF11-021D0462D52C-824_936674f404db48f14626ca00f0a6963f8da2f82f.jpg
    First off I took out the tranny. The connectors, fluid lines, shifter leaver came off then took out the starter to access the TC to Flexplate bolts. Then unbolted the bellhousing from the engine to pull the tranny out.
    A81ED30F-F9FF-42DF-8510-4CBC97B2218B-824_e5e441ea43b7618a7290227dc985ce65d02f1062.jpg
    Installed the new Transmission then cut the hole and sent my FJ Tcase home
    2754045E-2249-43EA-92C7-EA5AB18A23ED-824_dfa8fffe48d4bf1676fe71bce09fcf2202ef0ec5.jpg
    Have Twinsticks used for selecting the drive, left of for high, neutral and low and right for 2wd and 4wd. This also lets me utilize 2low for certain situations.
    bf65759e1a5eae0514299d1f2d82113f_zpsb9dd_c344dc45868479b1b9b15c19092570731d394ba9.jpg
    2737a4d44ea096f89a2717a0dd16870a_zps919e_3a0f4389c8945f7dc77fee101805c1884d5eb702.jpg
    The prerunner frame is different then the 4x4 so a custom crossmember is needed. The measurements were not the easiest to get. I used 1x3 steel tube, cut the ends off a 4x4 crossmember and welded them to the new. Then cut out the center section and added them mount. [​IMG]
    E6DCD80E-0DF7-4D43-B03E-F3A41F2400A3-824_2df9e2d906d7726881441e5c640b7836529b97c0.jpg
    E68840F1-B698-4286-BF37-36C954C62C64-824_6273213f59d310911ec8aa8f7a21ccd005f0e094.jpg
    7D141751-731C-41D8-BE09-8F220C55605F-824_fc4acef3707b69648daaf95517362743a2156ab0.jpg
    The IFS stuff is pretty simple, front diff bolts to factory holes, no crawl box meant factory front drive shaft would fit. Gusseted the spindles, through in the cv's and hubs with seals. Wired up the ADD Harness, works great. Allows the front diff to function without the use of the ecu. Before switching into 4wd the switch gets turned on activating the front diff, then the tcase can be shifted into 4.
    6fc07230aaa4f944f9d2af3ea07b4677_zps84d0_3b8d88ea80824b0a1bfbcfcef2a1fe3243f22dd8.jpg
    226FBE5F-476A-4106-8EBE-33428F5DEB9A-824_f8c80123592ad5b0f1ffb712709f351d650ea981.jpg
    11C2E892-8F49-45B7-AB10-FDA0ADE65128-824_487d9e0c3e15b3f2cb6a507586a5f834ac60e12b.jpg
    At the same time as the swap I had my front and rear diff regeared to 4.56 and front locker installed. [​IMG]
    DF3083C6-582A-4090-ADCA-C3BAA14F13F4-824_674101591a54a59284750e05098fbb0c19af2963.jpg
    For the rear drive shaft instead of buying a 4x4 shaft I was able to get my prerunner shaft cut down and a yoke and slip joint added. Cut the cost down rather than buying a new shaft and having to change the carrier bearing position, they are different on 4x4 frames.
    b8496a9477fb732a7a97e4da7ee22c32_zps17b5_c67e263bf0fcc4443b221d3978001d04be8f9911.jpg
    The last thing I got done was getting the exhaust relocated as It doesn't fit around the new tcase. You can see it in the bottom of the picture here, it is in the stock location now. I got it done by a shop. I will def be redoing it soon as it already has rock scars on it. [​IMG]
    6ca94a71b8cf03a8d12d72b842af1ba8_zpsd818_36ff97436fa920fa5ad901ce7f0534fa15f5db4c.jpg
  3. Jul 6, 2013 at 9:33 PM
    VanCity4x
    AB
    05 Tacoma
    3link on tons
  4. Jul 7, 2013 at 12:05 AM
    Stew Fidaso
    Stew Fidaso Member
    I am very sorry to ask, how much work and money to convert to 4X4? I also have a pre runner. Thanks!
  5. Jul 7, 2013 at 12:07 AM
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    Awesome job with the truck so far and that's awesome you converted it
  6. Jul 9, 2013 at 4:46 PM
    bunxbun
    bunxbun Well-Known Member
    Bunnath
    Santa Ana, Ca
    Plasti-dip emblems, Anytime Foglight, Wicked Flow muffler, 35w 6000k HID
    id love to know as well...:D
  7. Jul 9, 2013 at 10:14 PM
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    As I added above it would cost at least 3k in parts. Most the parts I was able to get for ridiculous prices from a friend with a wrecking yard. Regear and lockers was at least 2200, then suspension, wheels, tools ect. Not Cheap.
    Better pics and more details to come.
    tacom08 likes this.
  8. Jul 10, 2013 at 2:49 PM
    bunxbun
    Bunnath
    Santa Ana, Ca
    nice, i might do this years down the road :D
  9. Jul 10, 2013 at 2:52 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I need to 4x4 convert. I'm too attached to my truck to trade it in. Plus it's already paid off...
  10. Jul 10, 2013 at 11:14 PM
    Stew Fidaso
    Stew Fidaso Member
    Hello. Thank you very much for your response. I wish I have your skills. Man, your truck is awesome!!
  11. Jul 12, 2013 at 6:45 AM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    how sketchy was it welding up that new cross member? i might be getting an FJ T case for $150...and now that i've found the ADD system to trick the actuator i'd actually be tempted to try to convert. the only thing that scares me is rewelding a new cross member like that
  12. Aug 3, 2013 at 8:40 PM
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    Thanks man, put a lot of work into it.
    It was difficult to measure out the spacing for crossmember and I was still a little bit off. I spend at least 10 hours cutting and welding it. My advice, buy the 4x4 tail housing and inchworm adapter, would make it a lot easier.
    The FJ tcase is also very difficult to install on a automatic, the shifter comes up right underneath the transmission shifter. I'm working on fitting my twin sticks, another very difficult process, have gone through 3 different figments for sticks and still doesn't fit right, will prob take a few days more. :annoyed:
    Thanks bro, it totally is. :cool:
    mattraptor likes this.
  13. Aug 3, 2013 at 8:46 PM
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    Changed coolant, front/rear diff fluid, changed tcase to synth, engine oil, bled brakes and added tranny fluid, was a bit low.
  14. Aug 20, 2013 at 10:53 PM
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    Molybdenite Peak - South of Lillooet BC. 9000 ft elevation, has snow 10 months a year.
    320d9c65615c34f3f48b1f36cf7abd6e_zps1b87_59c1497b166f88ba01193a3cc3dce674f1a15b8b.jpg
    d6767a942387fbe993ad18ea0eaed884_zps8fa0_3a36f85a3cf18200f2d6316584896b760946f90d.jpg
    41e93932dfed698d2f7305aaf31f1d83_zps9e08_c57e490336494ca39457dc035029aa9a19d93736.jpg
    f940c8dae484011b85776d51581727de_zps6914_c2d6a33e9a54737ea0b09a1598ecd9a2c9e59d52.jpg
    2dc2df79486e1cb2079be82c5156ab55_zps6d6b_114c9497ca284041bec8c875740e9fff693b5291.jpg
    4b75b79142a5c1d7bc14c72c99c8a5fa_zps8cc0_633fb7364b1240c43010bc613e8eac4fa6f1de1f.jpg
    46ef69c87772035f2bd82ca3b2bad9bf_zpsfd89_6cb3b2768c97b789ca7210b508bbbf649078bfa0.jpg
    9e9e11327a6706b3dab96cd89679b03e_zps06e2_cb28bfddc05dfb4f2bfa7ec1d4ceb7ec0e7729a5.jpg
    4449fee259eb48f36a1b733ea0183b59_zpscd55_cbff3ff9a88858c6d520e025dc126ad7e5659bd7.jpg
    010093cdcda447f560856bd259530d36_zps073f_021f06546618dadfc43fb69fbe378efcbdcc2ed4.jpg
  15. Aug 20, 2013 at 11:06 PM
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    Whipsaw - Princeton, BC off Crowsnest Hwy
    73af8c29a9326c82c7fe2248341d7eee_zpsb639_48888dd4fbc8c411cba39532f8814b548ccac959.jpg
    3dbd1aa92096dbd0a5ee3f9f6870cf26_zpsde5b_596a714513afc25527f9c23559e3bec5229c6b53.jpg
    Memorial Rock
    a8e97f6ff7490ed65a0f6a7c45370bb7_zps2945_0173cfa9372fc557a8f9c427f419045eccb35b79.jpg
    Falcon Hill
    60370c6ada4be776c393d36dff0006a1_zps79b0_ac971b2335cdf6adf6f93bd5f8fd1a22accceafe.jpg
    03bf33f845be6b311ed3d4cf4a46f270_zpscf13_13a2826b317c22903c7d61bd4352627aab5944f9.jpg
    IFS Ledge
    95516c919fac78e8b109d2359a2ec4fa_zps402c_59ce2041861f77352e6dae3579fa4eb255b139f7.jpg
    36e082b3fdb5d887be523c10cbfd4038_zps7351_23e571cc962078f360c02379d32287597ec81a71.jpg
    370e72064ceef2d00c56c04459f2e444_zps2986_3e1834479c198f75a22a0010598ba3ea682528e1.jpg
    Death Hill
    f5d54266101f1e2f40f32f39be3a1957_zps7f1d_d065edee63441c92c28313b6ffc7e2dbd532b8e3.jpg
    099357161d62daa04d8060b01acd8f52_zps422f_75a99afacabdf89692ad83ee3650f0b500d85274.jpg
    9c7dd34383a69115728e1497bda7a7b9_zpsd423_94d018d687f4191ea613eb632a9f4f90bac0ebab.jpg
    f074be7394dc936f5107b4938a88e4fb_zps9fd0_2d8208e6a5e616df9c3fbdccceb8d3066e190206.jpg
    9b53a6e3960eb00b64abeb8c0f34bbda_zpsbc3f_a69fb41d3bc7f46f8e868e6a618ec575690f4331.jpg
    Sliders Work :D
    86eaf54f734bf9b47e717a9874c89c04_zps7c4f_933017983e9f8c93486ea0c7d3ad030ec40cdc27.jpg
    Coalmont Haunted Hotel
    5cd3c1263880ccbcac5882a0f4d50d84_zpsa080_ca284086897654c4054a7166eec3c8ccee57492b.jpg
  16. Aug 25, 2013 at 4:26 PM
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    Holy guacamole, I needed this build for my inspiration, I too have a prerunner. I want to convert it to 4x4; it's already paid for and it was a gift from my parents so trading it in for another truck isnt an option.
    I have no clue how much it'll cost but it's gonna be a ways down the road till i attempt it. Thanks for the build, DSM setting the standard. :thumbsup:
    p.s. My truck is DSM as well :cheers:
  17. Aug 25, 2013 at 6:04 PM
    VinnyMack
    VinnyMack Well-Known Member
    Casey
    Buda, Tx
    07' PreRunner DC LB
    Brute Force Hybrid w/ custom Longhorn cutout, Satoshi w/ Hella 500's, Wet Okole's, Kenwood DDX419 CD/DVD Player, Fog Lamp Mod, BHLM, Blacked-out badges/grill/roof/valence, 5100's up front @ 1.75, 1.25" Spidertrax, TacomaWorld Sticker, extra D-Rings and custom bed mat, interior LED lighting, and Car Seat Mod.
    Badass, great job man!
  18. Aug 26, 2013 at 10:51 PM
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    Thanks guys, still have to put togeather a more detailed description of the swap along with finishing the still long list of things that need to be done. :rolleyes:For me it was cheaper then selling and buying another so its def possible for you Cham.
    Heres video from Molybdenite trip
    http://youtu.be/s8FC9y_CU8A
    Leppz likes this.
  19. Sep 1, 2013 at 6:56 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
  20. Sep 1, 2013 at 7:08 PM
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    Hell yeah. Nice build man
