Math Teacher's Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Bender581, May 26, 2014.
  1. May 26, 2014 at 11:46 AM
    Bender581
    Bender581 [OP] Well-Known Member
    AL
    Arkansas
    2012 4X4 Tacoma
    Gobi roof rack. Icon coilovers, Icon tubular UCAs, FOX 2.0 rear shocks, Icon 3-leaf progressive AAL.
    I am fixing to install an ICON suspension and figured I would start a build log. I have already added a few small accessories. I start with a picture with a Gobi rack and Bushwacker fender flares installed.
  2. May 26, 2014 at 11:48 AM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    looks like ya got a good start! clean looking truck!!
  3. May 27, 2014 at 6:11 PM
    Bender581
    AL
    Arkansas
    2012 4X4 Tacoma
    I installed the front suspension today. It took about 5 hours. This is the first time I've done any front end work. So if anyone is reading this and can't decide if you can don this by yourself, take it from me you can. It was a hard day's work. I'm exhausted.
    This is what I installed today and will install tomorrow. Ordered it from Down South Motor Sport.
    I read several posts and found the posts here on Tacoma World better than the directions that came with the Icons. The tie rod end does not need to be detached.
    First: remove the shock/coils and the UCA.
    The hardest task was removing the long bolt that holds the UCA to the frame.
    The metal had to be bent a little but not much for the bolt to slide out. There is also a wire on the inside (under the hood) that needs to be moved out of the way. You can see in the above picture that the bolt is position to be slid back in.
    I installed Icons 2.5 extended travel and Icon UCA.
    This is the old and the new UCA.
  4. May 27, 2014 at 7:44 PM
    PeachEater81
    PeachEater81 Well-Known Member
    San Gregorio
    2005 Tacoma DCSB TRD Sport 4x4
    Icon C/O, Icon 2.0 Resi's, LR UCAs, Alcan 8 leaf pack, Aero 2525XL, Michelin LTX MS2, Lifetime LED heads and fogs (bad company and product - don't buy), aFe Pro Dry filter, Weathertech mats, Best Top, Hybrid Audio, Arc Amp, Arc Sub, Ram matting, Core/Hurst Short Throw Shifter, OEM Bed Mat, Antenna X....
    Wow, that looks sweet. Thanks for the info. I'm about to get some icons as well.
