x_mods build
Old 11-21-2013, 08:27 PM   #1
xmods [OP] xmods is online now
Super Member
xmods is one of the sharper tools in the shedxmods is one of the sharper tools in the shedxmods is one of the sharper tools in the shedxmods is one of the sharper tools in the shedxmods is one of the sharper tools in the shedxmods is one of the sharper tools in the shedxmods is one of the sharper tools in the shedxmods is one of the sharper tools in the shedxmods is one of the sharper tools in the shedxmods is one of the sharper tools in the shedxmods is one of the sharper tools in the shed
xmods's Avatar
xmods's Tacoma Gallery
x_mods build
Might be a little unorthodox, but I spend as much time over here as I do on ClubFrontier! So I figured might as well make a build over here too
How she sits today:
DISCLAIMER:
I'm not sure how my truck got this way, but I know it cost way too much...
I strongly urge anyone who is about to look at this thread to hide your wallets first. You'll thank me later.
Username: x_mods
Vehicle Name: Andromeda, Rommie for short
Year: 2010
Make: Nissan
Model: Frontier CC
Trim: PRO-4X 2WD
Color: Night Armor
Packages: Power Leather, Rockford Fosgate, iPod Interface
History: Other than the packages, she was as bare as a
PRO-4X can be.. I have done all of the work listed below myself with the exception
of mounting and balancing the tires, because of the Aluminum rims.
January 2012 ToTM
2012 ToTY
\/ Mods \/
Interior:
-Black & Orange Wet Okole Seat Covers
-Wheelskins Charcoal Steering Wheel Cover
-DashMat Charcoal Dash Cover
-Black WeatherTech Floor Liners
-BlendMount for Bully Dog GT
-Autometer Phantom II Vacuum Gauge
-V-LEDs Dome Lights/Map Lights
-PRO-4X 5 Switch Cluster
-5 OTRATTW Illuminated Rocker Switches
-Stinger Voltmeter
Exterior:
-OEM Rain Guards
-OEM Trailer Hitch
-OEM Trailer Wiring (4-pin)
-8 OEM Tie Down Cleats
-Smittybilt Hitch Shackle
-Masterlock Hitch Lock (blue)
-Bak Industries BakFlip G2
-Red LED Turn Signal Arrows in Mirrors
-EZDown Tail Gate Shock
-Bosch Icon Wipers
-De-badged
-Full Ceramic Window Tint to ALL Glass
-Orange Digital Camo Tailgate
-808UpFront Custom Front Burger (Orange)
-808UpFront Custom Rear Burger
Lighting:
FX-R's are out, TL's are in!
-x_mods Custom TRS Acura TL 3" Bi-X CL Projectors
-x_mods & 808UpFront Custom Molded Vacuum Formed Shrouds w/Custom Trim Rings (Orange)
-Morimoto 5Five 55w Blasts
-Philips D2S 85122+ Bulbs
-x_mods Custom TRS Mini H1 Foglights
-Morimoto 3Five 35w Balasts
-3000k H1 HID Bulbs
-x_mods Custom Dual Relay Bi-Xenon Fog Light Wiring Harness
-x_mods Custom Rigid Roof Mount
-Rigid SRCW 40" light bar (Roof)
-Rigid SRCW 20" light bar (Front Bumper)
-Rigid Dually Hyperspot Pair (Mirrors)
-Rigid Dually Hyperspot Pair (Front Bumper) (Orange)
-Rigid Dually Diffused Flood Pair (Rear Bumper)
-Alien LED Aero Pod Flood Pair (Bedcover)
-x_mods Custom Under Rail LED Strips
-LED 3rd Brake Light
-JLC LED Reverse Lights
-x_mods Custom V-LEDs Under Hood Lighting
-x_mods Custom V-LEDs Dual color Amber/White Footwell Lights
-x_mods Custom V-LEDs LED Courtesy Lights in Mirrors
-x_mods Complete Custom Light Wiring
Drivetrain:
-Radiator Cooler Bypass
-Flex-a-Lite Transmission cooler
-Flex-a-Lite Oil cooler
-Filter Mag Transmission Magnet & Rear Differential Magnet
Suspension & Tires:
-Bilstein 5125 & 5100 Series Lift Shocks
-ReadyLift 2.5" Lift
-PRG 2" AAL
-PRG Adjustable Upper Control Arms (Orange)
-PRG Adjustable Sway Bar End Links
-PRG Adjustable Shackles (Orange)
-PRG 2" Rear Lift Blocks (Orange)
-PRG SS Front Brake Lines
-4x4parts SS Rear Brake Lines
-CST Lift Spindles
-Sway Bar Delete
-PRO-4X 16" Wheels (PlastiDipped)
-285/75R16 Goodyear Wrangler Duratracs
-High Polish .44 Magnum Valve Stem Caps
-1" Rear Wheel Spacers (to match the CST lift)
-4x4parts Poly Leaf Spring/Sway Bar Bushings
-808UpFront Custom Wheel Badges (Orange)
-Painted Spline Lug Nuts (Orange)
Armor:
-SHROCKWORKS C200 Skid Plate (Orange)
-Painted Factory Tin Foil Skids (Orange)
-x_mods Custom Tube Front Bumper
-x_mods Custom Tube Rear Bumper
-x_mods Custom Dual Front Recovery Points
Performance:
-Injen Power Flow Cold Air Intake (Orange)
-Intake Manifold Spacer (Orange)
-Painted Valve Covers (Orange)
-Bully Dog Triple Dog GT
-Battery Pending
-Variable Charge System Bypass (Constant +14.1V)
-VAIS Bypass
-K&N Oil Filter
-Dual Filter Mag Oil Filter Magnet
-Royal Purple MAX ATF/5W-30/Gear Oil/Purple Ice
-350z OEM T-stat
-Stillen Light Weight Under Drive Pulley
-Pulse Plugs
-Dynomax Cat Back (Black)
-Dynomax VT Muffler (Black)
-x_mods Custom Exhaust Dump
-Custom Saikou Michi Oil Catch Can (Orange)
-x_mods Custom Oil Catch Can Mount
-Clutch Fan Delete
-Dual 12" E-Fans
Audio:
-Pioneer AVH-P3200DVD Head Unit
-Pioneer ND-BC4 Back-up Camera
-Alpine PDX-5 Amplifier
-4x Polk Audio db5251 Component Speakers
-New Model Alpine R10
-SO Ported Box
-Rockford Fosgate Wiring
-x_mods Custom Speaker Adapter Plates
Gear and Other:
-JetBeam BC10 (808UpFront Engraved)
-Pelican Case w/2x Surefire G2
-Pelican First Aid Case
-Pelican Survival Case
-Fenix HL21
-Hotech True 5mw Astronomy Green Laser w/Red Light
-First Aid Kit
-Signal Mirror
-Leatherman
-Other Random Survival Stuff
-Fire Extinguisher
-Hatchet
-4AWG 17ft. Jumpers
-20' Hook Tow Strap
-20' Loop Tow Strap
-3x Smittybilt U.F.O. L.E.D. Safety Lights
-1 Gallon Folding Gas Can
-1 Can Fix-a-Flat
In Progress:
-Custom Sliders
-Full Rewire
Future:
-It Never Stops
-Titan Swap?
-PRG Motor Mounts
-Extended Coilovers (w/dual rate springs? still working that out)
-808UpFront Custom Steering Wheel Badge
-LT Headers
-B Pipes
-E Fan Shroud
-Rear Locker
-Illuminated Steering Wheel Controls
-Pathfinder Window Controls
-Oil Pressure Gauge
-Oil Temp Gauge
-Trans Temp Gauge
-m226 Swap (if I can find one cheap enough)
-4WD Conversion (It's going to happen! Just trying to find all the parts..)
-6-Speed Conversion (waiting for the warranty to run out, find a
doner truck, and win the lottery)
-More LED's
[/font]
More pics!
Older Pics:
And a few from a long time ago:
Old 11-21-2013, 10:56 PM   #2
FMF FMF is online now
FMF is one of the sharper tools in the shedFMF is one of the sharper tools in the shedFMF is one of the sharper tools in the shedFMF is one of the sharper tools in the shedFMF is one of the sharper tools in the shedFMF is one of the sharper tools in the shedFMF is one of the sharper tools in the shedFMF is one of the sharper tools in the shedFMF is one of the sharper tools in the shedFMF is one of the sharper tools in the shedFMF is one of the sharper tools in the shed
FMF's Avatar
Navy: FMF Hospital Corpsman
FMF's Tacoma Gallery
Awesome truck Nate!!
