TacoSTIG: PNW MT Build
Discussion in '2nd Gen. Builds (2005-2015)' started by TacoSTIG, Jan 19, 2015.
  1. Jan 19, 2015 at 1:18 PM
    TacoSTIG
    TacoSTIG [OP] Untamed Member
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    //News:
    - massaging firewall with a hammer
    //2005 AC TRD OffRoad V6 : TacoSTIG
    //Goals/Direction Etc:
    After countless failed attempts at rock crawling with the WRX it was time to add a truck to the Stig family. Acquiring a Tacoma was the next logical step, months of searching later, I found what I was looking for, and the mod bug hit hard.
    The build parameters were loose, I value function, and unashamed to admit I'm a sucker for form. This isn't a dedicated rock crawler, dune jumper, cross continental expedition rig, or a mall crawler. It's a mixed bag of tricks geared towards being dependable and across the board capable.
    //Suspension:
    - Front -
    - FOX 2.5 extended travel coilovers with DSC reservoirs (install 8/11/15)
    - King 700lb springs
    - Total Chaos uniball upper control arms (install 8/11/15)
    - Removed Swaybar
    - Wheelers Superbumps
    - Rear -
    - FOX 2.0 12" RR
    - FOX universal resi mounts
    - ATO Shackle Flip kit (install 1/25/16)
    - B.A.M.F Shock Relocation Kit
    - All-Pro Expedition leaf pack
    - All-Pro U-bolt flip kit
    - Wheelers Superbumps (not installed)
    //Drivetrain:
    - 4.56 Nitro gears (ECGS built, big pinion 29 spline w/solid spacer) (install 1/12/16)
    - ARB air locker (Front) (install 1/12/16)
    - TRD Elocker (Rear)
    - Rear Diff breather (install 6/27/16)
    //Wheels & Tires:
    - Wheels: Konig Countersteer Type X, Matte Black, 16x8 4.5BS
    - Tires: Goodyear MTR 315/75/16
    - Spacers: Motorsport-Tech 3/4" (front and rear)
    //Armor:
    - B.A.M.F 80" Sliders w/ kick out (install 8/23/15)
    - B.A.M.F LCA skids (install 5/26/16)
    - Pelfreybilt Steel Plate Bumper with custom full hoops
    - Pelfreybilt Steel High Clearance Rear Bumper with Spare Swingout and flip down table. (install 5/28/16)
    - Pelfreybilt Steel IFS skid (install 6/24/16)
    - Pelfreybilt Aluminum mid skid (not installed)
    - Pelfreybilt Aluminum trans skid (not installed)
    - Pelfreybilt Aluminum gas tank skid (not installed)
    //Brakes:
    - Goodridge extended brake lines front + rear (not installed)
    EBC Stage 5 GD rotors (install 2/29/16)
    - EBC YellowStuff Pads (install 2/29/16)
    //Bed Accessories:
    - Leer 180, needs TLC, black.
    - Toyota Bed mat
    - Relentless Fabrication Quickfist Axe/shovel mount (install 5/30/16)
    - All-Pro Hi-Lift mount (not installed)
    //Interior Mods:
    - Kenwood DNX8120 GPS Navigation System
    - Weathertech floor liners
    - STIG security system
    - Ram Mounts X-Grip (install 5/25/16)
    //Exterior Mods Other
    - Prinsu Design Accessrac (install Part1 5/28/16 , Part2 5/31/16)
    - DIY Satoshi with custom grille (build/install 11/8/15)
    - Weathertech in-channel window sills
    - Trail toys EZView heated mirrors (not wired yet)
    //Lighting:
    - Morimoto xTorch 40" (not installed)
    - Rigid SRQ2 backup lights (not installed)
    - Rigid Dually 2x -amber- (not installed)
    - Rigid SR Series 20" (not installed)
    - BHLM with amber tinted signal lenses
    - BHLM with FX-R HID conversion (retrofit in progress)
    - Depo Black LED taillights
    //Recovery Gear:
    - Warn M8000-S (install 5/26/16)
    - Factor55 1.5" fairlead (not installed)
    - 48” Hi-Lift Jack
    - Wheeler’s Wrap-It Straps x2 (link)
    - Wheeler’s Recovery Strap 30'x3" (link)
    - Wheeler’s Tree Strap 12'x3" (link)
    - ARB 3/4" shackles x4 (12/12/15)
    - ARB HD 20k Snatch Block x2 (link)
    //Utility Gear:
    - ARB Dual Air Compressor (Part1 , Part2)
    - Slee Offroad ARB Compressor mount (link)
    - ARB Air Locker Manifold (link)
    - ARB Hose Kit (link)
    - ARB EZ Deflator (link)
    - ARB Speedy Seal Tire Repair Kit (link)
    - Powertank HD Inflator TIG-8330 (link)
    //Kitchen:
    - Camp Chef Everest Stove (link)
    - 6lb Worthington Aluminum LP Tank (link)
    - Powertank Cylinder Mount (modded for LP tank) (link)
    - REI Table / Kitchen Organizer
    //Storage:
    - 4x 20 gallon Action Packers
    - 1x 5 gallon Action Packer
    - Rotopax 3 gallon (gasoline)
    - Rotopax 1 gallon (gasoline)
    - Rotopax 1 gallon (water)
    //Mod Wishlist:
    - Marlin Crawler Taco Box
    - RST FJ twin stick
    - Maxtrax or similar recovery ramps
    - Factor55 flatlink pro
    - TRD SuperCharger
    RogueTRD, dub_11, Guerrilla and 4 others like this.
