Longer wheel stud question...Need help
Discussion in '2nd Gen. Builds (2005-2015)' started by dad32509, Dec 4, 2012.
  1. Dec 4, 2012 at 4:32 PM
    dad32509
    dad32509 [OP] Thinking of something clever
    Dave
    San Diego
    Blacked out 05
    5100's front and back, OME 885x's, LR UCA's, OMD rear springs, Pioneer AVH-P2300DVD, HVAC Green led's MOD, Blacked out bumper, Plastidip emblems, custom front tube bumper, 32" combo led bar, rigid duallys, otrattw switches, my own Satoshi grille, shorty antenna, Spyder LED halo headlights. csjumper2003 map/dome, 3rd brake, DTRL white/amber and parking LED's. Pelfreybilt IFS skid, Cab mount chop, sliders and rear light bar w/blitzpro 5LR dust light. Uniden CB, Magnaflow 18" exhaust, Rear tire carrier, sway bar removed, spidertrax 1.25" spacers, Wheelers 16" Alloys w/265/75r16 Goodyear DuraTracs
    Ive searched and searched but cant get the exact answer I need. So I'm running Wheelers 16x8's and when I first put them on, I took my 1" spacer off and realized the wheels were rubbing on the caliper so I put the 1" spacers back on the front. I looked around and decided to get the 1/4" spacers from wheelers to avoid rubbing without shaving the caliper, and got the et lugs. Go to find the et lugs dont fit in the lug holes. So I figure extended studs are the best bet. After looking around and talking to arp, the IS300 studs are probably my best bet, but they are an inch longer than stock. I dont wanna bottom out the lug before tightening the wheel down so should I just get open ended lugs? Or does anyone have any idea if I can get a stander lug all the way on(would like to get gorilla lugs)? Also is there any better options out there as far as studs? Thanks for the help
  2. Dec 4, 2012 at 4:38 PM
    dad32509
    Dave
    San Diego
    Blacked out 05
    This is as far as the ET stud will go into the lug hole
  3. Dec 4, 2012 at 9:06 PM
    dad32509
    Dave
    San Diego
    Blacked out 05
    Bump....someone has to know
  4. Dec 4, 2012 at 9:23 PM
    Matt123
    Matt123 Well-Known Member
    www.bpfabricating.com
    West Coast
    Toyota Tacoma
    I think you will be better off with your bolt on spacers. I constantly had problems with my ARP studs. They worked fine at first, but once I had taken my wheel off a few times they began to slip and lose there bite. I find that the ARP knurl (at the bottom) of the stud is a bit smaller then the ones we have on our stock wheel studs.
  5. Dec 4, 2012 at 9:34 PM
    dad32509
    Dave
    San Diego
    Blacked out 05
    The spacers wouldnt be a problem, but they are lug centric and the steering wheel shims around 65mph. And with the BS of the wheels, they stick out about 2" past the fender.
  6. Mar 8, 2013 at 10:00 AM
    DaveSmith
    DaveSmith Active Member
    Dave
    Maine
    2010 Tacoma TRD Offroad
    To the OP (dad32509) what is the length of the lug in the above picture that isn't deep enough? Specifically what is the depth of the lug? I'm facing a similar situation. I want to replace my studs with something stronger and longer (better then the OEM crap). I'm wondeirng if gorilla makes a longer/deaper lug? Have you checked with them?
    Did you think about using the shorter ARP studs for the Celica (100-7718) at 2.340" long vice the longer Lexus IS 300 studs (100-7715) at 2.60" long? Would the .26" difference be enough?
    Is anyone running the ARP lexus studs? If so what lugs are you using and on what wheels?
  7. Mar 9, 2013 at 11:46 PM
    jjhitchen
    jjhitchen Relentless
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
