-   2nd Gen Tacoma Marketplace (http://www.tacomaworld.com/forum/2nd-gen-tacoma-marketplace/)
-   -   WTB: Rear axle shaft or whole rear axle (http://www.tacomaworld.com/forum/2nd-gen-tacoma-marketplace/148396-wtb-rear-axle-shaft-whole-rear-axle.html)
LBCtaco 03-28-2011 09:35 AM
WTB: the passanger rear axle shaft (or whole shaft with bearing, drums etc) Or i will buy the whole axle if priced right.
I just got into a reck on the freeway and bent two wheels, one leaf pack on the passanger side. From looking at everything that is all I saw that was wrong. So I bought new rims and tires, and a pair of leaf packs. I installed the leaf packs, wheels and tires and drove the truck to the get an alignment. So the front was way out of specs but they were able to get it back into specs (alignment was near perfect). But here is the problem when i drove out of the shop I notice my rear passanger wheel is wobbling and when i let off the gas it slows down really fast. I took it to a shop and they said "I WOULD" buy a whole rear axle from a salvage yard which is $1200. I figured I could just replace the axle shaft, bearing and seals for less.
If anyone can help me with this problem I would appreciate it.
LBCtaco 03-28-2011 05:08 PM
So i found a rear passanger axle shaft from LSD to drum. Is $300 a good price?
sparkystaco 03-28-2011 07:35 PM
300.00 for 1 shaft sounds high?
I would have a 4 wheel alignment done to make sure the housing is not bent, cause if you did all that damage I'll bet the housing is bent. I just went thru this after I was forced off the road and clipped a pole with my pass. tire, didn't bend the axle but the housing was out 1.87 degrees on the alignment
96Taco 03-28-2011 07:43 PM
I just replaced my axle shaft for wheel wobble. Cost me $170 from the wreckers. The drums on that side were fucked aswell so i replaced the whole assembly together (axle, backing plate, drums)
LBCtaco 03-28-2011 08:09 PM
I am pretty sure the housing isn't bent. If the housing was bent the wheel would not wobble it would create a noise similar to a bad wheel bearing. And as i said in my first post alignment was perfect. Except for the wheel wobble.
LBCtaco 03-28-2011 08:12 PM
Here is the trucks info: 2008 Prerunner TRD sport #2
sparkystaco 03-28-2011 08:21 PM
did you get a 4wh alignment?
I ask cause when I got everything back to where it was supposed to be the truck drove fine, no squeaks, rattles or noises, would not have even known housing was bent if not for the 4wh alignment
LBCtaco 03-28-2011 08:24 PM
Yes they had sensors on all 4 wheels.
