Borderbrat's build thread
Discussion in '2nd Gen. Builds (2005-2015)' started by borderbrat, Sep 24, 2009.
  1. Sep 24, 2009 at 7:52 PM
    borderbrat
    borderbrat [OP] Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    Well I've had my truck for almost two years now and there has been alot of changes to it since I got it here's the evolution.
    I bought my 2008 V6 SR5 4x4 from metro lexus victoria in April 2008.
    The night I brought it home
    Then a few days later I decided to take a road trip to Calgary AB to visit some friends that trip is when I began to truly appreciate the quality of truck Toyota had built me.
    In Alberta
    Back in BC
    One way
    Yes there is a dent in the rear fender that happened 2 days after I got the truck, it has since been fixed
    The mods began soon after I got home from Alberta.
    First thing I ever did was bolt on a toyota devil emblem and add some piaa lights in the stock fog spots
    Followed quickly by 120V outlets in the cab
    The horror!!!!
    Next thing I did was install some puddle and bed lights
    I quickly grew tired of doing unintentional burnouts every time I took off on wet pavement so I got myself some new tires.
    After a lot of research I decided on Firestone Destination A/T in 265/75/16 size
    They have done me well
    Things slowed here I started my OBA system but only got as far as buying and installing the compressor.
    That was it for quite a while i lurked and surfed and researched to make my next move when i decided all that was lacking was money I didn't have enough saved up to comfortably buy everything I wanted but lucky for me I was soon being deployed money would not be a problem after that.
    About two months before I got home I started to buy everything mainly off ebay but there were a few things that were bought locally as it was just easier.
    Bought a scanguage and blendmount and installed them (eBay)
    Ipod adapter (eBay)
    Bike fork mounts got them from Mountain Equipment Co-op for about $20 each took the rail off drilled two holes into a couple pieces of flat stock bolted them in and reinstalled the rail easy peasy and they won't move.
    I take the skewer out when there isn't a bike hooked in otherwise it rattles around and pisses me off to no end
    Got a good deal on a complete on board air system so I bought it and decided to use the compressor that I already had cause it was a much better unit anyway and it was already bolted to the truck. (eBay)
    Bought 50ft of 200psi air hose from home depot on sale instead of using the rigid hose that came with the kit, and i've used an ass ton of air fittings, hose clamps and teflon tape. I'm very pleased with how everything turned out so far.
    yeah the kit came with air horns great for getting those F350 drivers' attention when they think it's their god given right to cut people off. :D
    The next two things are tied between what i like the most
    got a randy ellis light bar and 4 hella black magic driving lights (eBay for the bar and one set of lights local for the other set)
    Old man emu suspension for front and rear. I had the front installed by a local shop cause well driveway alignments aren't very good and I didn't want to kill myself with a cheap spring compressor. (Local from Cap-it Victoria could have gotten a better deal with north shore off road but I was in a hurry)
    They ride sweet haven't got the rear installed yet. Gonna go to a buddies place one weekend and get it done cause he has a lift and I don't know if you can see my driveway, but its kinda sloped and not jack stand friendly.
    Misc electrical
    Switches are configured different now, now the far right is for the compressor, the horns will not work if the compressor switch is not on. The middle is for both the bed and puddle lights I use them together anyways so I decided to combine them. The fog light switch controls all the aftermarket lights up front. When the switch is on the piaas are on as long as the high beams aren't on, and the hellas only come on with the high beams. Neither work when the switch is off.
    All my relays and fuse holders are contained within an enclosure to keep the engine bay neat and tidy
    Dakars installed
    Pick me up a magnaflow cat back and installed it that night in the dark.
    I would like to install lockers front and rear, but for the amount of off roading I do there's not much point. So I would like to get a limited slip put in the rear, not a detroit locker something similar to the stock toyota unit.
    Last but not least I want a plate rear bumper and some sliders, don't know how my air tank position is going to affect mounting the new rear bumper. I will solve that problem when I come to it.
  2. Sep 24, 2009 at 7:54 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    Nice build
  3. Sep 24, 2009 at 7:57 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    lookin' good man!
    where did you get that piaa fog kit from?
    did it come with mounts as well?
  4. Sep 24, 2009 at 8:01 PM
    baildavc
    baildavc TREADING LIGHTLY!
    David
    Jasper, AL
    08 4x4 white DC OR
    3 inch lift, 33's, bull bar, debadged, windows tinted, direct wired power inverter, blacked out front emblem,
    Very Nice!
  5. Sep 24, 2009 at 8:06 PM
    t-com09
    t-com09 Well-Known Member
    Connecticut
    2010 single cab 4x4 sr5
    Bilstien 5100's yellow foglights toolbox pop n' lock
    truck looks good man
  6. Sep 24, 2009 at 8:07 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    piaas are just normal everyday piaas had to put longer bolts in the mount then i used two nuts to fasten it to the stock mounting points
  7. Sep 24, 2009 at 9:05 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    thanks dude
    thanks man i don't know how you do it you must not spend a penny on anything but your truck.
    thank you
    :thumbsup:
  8. Sep 25, 2009 at 3:20 PM
    ttylerr
    Tyler
    09 MGM 4Banger 4x4
    looks good!!
    could i trouble you for a part number on them piaas?
  9. Sep 25, 2009 at 6:01 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    wtf sausage monger :laugh:
  10. Sep 25, 2009 at 6:24 PM
    AK27
    AK27 Well-Known Member
    :woot:
    nice build BB!
  11. Sep 25, 2009 at 6:58 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    Thanks AK
    Lol I think I've played that game
  12. Sep 25, 2009 at 7:05 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Very nice build, BB! :)
  13. Sep 25, 2009 at 9:02 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    thanks colton
  14. Feb 1, 2010 at 10:23 AM
    borderbrat
    Jeremy
    Victoria BC, Canada
    Update time....
    my buddy Jacee came over and helped me install my new leafs
    I know I know i look really young
    old vs new
    Jaycee caught me mid scratch draining my air tank.
    huge difference truck feels more sturdy too
    As of now I'm done all the big projects. I need to redo some wiring I'm in the middle of making a new wiring harness for all my aftermarket gear. I need to replace my bed and puddle lights with something a little more robust. They're coming soon so stay tuned.
    to be continued....
  15. Feb 1, 2010 at 10:40 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Wow man you've done a lot. Looks really good, you need to get some sliders on there now.
  16. Feb 1, 2010 at 10:45 AM
    SACTOWN
    SACTOWN ???????????????????????
    Greg
    '18 ZR2, 04 Rubicon, &19 lx570
    Nice build
  17. Feb 1, 2010 at 10:53 AM
    borderbrat
    Jeremy
    Victoria BC, Canada
    sigh i know and bumpers. need to find someone to build me a set that will actually listen to what i want and not do what they please.
  18. Feb 1, 2010 at 10:58 AM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    Good lookin truck. Nice build, looks good. :thumbsup:
  19. Feb 1, 2010 at 12:58 PM
    AK27
    looks good jeremy! :woot:
  20. Feb 1, 2010 at 9:54 PM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Looking good man!:thumbsup:
