XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Oct 16, 2011 at 8:33 PM
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    This build is dedicated to my Dad and Grandpa.
    RIP JLM
    James "Lex" Moses
    1957-2013
    Jewel "Jay" Lee Moses
    1937-2023
    Truck:
    -2009 Superwhite DCSB TRD O/R 4x4 1GR-FE Auto
    AS OF: 9-3-22
    DrmKrtPpWcy_BVYJIxc_y7JM7WRloxQpvMnrx2BA_5200b795b088c78a063c70afc711e05934b474e5.jpg
    Suspension:
    Front:
    -King 2.5" 700# ext. travel w/ Resi's
    -BTF High-Caster LCA's
    -Camburg Sealed 1.25" Uniball UCA's
    -RC Fab Total Chaos Gusseted Spindles
    -Total Chaos UCA Gussets
    -Total Chaos Cam Tab Gussets
    -Poly Performance Taco Tabs
    -Superbumps bump stops
    -Sway Bar Delete
    -DRT CMR
    -Energy Poly Steering Rack Bushings
    Rear:
    -King 2.5" ext. travel w/ Resi's
    -Toytec BOSS leaf pack w/ custom arch
    -DRT Shackle Hangers
    -Wheelers Red Extended Brake lines
    Wheels/Tires/Brakes:
    -(5) 17x9 -25mm Summit Dakar Matte Gunmetal
    -(5) 35x12.50R17LT Mickey Thompson Baja Boss MT (load range D)
    -Wilwood Forged Superlite 6 Piston Big Brake Kit - PN: 140-14577-R
    -Wilwood Stainless Brake lines
    Drivetrain/Performance:
    -Nitro 4.56 Gears (Front and Rear w/ E-Locker)
    -Safari Airflow Snorkel
    -K&N drop in filter
    -TRD Supercharger
    -Smoothflow 2.5 Pulley on Pulleyboys Hub
    -NST Full Lightweight Pulley + Lightweight S/C Crank Pulley
    -VW Roller S/C Belt Wrap Mod
    -Steeda Billet S/C Tensioner
    -Solid Off-road Solid Motor Mounts
    -Solid Off-road Solid Trans Mount
    -HP Tuners Tuned (justDSM tune)
    -Removed Boost bypass Jet
    -IPT Valve Body Upgrade (Shift Kit)
    -URD 160* Thermostat
    -URD Spec-U Equal Length Headers
    -URD o2 Sims
    -DeatschWerks 255 Fuel Pump
    -Full Cat Delete
    -Custom 2.25" High Clearance Y-Pipe
    -Custom 3" exhaust dumped over axle
    -Resonator
    -Magnaflow Muffler
    -ZZ Performance Coupler
    -Generic Oil Catch Can
    -TRD Rad Cap
    -IEDLS carrier bearing
    -ECGS Needle Bearing
    -Energy Poly Body mounts
    -Energy Poly Radiator mounts
    -ABS killswitch mod
    -Locker anytime mod
    -Diff breather mod
    -Fumoto f103s drain valve
    Exterior:
    -Pelfreybilt Aluminum Single Hoop front bumper w/ frame reinforcements
    -BAMF HC Dual Swingout w/ 2x tables, single Jerry Can, 5lb Propane, and Spare tire mounts
    -Pelfreybilt Aluminum Skids (IFS, Mid, T-Case & Gas Tank)
    -Smittybilt x20 Winch w/ Synthetic line
    -Factor55 Fairlead
    -Fenders cut (Sheetmetal 2.5"/ Flares 2")
    -Prinsu Roof Rack (Custom Cut)
    -CBI Ditch Mounts
    -Custom Homer Raptor grill
    -Redline Hoodstruts
    -Debadged
    -Color matched rear bumper
    -Limo Tint
    -Satin black roof wrap
    -KM Fab Weld on Sliders
    -Scratches, Dings & Dents
    Interior:
    -Weathertech floor liners
    -Black Bartact seat covers
    -Black interior details
    -White interior details
    -Red/White Interior LEDs
    -Sound Deadened back wall
    -AEM AFR and Boost Gauges
    -Custom White Gauge Cluster Face
    -Mod Armor Mag mount
    -Salex center console organizer
    -Maglight mod
    Electronics/Audio/Comms:
    -Bluesea Fuse Block
    -Switch-Pro flush mounted on shifter console w/ custom mount
    -Pioneer AVH W4400NEX headunit​
    -Alpine PDX-V9 5 channel amp
    -Alpine Type R SPR-60C Components (front)
    -Alpine Type R S65 Coaxials (rear)
    -Sundown SD-2 10"
    -Dual 10" custom enclosure
    -Midland MXT275 GMRS
    -Midland T290vp4 GMRS/Two Ways
    -Midland Handheld CB
    -Garmin DriveTrack GPS
    -Rugged Radio 5H5R's
    Lighting:
    -Black Housing headlights w/ 100w Halogen Ultimate Headlight Upgrade & LED Turn Signals
    -Baja Designs 20" OnX6+
    -Baja Designs SAE Squadron Fog Lights
    -Black Housing LED Tail lights
    -White License Plate LEDs
    -Foglight anytime mod
    Gear:
    -Super Pacific X1 Wedge Camper - Build #139
    -Dometic CF80
    -Tortuga XL Off-Road Fridge Slide
    -13 Gallon Ironman 4x4 Watertank w/ 12v water pump + accumulator & faucet
    -5lb Flamemaster propane tank w/ mount
    -Action Packers for Gear
    -Fire Extinguisher w/ Homemade Quick Release Mount
    -Maxsa Escaper Buddy Ramps
    -10lb Poly Performance Co2 tank w/ mount
    -ARB Digital gauge
    -Trasharoo
    -Misc Adventure/Camp Gear in assorted Molle bags
    Upcoming mods:
    -OMF beadlock converted machined Summit Dakars
    -Mishimoto Radiator and HD Transmission cooler w/ E-fan
    -Solid Offroad Trans mount
    -Digital Rearview mirror
    -Leather steering wheel wrap
    -Headlight hoops and flush mount ditch lights to front bumper + fresh PC
    -OGE Dual Battery + solar
    Wishlist:
    -Remote Start
    -SHOCK TUNING
    MAINTENANCE
    LOG:
    OIL: Castrol Syn 5W-30
    71,600/11-21-15 - Oil Change (Castrol Syn 5w-30)
    72,200/12-19-15 - New Battery (Die Hard Advanced Gold AGM 34R)
    76,954/5-7-16 - Oil Change (Castrol Syn 5w-30) & Cabin Filter Change
    79,859/7-30-16 - New Tires (285/70/17 Cooper ST Maxx)
    81,600/9-24-16 - New Alternator & S/C Belt
    82,378/10-15-16 - Oil Change (Castrol Syn High Mileage 5w-30) and Tire Rotation
    82,700/10-5-16 - New Torque Converter/Fluid & IEDLS Carrier Bearing
    84,981/1-2-17 - Re-Arched Toytec BOSS leaf pack
    86,520/2-12-17 - New CV's/Hubs/Seals/EBC Rotors/Green Stuff Pads/Brake Lines
    87,800/4-2-17 - Oil Change (Castrol Syn High Mileage 5w-30)
    90,873/6-10-17 - F/R Diff & T-Case Fluid(Mobil 1)/New Plugs/SC Oil/K&N Filter
    91,175/6-28-17 - Balance/Rotation
    91,183/6-29-17 - Inner & Outer Tierods
    91,189/6-30-17 - Serp Belt/Upper & Lower Idler Pulley's/Alignment
    93,000/7-13-17 - Nitro 4.56's/Fluids/Seal
    93,056/7-15-17 - Oil Catch Can/Oil Change (Castrol Syn High Mileage 5w-30)
    93,364/7-22-17 - Dayco S/C Belt/Tensioner Pulley/3rd Idler Pulley/AC Resistor
    93,507/7-29-17 - 650# King Coils and new spherical bearings
    98,330/11-28-17 - Oil Change (Castrol Syn High Mileage 5w-30)
    100,534/12-27-18 - Pulleyboys 2.6" s/c pulley
    101,786/1-21-18 - New Black Housing Headlights & Yellow Fogs (Ditched all HID)
    101,866/3-5-18 - New ZZ Performance S/C Coupler
    102,325/4-28-18 - New Steering Rack w/ Poly Bushings/New LCA's/Tierods/TC Gussets
    104,127/5-14-18 - Oil Change (Castrol Syn High Mileage 5w-30)
    104,213/5-16-18 - New Tires (285/70/17 Falken Wildpeak MT)
    104,456/6-16-18 - New Battery (Die Hard Advanced Gold AGM 34R) - Warranty
    109,800/9-19-18 - Driveshaft Re-Tube/New U-joints/Balance
    109,825/9-21-18 - Oil Change/ECGS Needle Bearing/Coolant Flush/URD 160 T-Stat
    114,681/4-24-19 - New Steering Rack Bushings/Driver Side UCA Rebuild & New LCA
    117,360/6-15-19 - Oil Change/Cleaned Filter/MAF/Throttle Body/Installed Fumoto
    119,754/12-21-19 - Pelfreybilt Aluminum bumper w/ Smittybilt x20 Winch/Baja Designs SAE Squadrons
    121,485/2-5-20 - King Rebuild (seals, uniballs, spacers, oil, nitrogen, 700# coils)
    121,537/2-17-20 - New Camburg Sealed Uniball UCAs/New LCAs/New Inner & Outer Tierods/New CVs
    122,354/5/1/20 - Full NST lightweight Pulley Kit + lightweight S/C crank pulley/New oil pan gasket/Oil Change/New Wheelers Superbumps/2.5 Pulleyboys SC pulley
    127,234/1/29/21 - Dirt King LCA's/New OEM Inner & Outer Tierods
    128,215/2/6/21 - New HD CV on passenger side
    128,784/3/25/21 - Solid Offroad Motor Mounts/New Upper Oil Pan/New Starter
    128,853/5/28/21 - New RC Fab TC Gusseted Spindles/New Wheel Bearings/New Battery(DieHard Platinum AGM 24F)
    128,976/7/24/21 - Wilwood BBK and Brake Fluid Flush/Fill/17x9 -25 Summit Dakars/35x12.5r17 Mickey Thompson Baja Boss
    129,675/10/30/21 - New NGK Ruthenium Spark Plugs PN 95125/Cleaned MAF, TB, Air Filter
    130,024/11/16/21 - New Power Steering Pump
    130,167/11/22/21 - Super Pacific X1 Wedge Camper
    133,587/12/30/21 - Oil Change/SC Oil Change
    134,244/1/07/22 - BAMF rear dual swing out
    134,357/1/22/22 - Re-Arched Toytec BOSS pack
    138,674/6/10/22 - New Blower Motor/Resistor/Pigtail(PN's 87138-040070 & 82141-04Q80)
    138,867/8/1/22 - Oil Change/New K&N Cabin Filter
    138,912/8/27/22 - Poly Taco Tabs + Alignment(max caster rear, neutral front)
    140,382/12/22/22 - New upper idler S/C Pulleys/New upper and lower Radiator hoses/New oil cooler hoses/New 160 Motorad Tstat.
    141,067/1/28/23 - New Engine and S/C idler bearings/New Engine (K070835HD) and S/C (K050705RPM) belts/New Engine and S/C tensioners/new exhaust gaskets/balance & rotation
    141,873/4/15/23 - Swapped DK LCAs to BTF High Caster LCAs
    142,382/8/26/23 - New ECGS 3rd Member (4.56) + Lucas 85w140 gear oil
    142,400/9/2/23 - Oil Change
    142,996/9/27/23 - ECGS break in complete + Gear fluid change (Lucas 85w140)
    Youtube Channel:
    https://www.youtube.com/user/bamfota88
    The day I brought it home:
    It's journey there after:
    b1dxZOa3zejNe6yOclxZ2NxqxLwTLX9ozbnQ8iiE_db9c792056bf2dcd5a6c0841c3c63e0ae20d21ca.jpg
    UXVLBRNI8BvXCOmCa3WF0WgEN_HaYmQvl-kw6Nbb_71318e36c9a6c3e6db3438faca37d973b17b72a4.jpg
    9cxuRAck1ZQ8u6Dxtawt0l0DY9qxGWC_XHv2RLmC_70764b716595ac902045988264e6682a5e7bd876.jpg
    w77DV7usctGbI_cJCKioBN9dV-vZpwq7Al6r1t0T_a2cd4d7d637a37cd07128dbd2fd2e0ff789abc6b.jpg
    PXKIVQZeli1OSnytB6hVqsly1us-q7qj5pATHKC1_96fd3410433a29c5a5ce6ccf3cc29520090e0e9d.jpg
    A7i0Eo_5L_ygC5qlYSY7F5JIHsuJi2RrFu5lmUwO_8803c4f0be1a03c33283211f24f72ed6bf1f338e.jpg
    SD5NWS-TgXLK4KXDODx2yZqdGNnPAL2l8ZiXBFMj_4651a84c8c747498e8397ae423033e794af513f3.jpg
    UMC, -Rorschach-, skusty and 28 others like this.
  2. Oct 16, 2011 at 8:34 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    adding the Satoshi and Hellas behind the grill. I used some angle aluminum for the light mount and high temp black paint to paint behind the grill along with the mesh for the satoshi.
    When making the Satoshi, instead of using fiberglass, or plastic from the grill itself, i used some 1/4" particle board type stuff i had laying around, and epoxy'd it to the grill. It actually allowed me to sand the board to get the perfect curve for the mesh to sit on.
    I then filled in the dip with bondo and sanded and sanded. I used epoxy and threaded studs to mount the mesh to the surround. Then, had it colored matched super white, including the inner surround. overall, for my first time cutting, using bondo, etc.. it came out pretty good I think.
    PreTaco170, ChadsPride and kgarrett11 like this.
  3. Oct 16, 2011 at 8:34 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    New Lighting and switches. Ordered some Hella 500's with 4.3K 35w HID's. Added some rocker switched from Sierra Expeditions. I just need to wire up the rock lights and change out my headlights and foglights to 4.3K.
  4. Oct 16, 2011 at 9:27 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    sub';d
    WTF did you do to the blue one?
    what happened to red?
  5. Oct 16, 2011 at 9:29 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    What a beast!
  6. Oct 16, 2011 at 9:46 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Blue got in a fight with a yellow sand filled barrel on the freeway... and lost. lol
    Red gor traded in for Blue. lol I do miss that truck tho.. just HAD to have the newer one :rolleyes:
    thanks man! love the new bumper BTW!
    ChadsPride likes this.
  7. Oct 16, 2011 at 9:48 PM
    PLC721
    Patrick
    Chandler, Az
    Oh man you need to see the glossy powder coat in person. Sooo sick
  8. Oct 16, 2011 at 9:50 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    right on man.. sometime soon we will switch out the grills too.
  9. Oct 16, 2011 at 10:07 PM
    pancho
    pancho Go home Nubbs, street lights are off!
    Pancho
    Southern California
    18 Cement OR 4x4 DCSB
    Black out emblems. TRD Pro grille.
    I really like your tail lights. did you make em like that or bought some?
  10. Oct 16, 2011 at 10:20 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Bought them online. Ebay. $130. No issues with them at all either.
  11. Oct 17, 2011 at 6:37 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    cute build:D
    haha but seriously, finally you made one
  12. Oct 17, 2011 at 3:08 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Right on. Lol. Do you just use a computer program or something. I'm horrible with pictures. Lol that ones not even by me.. Hell, most of them are by you or Jason. Lol.
  13. Oct 17, 2011 at 3:15 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yeah I stole that one a while ago. lol. Don't need to upload it now. Haha. Love that picture!
  14. Oct 17, 2011 at 3:24 PM
    RenoTacoma
    RenoTacoma Petrol head
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    where did you get those black tail lights? :bowdown:
  15. Oct 17, 2011 at 7:30 PM
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    Awwww a fellow stormtrooper! Now u just need the sticker from sockmonkey like me. its funny I was look at the second gen build heard page and there were 6 super whites and one right after the next hahaha
  16. Oct 17, 2011 at 10:07 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    hell yeah man.. UNITE!! lol
  17. Oct 22, 2011 at 9:02 AM
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    Sub'd. Good to see you made a build page (finally). Your build page is so neat and organized. Almost motivates me to fix mine up a bit, but I'm gonna go get drunk now, and help Spezzy put his all pro leave springs on.
  18. Oct 22, 2011 at 9:54 AM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    Josh, you should go help. Your a superstar with rear leaf springs now. LoL
  19. Oct 22, 2011 at 10:10 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Road trip anyone? Lol
    Thanks Matt!
  20. Oct 22, 2011 at 10:14 AM
    extremachn1
    Turd Furgison
    Tucson, AZ
    1500 miles, Where the hell is he?