Old 11-21-2013, 10:59 PM   #3
SoCal Tacomas
Jerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shed
Jerez's Avatar
Jerez's Tacoma Gallery
Huh...you don't see a frontier on here everyday. Especially one modded really well looks good sir
Old 11-21-2013, 11:11 PM   #5
NW4RUNNER is one of the sharper tools in the shedNW4RUNNER is one of the sharper tools in the shedNW4RUNNER is one of the sharper tools in the shedNW4RUNNER is one of the sharper tools in the shedNW4RUNNER is one of the sharper tools in the shedNW4RUNNER is one of the sharper tools in the shedNW4RUNNER is one of the sharper tools in the shedNW4RUNNER is one of the sharper tools in the shedNW4RUNNER is one of the sharper tools in the shedNW4RUNNER is one of the sharper tools in the shedNW4RUNNER is one of the sharper tools in the shed
NW4RUNNER's Avatar
NW4RUNNER's Tacoma Gallery
Looks bad ass man. Nice work.
Old 11-21-2013, 11:58 PM   #6
Super Member
xmods's Avatar
Thanks Chris!!
Originally Posted by Slinky View Post
Not a Tacoma, yet still a badass truck. Thanks for sharing!
Thanks guys
I'll have some pics from this afternoon up in a bit!
Old 11-22-2013, 05:40 AM   #7
Stuff'd
RadTaco914 has much to be proud ofRadTaco914 has much to be proud ofRadTaco914 has much to be proud ofRadTaco914 has much to be proud ofRadTaco914 has much to be proud ofRadTaco914 has much to be proud ofRadTaco914 has much to be proud ofRadTaco914 has much to be proud ofRadTaco914 has much to be proud ofRadTaco914 has much to be proud of
RadTaco914's Avatar
RadTaco914's Tacoma Gallery
Beautiful truck! Been following your build forever ago back on Club Frontier in my Nissan days Nice to see it again!
Old 11-22-2013, 05:42 AM   #8
nofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shed
nofords08's Tacoma Gallery
Not bad at all!
Old 11-22-2013, 06:03 AM   #9
Running For Mayor of TW
richardbui23 is one of the sharper tools in the shedrichardbui23 is one of the sharper tools in the shedrichardbui23 is one of the sharper tools in the shedrichardbui23 is one of the sharper tools in the shedrichardbui23 is one of the sharper tools in the shedrichardbui23 is one of the sharper tools in the shedrichardbui23 is one of the sharper tools in the shedrichardbui23 is one of the sharper tools in the shedrichardbui23 is one of the sharper tools in the shedrichardbui23 is one of the sharper tools in the shedrichardbui23 is one of the sharper tools in the shed
richardbui23's Avatar
richardbui23's Tacoma Gallery
its a fronty burn it to the ground!!!!!! jk that truck is sick and super fucking clean good job man!
Old 11-23-2013, 02:40 AM   #10
Super Member
xmods's Avatar
w00t w00t!
Originally Posted by nofords08 View Post
Not bad at all!
Thanks! I have followed your truck forever
lol, thanks!
You know at least a little part of you wouldn't mind seeing that!
Old 11-23-2013, 06:12 AM   #11
Vivid Illumination
memario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shed
memario1214's Avatar
memario1214's Tacoma Gallery
You know I'm in This truck is the only reason I ever go back to CF after getting rid of my fronty
Old 11-23-2013, 06:23 AM   #12
AKA Crash Bandicoot
ChamYota is one of the sharper tools in the shedChamYota is one of the sharper tools in the shedChamYota is one of the sharper tools in the shedChamYota is one of the sharper tools in the shedChamYota is one of the sharper tools in the shedChamYota is one of the sharper tools in the shedChamYota is one of the sharper tools in the shedChamYota is one of the sharper tools in the shedChamYota is one of the sharper tools in the shedChamYota is one of the sharper tools in the shedChamYota is one of the sharper tools in the shed
ChamYota's Avatar
Army: National Guard: Infantry/ROTC Cadet
ChamYota's Tacoma Gallery
My grandad has a fronty(I may get it when he decides to get something else) and freakin' A man this fronty is CLEAN!
Subbed.
Old 11-23-2013, 07:09 AM   #13
BLOODYMARY is one of the sharper tools in the shedBLOODYMARY is one of the sharper tools in the shedBLOODYMARY is one of the sharper tools in the shedBLOODYMARY is one of the sharper tools in the shedBLOODYMARY is one of the sharper tools in the shedBLOODYMARY is one of the sharper tools in the shedBLOODYMARY is one of the sharper tools in the shedBLOODYMARY is one of the sharper tools in the shedBLOODYMARY is one of the sharper tools in the shedBLOODYMARY is one of the sharper tools in the shedBLOODYMARY is one of the sharper tools in the shed
BLOODYMARY's Avatar
Air Force: Veteran
BLOODYMARY's Tacoma Gallery
Best pathfinder I've ever seen! hawt!
Old 11-23-2013, 07:19 AM   #14
Red
Large's Tacoma Gallery
Frontier
Old 11-23-2013, 02:57 PM   #16
Just a man and his truck
FLtaco24 has a brilliant futureFLtaco24 has a brilliant futureFLtaco24 has a brilliant futureFLtaco24 has a brilliant futureFLtaco24 has a brilliant futureFLtaco24 has a brilliant futureFLtaco24 has a brilliant futureFLtaco24 has a brilliant futureFLtaco24 has a brilliant futureFLtaco24 has a brilliant futureFLtaco24 has a brilliant future
FLtaco24's Avatar
Navy: GSM
FLtaco24's Tacoma Gallery
Damn!
Old 11-23-2013, 03:01 PM   #17
mromeo is on a distinguished road
mromeo's Avatar
Army: Rigger/Paratrooper
mromeo's Tacoma Gallery
Thats a whole lot of LEDs , looks really good!
Old 11-23-2013, 05:13 PM   #18
Super Member
xmods's Avatar
Thanks guys
Been a while! I love the new LED bar, but the old setup was nice too!
Originally Posted by tx novice View Post
bout time Nate
Awesome job.....
Future mods "Titan" , DIESEL OPTION !?!
haha thanks Ron! If anything I would probably do a propane conversion . Or supercharge it. V8 and diesel swaps are too much trouble for a DD.
Old 11-23-2013, 05:20 PM   #19
Senior member
XxTHe FioLOxX is one of the sharper tools in the shedXxTHe FioLOxX is one of the sharper tools in the shedXxTHe FioLOxX is one of the sharper tools in the shedXxTHe FioLOxX is one of the sharper tools in the shedXxTHe FioLOxX is one of the sharper tools in the shedXxTHe FioLOxX is one of the sharper tools in the shedXxTHe FioLOxX is one of the sharper tools in the shedXxTHe FioLOxX is one of the sharper tools in the shedXxTHe FioLOxX is one of the sharper tools in the shedXxTHe FioLOxX is one of the sharper tools in the shedXxTHe FioLOxX is one of the sharper tools in the shed
XxTHe FioLOxX's Avatar
XxTHe FioLOxX's Tacoma Gallery
Beast truck! I dig it
Old 11-24-2013, 06:12 PM   #20
Eatshots is on a distinguished road
Eatshots's Avatar
Eatshots's Tacoma Gallery
Very nice!! I love the red in the head light! Where did you get them?
Also, would love to see the back a little better.
Boogyman build Take 2 and Scout 2 Build Boogyman 2nd Gen. Builds 51 06-15-2014 04:00 PM
Build crazy? Krazie's build! Krazie Sj 2nd Gen. Builds 134 01-22-2014 12:56 PM
The Jay build!!.. 5 Lug base Build Jmiller0004 2nd Gen. Builds 17 11-06-2013 09:30 PM
Wrecked 2000 Tacoma Build. New member, New Truck, New Build baja_beetle 1st Gen. Builds 21 07-17-2013 03:07 PM
Blackout build (Slow Build) RubberTank 2nd Gen. Builds 8 05-09-2013 04:41 PM