  2. Jan 19, 2015 at 1:19 PM
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    The last 4x4 project started around 2002 with a hacked up 1991 YJ. Ran D44/D60 axles plus some 38.5's. So many memories with this beast, decided to get serious in life and sold it, then moved away for college.
    //The Build
    - Day 1 Picked up in Coulee Dam, WA 5/3/14
    - RIP Chrome... Removed grille and nerf bars.
    - Headlights came off next... (still day 1)
    - BHLM with amber tinted DTRL/Blinker lenses
    - Came out okay, iffy on the ambers, will swap to clear for the FX-R retrofit.
    - Goodbye chrome grille, ordered honeycomb, but got this... didn't want to hassle with the return so I'm keeping it for now. (who wants a chrome grille?)
    - Breaktime @Duthie Hill BikePark
    - Morning view of Lost Lake, WA
    - TIP: Relocate before you do this.
    - Garage Sale goods from The Traveler
    - LED tails and Spidertrax spacers came in
    - Picked these up over Christmas, thanks again Kelvin! (The foxs are overkill for my immediate needs but should future proof the setup)
    - New wheels from OldSven and fresh KO2's from DiscountTire. 2/11/15
    - All-Pro flip kit, extended brake lines, and FOX 2.0 fj smoothies. (sold fox 2.0's for 12" RR's) 2/23/15
    - Fullsize spare from FNwheels. Killer customer service, thanks again Dustin! 2/28/15
    - AllPro Expos 3/2/15
    - Pelfrey teaser 4/16/15
    - Leer 100XQ upgrade 4/29/15
    - 700# Kings 5/1/15
    - 12" Fox RR's 5/1/15
    - Pelfreybilt Armor 7/18/15
    ...the domino effect continues.
  3. Jan 20, 2015 at 9:24 AM
    xTRDxLatino
    xTRDxLatino Member
    Mississippi
    2010 Tacoma TRDoffroad
    Nice truck man, I have the exact same one. Cant wait to see how your build will turn out
  4. Jan 20, 2015 at 9:26 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Got some nice parts there sitting around ready for a home!!
    :popcorn:
  5. Jan 20, 2015 at 9:32 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Some nice stuff you have there :anonymous:
  6. Jan 21, 2015 at 11:52 AM
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    Thanks guys! cant wait to start wrenching.
    :cheers:
  7. Jan 21, 2015 at 1:11 PM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Going to be a badass build for sure :spy:
    subd :popcorn:
  8. Feb 28, 2015 at 2:28 PM
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    Nice truck, looking forward to seeing the mods progress. I want your "hit bump go bouncy thingys". :)
  9. Feb 28, 2015 at 2:47 PM
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    haha thanks man! I'm just as curious how they'll perform. Your wheels look great with the trd center caps. What's the diameter on those? I've been looking at alternatives.
  10. Feb 28, 2015 at 2:55 PM
    RogueTRD
    Cade
    So. Oregon
    Thanks! The center caps are 4". You can get them at any Toyota dealer.
  11. Feb 28, 2015 at 3:35 PM
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    Just measured the diameter of mine and they're a bit over 4". Do they taper much? Hmm they might just work out with a few rounds of tape, thanks for the info!
  12. Feb 28, 2015 at 3:47 PM
    RogueTRD
    Cade
    So. Oregon
    They dont taper at all IIRC, they fit perfectly in my MK6's.
  13. Feb 28, 2015 at 7:31 PM
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
  14. Feb 28, 2015 at 7:35 PM
    RogueTRD
    Cade
    So. Oregon
    ^^^ Sweet!
  15. Feb 28, 2015 at 8:47 PM
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    Other options I've been considering,
  16. Feb 28, 2015 at 8:50 PM
    300AACTaco
    300AACTaco Well-Known Member
    Black '15 DCSB TRD Off Road 4x4
    ARB Old Man Emu 90000s and 60091s OME 886s, Trim Packer, Icon Tubular Uniball UCAs, CMC, Invisible Sway Bar, Dakar Rear Leaf Packs, Timbren Rear Bumpstops, All Pro U-bolt flip up kit, Method Race Wheels NV 16X8 4.5BS, Cooper ST Maxx LT285/75/16, DEPO Black Tail Lights, Weathertech Floormats, Cascadia Vehicle Tents Mt. Shasta in Earth Tone Green, Custom Green Tree Fabrication Bed Rack, N-Fab Spare Tire Bed Mount
    Oh how I envy those who live in states that don't require front license plates! Great looking truck, I absolutely love that color!
  17. Feb 28, 2015 at 8:55 PM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    We are supposed to actually in Washington... I think
  18. Feb 28, 2015 at 8:58 PM
    300AACTaco
    Someones a rebel then haha, one of my buddies up here got a light bar in the opening in his bumper on his 1st gen tacoma, he had his license plate blocking it before he installed it so he just threw it up on the front of his dash. I guess it's legal in AK to do that but he's still gotten pulled over a few times about it when the po pos couldnt see it. The cops just tell him that he should move it back down but it's not illegal to keep there I guess. Still though, I hate the holes that you can still see after removing it.
  19. Feb 28, 2015 at 9:04 PM
    TacoSTIG
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    Thanks Caleb! Man, I wish it was legal in WA to run without a front plate. I risk getting a cheap yet annoying fix it ticket, it just looks so much better without it.
  20. Feb 28, 2015 at 9:50 PM
    300AACTaco
    Have you gotten one yet? And yeah it really does, it especially sucks because some states have ugly plate colors! Like Alaska has these nasty orange colored plates that look horrible on most vehicles! :frusty:
