LSC15's 95 Tacoma 4x4
GEOTACOs Build
Old 02-29-2012, 12:36 PM   #61
GeoTaco [OP] GeoTaco is offline
the town is back that way
GeoTaco has much to be proud ofGeoTaco has much to be proud ofGeoTaco has much to be proud ofGeoTaco has much to be proud ofGeoTaco has much to be proud ofGeoTaco has much to be proud ofGeoTaco has much to be proud ofGeoTaco has much to be proud ofGeoTaco has much to be proud of
GeoTaco's Avatar
GeoTaco's Tacoma Gallery
I MIGHT be able to pull off one and the trip. If i go to mexico, i would not be able to. the whole trip cost ($2000) is due now, plus a $1000 for a front bumper. If i go to the bahamas, trip cost is due in July, so i would be able to spread it out a bit...might just do that.
Ive been diving in mexico for the past 2 years, its great, but it might be time for a new trip. I think thats a pretty good plan Bob....Thanks, problem solved
Old 02-29-2012, 12:50 PM   #62
‹^› ‹(ಠ_ಠ)› ‹^›
NYCO is one of the sharper tools in the shedNYCO is one of the sharper tools in the shedNYCO is one of the sharper tools in the shedNYCO is one of the sharper tools in the shedNYCO is one of the sharper tools in the shedNYCO is one of the sharper tools in the shedNYCO is one of the sharper tools in the shedNYCO is one of the sharper tools in the shedNYCO is one of the sharper tools in the shedNYCO is one of the sharper tools in the shedNYCO is one of the sharper tools in the shed
NYCO's Avatar
NYCO's Tacoma Gallery
haha no prob...you should buy my lca skids too while you're at it haha
Old 02-29-2012, 12:52 PM   #63
GeoTaco's Avatar
hahah, ive got 1/2 and 3/16 steel protecting the expensive stuff, i think im gonna stick with the steel armor for the under belly
Old 02-29-2012, 01:09 PM   #64
‹^› ‹(ಠ_ಠ)› ‹^›
NYCO's Avatar
TC's are 3/16 steel
This bolt on lower a-arm skid plate uses 3/16” mild steel to provide maximum protection from the elements and will protect areas most vulnerable to rocks and tree hang ups on the trail. TC’s armor is CNC laser cut, pre bent and welded ready for easy installation. The skids bolt into existing factory lower control arm bolt holes (enlarging some holes may be necessary). Carriage bolts are used to eliminate damage caused by rocks. These arms ship raw so the armor can also be fully welded to the stock lower control arm for added strength & protection.
Old 06-07-2012, 12:52 PM   #65
GeoTaco's Avatar
finally got my BAMF LCA skids on, will get some pictures of the under side of the truck up soon. Also plan on relocating the 7 pin now that it is nice out. Just bought a house, so it might be a while before the bumpers and winch are bought. Hoping i can work some OT soon and fill that bank acount back up.
Old 06-07-2012, 01:04 PM   #66
‹^› ‹(ಠ_ಠ)› ‹^›
NYCO's Avatar
if you want a slightly used chrome rear bumper with the 7pin mod already done to it then sell your rear bumper (might be in better condition than mine), you can have my old rear...seems how you'll be getting rid of the rear soon enough
i'd like to see it out of my house
Old 06-07-2012, 01:06 PM   #67
GeoTaco's Avatar
if i can find a buyer for mine or get my garage built soon i may take you up on that
Old 06-07-2012, 01:16 PM   #68
‹^› ‹(ಠ_ಠ)› ‹^›
NYCO's Avatar
sounds good...hard for me to justify selling a used and dented bumper, but would be a good temporary bumper that i'd gladly give up
Old 02-05-2013, 06:50 AM   #69
GeoTaco's Avatar
finally got my ARB on, and some BHLM headlights. Im just waiting on the winch and trying to decide what i want to do about lights. Im thinking about a light bar, but i need to make some measurements and figure out if thats the way i want to go.
I added a Leer topper to it while i was in Portland, the Bestop leaked like crazy.
Also, I just bought an 8 switch bezel from an FJ, so its time to start looking into heated mirrors, heated seats, rock lights, bed lights, back-up lights, dual battery....the list goes on....
Old 02-05-2013, 07:10 AM   #70
‹^› ‹(ಠ_ಠ)› ‹^›
NYCO's Avatar
lookin good man
you should look into trimming the bumper for better tire clearance before you eat up a set of tires
Old 02-05-2013, 07:20 AM   #71
GeoTaco's Avatar
I noticed that i rubbed when i was pulling up onto a curb the yesterday, Ill have to do that. Where did you do it? did you use a dremmel type tool or plasma cutter?
Old 02-05-2013, 07:25 AM   #72
‹^› ‹(ಠ_ಠ)› ‹^›
NYCO's Avatar
Originally Posted by NYCO View Post
ARB Bumper cut project
The goal:
to cut my damn ARB bumper back so i am not shredding my damn tires on every large compression
The plan:
using a cutting wheel, cut along the white line to create ample space for my tire to travel
with the help of my buddy jace, we marked in from the bottom as far as the bumper structure would allow us (if you have an ARB look behind the bumper on the bottom and you will see additional structuring at a certain point that would be hard to cut through and keep the integrity of the bumper).
Then using a small metal ruler, i place the ruler within the fender flare near the bumper to mimic the curve of the fender to make a smooth transition (important to have a ruler that can bend and use your best judgment to continue the arc down to the bumper). this established the upper cutting point.
then to connect the dots, i took a metal coat hanger and (while still in one piece) used the long straight bottom part of the hanger to make a curve mimicking the curve of the tire. This served as a template for the desired arc.
use a paint pen and there ya go, a line to follow when trimming your bumper....
after pics to follow, cutting expected to go down this afternoon after work
Old 02-05-2013, 07:28 AM   #73
GeoTaco's Avatar
just found that on your page, thanks!
Display Modes
Build crazy? Krazie's build! Krazie Sj 2nd Gen. Builds 134 01-22-2014 12:56 PM
Wrecked 2000 Tacoma Build. New member, New Truck, New Build baja_beetle 1st Gen. Builds 21 07-17-2013 03:07 PM
Blackout build (Slow Build) RubberTank 2nd Gen. Builds 8 05-09-2013 04:41 PM
how to build book? can i build bookshelve speakers with car speakers? elchimpo Audio & Video 15 03-12-2012 01:43 PM
Build Help? ... cdn_bacon 2nd Gen. Tacomas 2 01-26-2010 08:54 AM
