Scuzzy's/NWTI Front Bumper Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Scuzzy1007, Mar 23, 2014.
  1. Mar 23, 2014 at 10:31 AM
    Scuzzy1007
    Scuzzy1007 [OP] Active Member
    Tony
    Brookings, Ore.
    Sand Taco
    Bumpers, Lift, I-Phone Interface, more to come
    Ok guys and gals, I said I would posy my stuff online for this truck, so here it begins. I have a 2005 TRD Off Road 4x4 Access Cab that I put a cheap $150 3" lift on from eBay so I did not have to buy tires twice when I put a Total Chaos on. Today's (and probably tomorrow's) will be the assembly and installation of North West Trail Innovations 05-11 Tacoma precut bumper. It is a "some assembly required" kit that I got for $350 (after $20 discount) with several options that I requested for fog lights and grill guard/hoops. Total with shipping was $550 thru Fastenal right here in Brookings.
    Background information: This truck is being built as a chase truck for my Class 10 buggy. This is #2. I paid a whopping $9500 for it with a blown 6 speed and it turned out to be a $12 shifter cup. #1 is a 67 Ford Bronco that is nearing completion and is currently being driven. I race my buggy with the Valley Off Road Racing Association (VORRA) out of Reno Nv.
    www.nwtrailinnovations.com
    As soon as I figure out how to post pictures to this site I will be adding them from the build.
  2. Mar 23, 2014 at 11:05 AM
    Scuzzy1007
    Tony
    Brookings, Ore.
    Sand Taco
    tools used in this build:
    craftsman tool kit
    Miller 180 220v MIG welder
    angle magnets ( I am old and don't hold stuff straight)
    4" angle grinder
    BFH. Everyone needs one.
    Beer
    coffee
    food
    Someone who knows how to transfer images from my iPhone to this site to enlighten me. I do not have URL to send them to.
  3. Mar 24, 2014 at 7:31 PM
    Scuzzy1007
    Tony
    Brookings, Ore.
    Sand Taco
    First wash the truck...hahaha
  4. Mar 24, 2014 at 7:40 PM
    Scuzzy1007
    Tony
    Brookings, Ore.
    Sand Taco
    The kit comes neatly packed, all parts were checked and rechecked to make sure I had it all. Then I opened the instructions and ignored them by disassembling the truck first and cutting the tow hook off.
  5. Mar 24, 2014 at 7:51 PM
    Scuzzy1007
    Tony
    Brookings, Ore.
    Sand Taco
    Assemble the center section and grind off the excess factory welds from the truck to ensure a flush mount. Tack the center section together and bolt it up to the truck, ensuring you got it to fit correctly. The notch on the top of the plate obviously goes to the right side of the truck for the A/C line from the condenser.
  6. Mar 24, 2014 at 7:59 PM
    docjake
    docjake Well-Known Member
    Fredericksburg VA
    This looks like an interesting route.
  7. Mar 24, 2014 at 8:01 PM
    Scuzzy1007
    Tony
    Brookings, Ore.
    Sand Taco
    Once the center section is assembled, start attaching the sides. This is the important part of this kit...width and fitment are your choice. I am installing 6" Baja fenders next month, so I chose to set the sides up a little wide. Also, every winch bumper I have ever owned flex as much as 1/4 " or more under a full pull. I intentionally set this up 3/4" below the body. Tack everything together, do not weld it up yet.
  8. Mar 24, 2014 at 8:07 PM
    Scuzzy1007
    Tony
    Brookings, Ore.
    Sand Taco
    Once you have all of the panels tacked together, remove the bumper and weld it up. I welded both inner and outer. Really not needed, but I decided to make it seamless rather than edgy, so I used the outer welds as filler.
  9. Mar 24, 2014 at 8:20 PM
    Scuzzy1007
    Tony
    Brookings, Ore.
    Sand Taco
    And here it is before and during grinding. Grinding, Grinding,, Grinding. But it will look good in the end.
    In all, this is a fantastic kit to build. I saved a lot doing this on my own, but I have a ton of time into it. As usual, if I paid to have it done, it is easy $1000.
    Beer consumed -12 Corona.
    Time elapsed - 12 hours for me, 6 for anyone else.
    10 lbs of wire in the welder
    2 grinding disks
    2 sanding disks
    $40 in power
    No injuries. I actually used my hearing protection and safety glasses. Finish is bedliner over black primer, the back side is already painted. I will finish grinding and painting tomorrow. My winch will be here after payday and the Baja fenders will be coming soon to finish the front.
    Hope this helped some of you. If anyone wants to do this, you can call Corey (tell him Tony from Brookings sent you) to get the kit and if you need help, pm me and we will talk.
  10. Mar 24, 2014 at 8:28 PM
    Scuzzy1007
    Tony
    Brookings, Ore.
    Sand Taco
    Oh and another side note. Corey did send me the hoops for the brush guard around the lights. I need an extra bend in each side before I put them on.
  11. Aug 24, 2014 at 6:10 PM
    PhantomRaider
    PhantomRaider New Member
    Tim
    Federal Way
    2011 4x4 RC PM
    did you ever get the hoops on?
  12. Feb 28, 2016 at 1:49 PM
    LordKravets
    LordKravets Member
    Joseph
    PDX, Oregon, USA
    Barcelona Red with Steel, No Ice.
    Completely Stock. (Currently) Work in progress: TOYOTA Mesh Grill Nwti F/R Steel Bumpers Several Small DIY Mods
    Awesome, I live local with NWTI and purchased F and R bumpers, Picking them up in a few days and painting them myself, will post pics!
  13. Mar 8, 2017 at 1:53 PM
    Borealis
    Borealis Active Member
    Willy
    Yukon Territory
    1980 4x4 Pickup, '96 White Taco,'96 Blue Taco,'06 TRD Taco
    bush-road clusterfuck
    Thanks Scuzzy1007, this was just the kind of post I was looking for!
    Hi LordKravets, would be cool of you could post some pics, I'm thinking of going the same route with my 06 later this year.
  14. May 31, 2017 at 6:31 PM
    WSMFP
    WSMFP Well-Known Member
    Dylan
    2006 Tacoma 4x4 v6 6-speed
    Considering embarking on the same bumper build.
    Have you noticed any decreases in your trucks performance? (i.e gas mileage, acceleration etc....)
  15. Oct 19, 2017 at 4:54 PM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    Dude can you send me all the links for this kit?!
  16. Oct 19, 2017 at 5:06 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Steve
    Buffalo NY
    2010 RC 2.7 4x4
    BUCKLE UP! It makes it harder for Aliens to pull you out of your Truck.
    “Manfred” got time fo dat!
    Manfred likes this.
  17. Oct 19, 2017 at 5:11 PM
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    Could probably have this kit ordered, shipped, constructed and painted before my rack came in haha
  18. Mar 8, 2018 at 5:43 PM
    Nibblekibbles
    Nibblekibbles New Member
    Neal
    2000 taco sr5
    20180308_185025.jpg Working on getting mine together now!
  19. Jan 28, 2020 at 1:23 PM
    Crazyframerdude
    Crazyframerdude Well-Known Member
    Josh
    Blodgett, Oregon
    2021 Cement 4x4 Tacoma Trd off-road
    Fox 3” lift with icon uca and RXT rear leafs, 285/70/17 nitto trail grappler mt
    Scuzzy, just received one for my 14, looking at your unboxing photo what are the 2 additional bent tubes? I don’t see them on the final welded bumper
  20. Jan 28, 2020 at 4:33 PM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    I don't think he is on here anymore, can't tag him and hasn't logged on since September of 2018
