-   2nd Gen. Builds (http://www.tacomaworld.com/forum/2nd-gen-builds/)
-   -   Team Lombardo 2012 Build (http://www.tacomaworld.com/forum/2nd-gen-builds/227523-team-lombardo-2012-build.html)
TeamLombardo 07-02-2012 09:48 PM
http://www.tacomaworld.com/gallery/d...m/P1030797.JPG
http://www.tacomaworld.com/gallery/d...m/P1040083.JPG
http://www.tacomaworld.com/gallery/d...m/P1040097.JPG
http://www.tacomaworld.com/gallery/d...m/P1040105.JPG
http://www.tacomaworld.com/gallery/d...m/P1040108.JPG
http://www.tacomaworld.com/gallery/d.../P10308152.JPG
http://www.tacomaworld.com/gallery/d...m/P1030333.JPG
Pre-lift:
http://www.tacomaworld.com/gallery/d...dium/10104.JPG
Lifted:
http://www.tacomaworld.com/gallery/d...m/DSC01949.JPG
http://www.tacomaworld.com/gallery/d...m/DSC01946.JPG
*Pre-Lift Drive Shaft Measurements (Flange to Flange):
Top: 68"
Bottom: 67 15/16"
Difference top from bottom: 1/16"
**Post-Lift Drive Shaft Measurements (Flange to Flange): (Taken on 7/15/12 with 4,267 miles)
Top: 68 13/32"
Bottom: 68 1/16"
Difference top from bottom: 11/32"
***Measurement Difference from Pre-Lift to Post-Lift: 9/32"
__________________________________________________ ____
*Pre-Lift Hub Center to Bottom of Fender Measurements:
FD: 20 1/4"
FP: 20 3/8"
RD: 22 1/16"
RP: 21 5/16"
**Post-Lift Hub Center to Bottom of Fender Measurements: (Taken on 7/15/12 with 4,267 miles)
FD: 23 1/2"
FP: 24 1/8"
RD: 25 1/8"
RP: 25 1/16"
***Measurement Differences from Pre-Lift to Post-Lift: (As of 7/15/12 with 4,267 miles)
FD: 3 1/4"
FP: 3 25/32" (pretty much 3 3/4")
RD: 3 1/16"
RP: 3 3/4"
****Hub Center to Bottom of Fender Measurements taken again at 5,421 miles on 9/16/12 (1,154 miles since suspension install)
FD: 23 1/2" (no change)
FP: 24 1/8" (no change)
RD: 25 1/8" (no change)
RP: 25 1/4" (+ 3/16") Not sure what happen here....
*****Hub Center to Bottom of Fender Measurements taken at 7,200 miles on 11/2/12. Additional weight added: Bumper, Sliders, VR8000-s, RI 20" SR LED, RI Duallys (2,933 miles since suspension install)
FD: 23 3/16" (-5/16" from previous measurement)
FP: 23 13/16" (-5/16" from previous measurement)
RD: 25 1/16" (-1/16" from previous measurement)
RP: 25 1/16" (-3/16" from previous measurement)
Based on the measurements above the Front Driver's side is 5/8" lower than the Front Passenger's side, despite having an OME 5mm trim packer installed.
I installed a 10mm top plate spacer w/extended studs to the Front Driver's side, which was supposed to give me an additional 1/2" to 5/8" lift according to Wheeler's Off-Road. Below are the measurements AFTER installing the 10mm spacer to the Driver's Side only.
******Hub Center to Bottom of Fender Measurements taken at 7,713 miles on 11/17/12 (3,446 miles since suspension install)
FD: 23 7/16" (+1/4" from previous measurement)
FP: 23 7/8" (+1/16" from previous measurement)
RD: 25 1/16" (no change)
RP: 24 13/16" (-1/4" from previous measurement)
CV Angle Before Lift (Driver's side)
http://www.tacomaworld.com/gallery/d.../DSC019291.JPG
CV Angle After Lift (Driver's side)
http://www.tacomaworld.com/gallery/d...m/DSC01951.JPG
Armor:
-Pelfreybilt (socalduckslayer) Front Bumper
-Demello Hybrid Bolt-on Sliders
Exterior:
-Derped Emblems (TOYOTA lettering removed from tailgate)
-Derped Grill
-Stubby Antenna
Interior:
-Salex Center Console Organizer www.salexorganizers.com
-WeatherTech Digital Floor Liners
-20% Tint all A-round
Lighting:
-RI 20" LED Light Bar (www.amazon.com)
--Black Light Bar Covers
--Flood Duallys (www.truckcustomizers.com)
-BHLM
-Anytime Fogs
Performance:
-TRD Exhausted
-SS Braided Front/Rear Brake Lines
Recovery:
-Warn VR8000-s (www.4wheelparts.com Coupon Code CC5OFF for 5% off)
-Wheelers Snatch Strap
-Smittybilt 3/4" Black D-Ring Shackles
Suspension:
-OME Suspension
--886x Coils
--90000 Nitrocharger Front
--N182 Rear
--CB Drop Kit
--5mm Trim Packer (D.S. only to level out)
--10mm Top Plate Spacer (D.S. only to level out)
-Dakar Leaf Packs
-Toytec 3 deg Shims w/Longer Center Pins
-LR UCAs
Wheels and Tires:
-Pro Comp 7069-6883
-GY Wrangler MT/R 285/75/16
Misc:
-CV Boot Mod (My write up: http://www.tacomaworld.com/forum/2nd...ml#post5972612)
-TacomaWorld.com Sticker (Thanks tcBob :thumbsup:)
-Modified Grill for Access to Winch Solenoid
-WARN Black Fairlead
-CMC
On Order:
-N/A
Sitting in the Garage Waiting to Install:
-N/A
Later Mods:
-Pelfreybilt HC Rear Bumper
---Skids
----Front/IFS Skid
-----Trans/Mid Skid
------Transfer-Exhaust/Rear Skid
-60" All-Cast Hi-Lift
-ATO Hi-Lift Mounts
-Toytec U-bolt Flip Kit
-Color Matched Grille Surround
-TOYOTA Lettering from MetalMiller/Emblemart.com
-PIAA Xtreme White Plus Anti-Vibration Bulbs Part# 70856 ($70 from amazon)
-Soft topper
-Custom Fenders
Jester243 07-02-2012 09:50 PM
Nice start...
:popcorn:
OZ-T 07-02-2012 09:53 PM
Lift
Lift
Lift
TeamLombardo 07-02-2012 09:58 PM
Originally Posted by OZ-T (Post 5327340)
Lift
Lift
Lift
I can safely say that tomorrow I will be ordering said lift. About 99% sure of this....
OZ-T 07-02-2012 10:00 PM
886's ?
TeamLombardo 07-02-2012 10:03 PM
Originally Posted by OZ-T (Post 5327370)
886's ?
Yes. Penguins cc has convinced me
OZ-T 07-02-2012 10:05 PM
I think it's a good call
Get OME shocks if you are going to run 886's
TeamLombardo 07-02-2012 10:12 PM
Fo shizzle. OME all the way!
TeamLombardo 07-24-2012 10:09 PM
Ah yeah! Demello hybrid sliders on order SON!
evanmb31 08-22-2012 07:36 AM
Nice, very detailed lift specs, thanks for the info this should help me with my lift, the truck looks awesome.
TeamLombardo 09-07-2012 07:13 PM
Warn winch and Rigid fogs arrived......Now, just waiting on the bumper to get here so I can bloody up the knuckles :popcorn:
TeamLombardo 09-08-2012 08:35 PM
First time out
12 Attachment(s)
Attachment 168820
Attachment 168821
Attachment 168823
Attachment 168824
Attachment 168826
Attachment 168827
Attachment 168828
Attachment 168830
Attachment 168831
Attachment 168832
Attachment 168833
Attachment 168834
TeamLombardo 09-08-2012 08:55 PM
Originally Posted by PSU Taco85 (Post 5662526)
Good looking '12. Gonna look sweet with all those future mods you have in store :)
Thanx. I really can't wait to get it all on. I don't know why the hell my sliders haven't got here yet though. Starting to chap my ass :frusty:
TeamLombardo 09-15-2012 11:48 PM
Red Sands, El Paso, TX.
15 Attachment(s)
Airing down a bit (18psi)
Attachment 169882
Attachment 169883
Attachment 169884
This was a pretty steep climb (4lo w/diff locked)
Attachment 169885
Attachment 169886
Attachment 169887
Attachment 169888
Attachment 169889
Attachment 169890
The old lady pretending to like going on the trails
Attachment 169891
Trying to figure out what the hell I am doing
Attachment 169892
Getting off the hill cause I couldn't go up any further. The trail was too narrow.
Attachment 169893
Attachment 169894
Attachment 169895
Airing back up (An onboard compressor would be nice....)
Attachment 169896
OZ-T 09-16-2012 12:05 AM
Did you not do an OME driver's side trim packer ? Just looking at your post lift numbers
TeamLombardo 09-16-2012 10:14 AM
I did put it in. And it still sits all skiwhompes. It is quite noticable. I will remeasure today to see how it has settled since install.
OZ-T 09-16-2012 12:05 PM
No chance it's on the wrong side ?
EATABULLETcom 09-16-2012 12:13 PM
lookin good cant wait till we get matching bumpers. im thinking of bedlinning it then color matching.
TeamLombardo 09-16-2012 06:22 PM
I need to see pics of that! That'll be a pretty penny.
TeamLombardo 09-16-2012 06:29 PM
2 Attachment(s)
How dare you! I am offended....but, I have been known to do dumb shit like that, so....... :anon:
Here are pics of the driver side.
Attachment 170042
Attachment 170043
