AgMechTacoma's Build
Discussion in '2nd Gen. Builds (2005-2015)' started by AgMechTacoma, Jan 8, 2014.
  1. Jan 8, 2014 at 4:59 PM
    AgMechTacoma
    AgMechTacoma [OP] Well-Known Member
    Joey
    Simpsonville/Clemson, SC
    -Fat Bob's Garage Leveling kit -DIY Satoshi Grill -Hella 500 driving lights -BHLM -Black Stock wheels -Reclining Bench Seat Mod -Black Badges -Removed Secondary Filter & Intake Resonator -Hard Wired GPS -DIY Skid Plate -Rear Differential Breather Mod -Sylvania 894 Reverse Light Mod
    Hey Everyone I have a 2009 5-Lug 2WD Base Model. I have done a few mods to my truck, but I am kind of limited to a small budget because I'm trying to make it through college:D.
    Mods to date:
    -30x9.5xR15 BFG All-Terrains
    -DIY Satoshi Grill
    -BHLM
    -Black Stock wheels
    -Black Badges
    -Hard Wired GPS
    -DIY Skid Plate
    -Sylvania 894 reverse light mod
    616297_254246214677721_1455417496_o_zps3_54f97dba8a3f91f16100d9e0b4fdd1ed4a1f7df1.jpg
    pugnaxx likes this.
  2. Jan 8, 2014 at 5:21 PM
    AgMechTacoma
    Joey
    I did the Reclining Bench seat mod the other day, and it turned out great. I was sick and tired of driving around sitting at a 90 degree angle. After searching around for a while I found a solution. Now I have 4 different reclining positions.:cool:
  3. Jan 8, 2014 at 6:06 PM
    AgMechTacoma
    Joey
    Took a trip up to Horse Pasture road with a roommate last year. It's a cool place to ride around and do some mild wheeling. It has a creek crossing and some good hills I had to get a running start at to make it up. It's in Pickens, SC up around Lake Jocassee. It's really beautiful country up that way. I had a blast.
  4. Jan 14, 2014 at 7:24 PM
    fgcutaco
    fgcutaco Fly rod in one hand, hockey stick in the other
    Nashville
    '09 SWB, Access Cab, 5 Lug
    Stock... For now...
    Good looking build man! :thumbsup:
  5. Jan 14, 2014 at 8:34 PM
    AgMechTacoma
    Joey
    Thanks!
  6. Jan 18, 2014 at 5:41 PM
    4WheelSteel
    4WheelSteel Active Member
    Jaime
    Chico, California
    2005 Tacoma access cab base model 4cyl 5 lug
    Slim's HID 6000K, JVC double din stereo, 2 12" Kicker Comp, 3" rear blocks Future list: FatBob's strut spacer lift and AAL's, Series 51 pro comp 15x8, Dynomax super turbo muffler, ultra gauge, 31x10.5x15 General Grabbers
    Are you getting any struts bottoming out with that kit on it?
  7. Jan 18, 2014 at 7:13 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Good to see a new 5 lugger! Welcome.
    Real nice work on the truck, and nice working the ol' girl too.
  8. Jan 19, 2014 at 5:56 AM
    AgMechTacoma
    Joey
    Yeah unfortunately the struts bottom out when the truck is flexed. If I have one side of the truck jacked up high enough to get the tires off it bottoms out. I guess that just means I cant jump it.
  9. Jan 19, 2014 at 5:58 AM
    AgMechTacoma
    Joey
    Thanks!
  10. Jan 23, 2014 at 7:39 AM
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    subbed. :spy:
  11. Jan 25, 2014 at 1:18 PM
    AgMechTacoma
    Joey
    Took my lights off to do some rewiring and put in an oem switch. My truck looks naked:eek:
  12. Jan 25, 2014 at 1:20 PM
    AgMechTacoma
    Joey
    Here's my skid plate I made out of an old stop sign I had laying around. Turned out pretty good, and it works for what I do.
  13. Jan 26, 2014 at 9:03 AM
    AgMechTacoma
    Joey
    Just order the Sylvania 894 bulbs for my reverse lights. Looking forward to see the results. :dancingbacon:
  14. Jan 26, 2014 at 10:50 AM
    ChamYota
    Cam
    Ah shit now. Get a retrofit.. I honestly think that's one of the top mods over everything. See mine in person and you'll want em :cool:
  15. Jan 26, 2014 at 11:07 AM
    AgMechTacoma
    Joey
    I got the 894's because they are 37.5 W each. I didn't want to overload the circuit, and with these it will already be double what the factory bulbs were pulling. I didn't really feel like putting in relays to handle the extra load. Plus they were cheap :D.
  16. Jan 26, 2014 at 12:21 PM
    ChamYota
    Cam
    That's fine too but i was referring to retrofitting your headlights :cool:
  17. Jan 26, 2014 at 1:04 PM
    AgMechTacoma
    Joey
    Oh, my bad.
  18. Jan 26, 2014 at 1:15 PM
    ChamYota
    Cam
  19. Jan 26, 2014 at 2:10 PM
    MikeTaco
    MikeTaco Let's do this!!
    Miami, FL
    07 Regular Cab
    A Few...
    Hey brother how did you do this mod ? I'm dying to try it I can't stand it either after 4 years
  20. Jan 26, 2014 at 4:28 PM
    AgMechTacoma
    Joey
    It's really easy to do. There are a couple write ups about it if you search around a little. Just take the screw out of the plastic cover on each side of the seat and pop them off. See how the metal tab on mine sits in that little notch. Basically all you have to do is cut the same size notch like you see in the picture above. Mine is about a 1/4 deep. Go slow and make sure the notch is the same on both sides of the seat. I used a dremel with a cutoff wheel. It took me like 5 minutes to do. I got 4 different reclining potions out of mine. It all depends on how deep you cut the notch. I wouldn't go too much further than what I did. You will be surprised how much the seat leans back with just that 1/4 in notch.
