Back from the dead build
Discussion in '2nd Gen. Builds (2005-2015)' started by Chindo, Sep 9, 2012.
  1. Sep 9, 2012 at 4:50 PM
    Chindo
    Chindo [OP] Member
    07 ac sr5
    Hey guys I got my Taco a few weeks ago at an insurance auction and wanted to share my build with you guys
    Here she is just like I got her
    Started tearing her apart and build my need to buy list
    Had a small engine fire in it that needed repaired
  2. Sep 9, 2012 at 4:51 PM
    Chindo
    Chindo [OP] Member
    07 ac sr5
    I will be uploading a few pictures later today of the rest of the progress. It took my just under a week to get her road worth
  3. Sep 9, 2012 at 4:53 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    What direction are you going with the build? Nice im sure you got a steal on it!
  4. Sep 9, 2012 at 5:00 PM
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    Looks like a lot Of work coming your way! Good luck!
    Thats one nice hood scoop!
  5. Sep 9, 2012 at 5:19 PM
    Chindo
    Chindo [OP] Member
    07 ac sr5
    Im thinking along a stormtrooper gonna stay with a simple 3" lift. It's my farm truck for work so just enough lift and tire to get over a few ditches
    I got it for under just 8000 and put in about 4000 into it, I had to replace the motor pics coming soon
  6. Sep 9, 2012 at 5:20 PM
    Chindo
    Chindo [OP] Member
    07 ac sr5
    Thanks man the work actually wasn't that bad on it
  7. Sep 9, 2012 at 5:42 PM
    Chindo
    Chindo [OP] Member
    07 ac sr5
    Original motor had to come out because the pervious owner thru a rod out the side of the block
    Once the motor was in I welded in the new core support
    Hood and lights getting aligned
    She is all done with the FJ TRD wheels I got a 3" lift in box to put on but it's a spacer lift.. Are these lifts really that bad for easy driving? I don't hit trails or anything just go thru a few rough places when I go fishing but reading reviews has me a little worried on it
  8. Sep 9, 2012 at 5:46 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    4000 with the lift? that looks a good deal! congrats!
  9. Sep 9, 2012 at 5:57 PM
    YFZ450MOE
    Moe
    The lift isnt bad as long as you dont wheel it that hard, but the ride quality of them is terrible. Its gunna drive like a brick. I had a 3" rough country on my old taco and i hated it.
  10. Sep 9, 2012 at 6:44 PM
    Chindo
    Chindo [OP] Member
    07 ac sr5
    Ya I got the pro comp lift gonna try it out and see how it goes.... If I would have known about this site before I got it I would have gone with the 5100's and aal. I have a friend that owns a body shop so I got all the parts for about 1500 included the lift and FJ wheels, the engine ran me 2500 and the rest is all little stuff that adds up
  11. Sep 9, 2012 at 6:57 PM
    YFZ450MOE
    Moe
    Its a procomp spacer lift?
  12. Sep 9, 2012 at 7:12 PM
    Chindo
    Chindo [OP] Member
    07 ac sr5
    Ya it's the nitro level lift kit... The biggest tire size I would do is 33's and this should clear it with the correct backspacing I believe.
    I did a little research and found out the FJ wheels are 4.5 backspacing can anyone confirm this.... I got the wheels with tires on it so I didn't measure it
  13. Sep 9, 2012 at 7:19 PM
    YFZ450MOE
    Moe
    I have 4.5" BS on my wheels and am able to run a 285/75/16. Almost a 33. There is some rubbing tho. I am going to cut out the buckets in the bottom of the front fender well as well as the rear fender flare and do the cab mount chop. They rub if i am turned and cycle the suspension at all. They are tight.
  14. Sep 9, 2012 at 10:13 PM
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    wow, brought that truck back! nice work!
  15. Sep 9, 2012 at 10:21 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    that lift will ride great! you shouldn't notice any change, as it is a top plate spacer, not an in coil spacer.
  16. Sep 9, 2012 at 10:30 PM
    Chindo
    Chindo [OP] Member
    07 ac sr5
    Thanks it feels great to have brought it back to life
  17. Sep 9, 2012 at 10:33 PM
    Chindo
    Chindo [OP] Member
    07 ac sr5
    Only question I have really is my rear shock still good? I mean it's only a 1" block thinking of going with a 2" block just cause I do pull trailers and haul stuff, don't want the Cali lean lol
  18. Sep 10, 2012 at 5:59 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    that's what i'm running and it works good, no problems.
    my friend had a 2011 with a 2'' block, stock shocks and they worked fine too.
  19. Sep 10, 2012 at 5:59 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    you could put in a progressive add a leaf for a nice ride, and better towing/payload
