nj636 DCSB DB build thread
Discussion in '2nd Gen. Builds (2005-2015)' started by nj636, Feb 28, 2014.
  1. Feb 28, 2014 at 5:01 AM
    nj636
    nj636 [OP] Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    It's time for one of these build threads. I never made one for my access cab so I'll do one for the double cab. I should title it "another DCSB build."
    2006 Rad Red DCSB Off-Road Automatic purchased 11/12/13 w/ 79k miles
    I'll start the thread and add to it as I get time :cool:
    How it currently sits
    Front Suspension
    OME 885x coils w/ ¼” spacers on Nitrocharger 90000 struts
    Desert Products UCA’s
    Wheelers extended brake lines *
    Wheelers Super Bumps
    Rear Suspension
    Dakar leaf springs w/ 3 degree shims
    All-Pro U-Bolt flip kit
    Bilstein B110 shocks
    Wheels + Tires
    SCS Stealth 6
    285/70/17 Tread Wright Guard Dawgs
    Lighting
    Black head light mod
    Fog light anytime mod
    BAMF behind grille light bar w/ Hella 500’s (2) & KC 130’s (2) *
    Electronics
    Blue sea 12 slot fuse box *
    Uniden PRO520XL CB mounted in center console *
    Relentless Fab hood hinge cb mount w/ 3’ Fire Stik
    Ultragauge
    Interior/Audio
    LED interior lighting
    White LED cluster swap
    Removed buzzer/chime
    Pioneer head unit
    TRD seat covers
    Exterior/Armor
    4x Innovations IFS Skid
    4x Innovations bolt on sliders w/ kick-outs
    BAMF LCA skids
    BAMF rear diff skid
    Homeroshi thin lip
    Recovery/safety
    Hi-lift mounted to bed rail
    Misc. straps & shackles
    Shovel
    Miscellaneous
    ECGS front diff bushing
    Extended diff breather
    *to be completed
  2. Feb 28, 2014 at 5:02 AM
    nj636
    Kev
    Jersey
    first things first
    BHLM FTW
    One of my favorite aesthetic mods
    c975642f-61b1-4915-9e62-048612760419_zps_7af29f6ccab8d16468b744b629f3bea796c960c6.jpg
    time to install the suspension lift :D
    on the lift it goes
    Dakars & Bilstein 5100's going in
    temp tag still on :D
    porta power helped installing the OME 885's on OME shocks
    OME 885's & Dakars
    285/70/17 Tread Wright Guard Dawgs on Stealth Custom Series Stealth 6's
    Crom likes this.
  3. Feb 28, 2014 at 5:02 AM
    nj636
    Kev
    Jersey
    I had maintenance records for the truck but I wanted to start fresh. I replaced the engine oil, both diff's & t-case gear oil, new air & cabin filter. I plan on replacing the spark plugs this spring.
    onto the fluid changes. front diff, t-case & rear diff got Lucas synthetic gear oil
    rear diff was diiirtaay
    t-case fluid looked pretty good
    that y-pipe :eek: future relocation noted
  4. Feb 28, 2014 at 5:02 AM
    nj636
    Kev
    Jersey
    first wheeling with some NJDB's
    NJ/PADB wheeling
    Crom likes this.
  5. Feb 28, 2014 at 5:03 AM
    nj636
    Kev
    Jersey
    picked up a set of 4x innovations bolt on sliders from paP's part out
    w00dy helped me install them :cool:
    we installed his AAL (what center pin :eek: )
    Crom and JWhitTac05 like this.
  6. Feb 28, 2014 at 5:04 AM
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
    BAMF kick out sliders, SkidRow skids,Pro Comp 7069, Kelly Safari TSR 285's, Elite front bumpa, OME 883 & Dakars w/ D6XL AAL, Nitro sport shocks, Eddie209 Soft topper, Satoshi, k&n fipk, Clarion vx400, Ultra Gauge, Debadgination mod
    Reserved
    And
    Subbed
    Let's get some content in this thread...
    Getting better now!
  7. Feb 28, 2014 at 5:29 AM
    nj636
    Kev
    Jersey
    onto the LCA bushing replacement
    this took a good amount of time. I decided while there I wanted to replace the lower ball joints, tie rod ends, hubs & install the ECGS bushing in the front diff
    since they were seized in the bushing, I cut the bolts with a sawzall to get the LCA out
    CV shaft out, time to remove the needle bearing
    thanks to JLink for the removal tool :cool:
    needle bearing out :thumbsup:
    ECGS bushing installed
    onto replacing the LCA bushings, this was time consuming. I was able to press two of the four bushings out, the other two took alot of swearing, beer drinking, hammer swinging, & air chiseling.
    The Boyd method worked for the two that did not want to be pressed out.
    I wanted to try the Whiteline bushings, but the O.D. was about .050 too large. I had a set of Moog bushings so I installed them instead
    glass beaded the LCA's and painted them
    this is the dust seal for the CV shaft (dealer only item)
    LCA in :woot: I used the Toyota bolts/cam's since the Moog's were only half correct
    Passenger side wheel bearing was smoked :eek:
    http://www.youtube.com/watch?v=1WhbdIADGKI
    Driver side wheel bearing was original & looked good when I took it apart. I replaced it anyway :cool:
    job complete! time for new UCA's :(
    Crom likes this.
  8. Feb 28, 2014 at 5:48 AM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
  9. Feb 28, 2014 at 5:44 PM
    nj636
    Kev
    Jersey
    took advantage of 4x innovations black Friday sale & ordered an IFS skid. very happy with their customer service, product quality & time to get it shipped :thumbsup:
    cleaned it with a degreaser
    soaked it in metal prep for 20 minutes
    a few light coats of Por-15 semi gloss (goes on glossy, dries semi gloss)
    Crom likes this.
  10. Feb 28, 2014 at 5:49 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    man, another NJDB build. well at least its Rad Red FTMFW and not SGB
  11. Feb 28, 2014 at 6:23 PM
    nj636
    Kev
    Jersey
    falling into the build thread trend:cool:
  12. Mar 3, 2014 at 8:54 AM
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
    Did the brown Santa deliver any other goodies on Saturday?
    Sum BAMF Love...
  13. Mar 3, 2014 at 9:15 AM
    nj636
    Kev
    Jersey
    Should be waiting for me when I get home :D
  14. Mar 12, 2014 at 6:25 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    01 SR5 TRD 4x4, '23 Bronco Wildtrak, 2017 HSQV FE350
    Drop bracket lift and booger welds
    Is that your shop you're working in? I love how your sliders look from the side, like they are barely even there.
  15. Mar 12, 2014 at 6:44 AM
    porchop
    porchop Well-Known Member
    Brad
    NJ
    '15 TRD PRO S/C
    Wtf how come I didn't know about this thread :mad: sub'd :D
  16. Mar 12, 2014 at 6:52 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    Lookin good in here! :thumbsup:
  17. Mar 12, 2014 at 10:55 AM
    nj636
    Kev
    Jersey
    :wave: thanks
    will be adding more when I get the time :D
  18. Mar 12, 2014 at 11:06 AM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    Notice the "DESTRUCTION" from the 1st pic...
    Looking good Kev....
  19. Mar 12, 2014 at 11:11 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    This thing is DESTROYED :D
    yea but this truck moves.... Sorry Ant.
  20. Mar 12, 2014 at 11:41 AM
    wrmathis
    Bonaire, GA
    parts and stuff
    everyone knows his truck is a POS
