Which Brake Fluid To Use
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sidehack, Aug 1, 2010.
  1. Aug 1, 2010 at 1:58 PM
    Sidehack
    Sidehack [OP] Well-Known Member
    Chuck
    Simi Valley
    07 DC Long Bed Sport
    Black Westin Oval Step Bar, Blacked out tail lights, ScanGuageII
    I have an '07 DC V6 with almost 60K on it, and want to flush my old brake fluid. Which break fluid have you used and found satisfactory?
    Before I get the usual "use the search feature" I did do that, and did not find any recommendations.
  2. Aug 1, 2010 at 3:23 PM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Use the brake fluid type recommended in the manual or on the lid of the master cylinder reservoir...use only that, none other. I'm not sure what it is (DOT3, DOT4) but use nothing else or you'll die.
    Seriously.
    Not joking.
    Well, maybe a little. But still use only the same type.
    TacoEspecial likes this.
  3. Aug 1, 2010 at 3:24 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    X2
  4. Aug 1, 2010 at 5:21 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  5. Aug 1, 2010 at 7:43 PM
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    The lid says DOT3 IIRC. I put in DOT4. I'm still alive.
  6. Aug 1, 2010 at 7:51 PM
    joes06tacoma
    joes06tacoma Well-Known Member
    Joe
    Central Coast, CA
    06 4x4 Off Road Access Cab v6 6spd
    LEER Shell with dome lights operated with 3 way switches, aux backup lights with relay and 3 position switch, modified wiring to compass/temp display and clock to include switch that disables dimming function (poor man's DRL solution), Scan Gauge 2
    If I recall correctly dot 4 is the same as dot3 but has a higher boiling point. Dot 5 is completely different and you will destroy your brake system using it in a system that takes dot3 or 4.
  7. Aug 1, 2010 at 8:05 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I've been using this stuff for the last 20k miles, so far so good. DOT 4 can be used in DOT 3 systems. Like someone else said DOT 5 should not be used unless you really want problems.
  8. Aug 1, 2010 at 8:06 PM
    SManZ
    Fauquier County, VA
    Correct! DOT5 is silicon based and is not compatible with anything but DOT5 specific brake systems. The advantage is DOT5 is not hygroscopic. The most common use I've come across is in older HD motorcycles.
    DOT 5.1 is compatible with DOT3/4 and has a higher boiling point than either. It usually marketed as a race spec/quality fluid.
    eherlihy likes this.
  9. Aug 2, 2010 at 3:46 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    ATE blue?? funny.
    i use it in my track car. hated it. first it dyes everything blue. the reservoir plastic will be blue. second ATE is a great track fluid..from what i understand, it isnt a long term brake fluid. it resist heat better than regular stuff, but what it gives up to do it..is it's resistance to absorbing water..i use MOTUL 600 now in the track car, it is clear. but like the blue stuff (or gold ATE) i change it out every other track day.
    for my tacoma, i'll use some quality stuff from toyota..it is designed to stay for a long time.
  10. Aug 2, 2010 at 11:49 AM
    george3
    New Jersey
    That's interesting. Some old posts said it was great stuff and a good way to tell when you have your old fluid out. I'll try and locate the old post if I have time.
  11. Oct 4, 2020 at 9:13 AM
    Trd420
    Trd420 2nd gen 03
    Tony
    Compton california
    Tacoma trd off road
    Icon stage 4 method wheels
    41BE12EB-54AF-417E-B6DB-937CB015BB00.jpg What do you guys think about this fluid
    EdgemanVA likes this.
  12. Oct 4, 2020 at 9:16 AM
    Plain Jane Taco
    Plain Jane Taco ALL human beings deserve equal treatment
    USA
    I think it's probably expensive when you can get this at Walmart.
    Lester Lugnut and spitdog like this.
  13. Oct 4, 2020 at 9:17 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    I've seen that for years, but refuse to put any Dot3 or Dot 4 brake fluid into my trucks that has "synthetic" on the label.
  14. Oct 4, 2020 at 9:18 AM
    billygoat
    billygoat Well-Known Member
    American Southwest
    08 TRD Offroad 4x4
    6” Fabtech Lift, 35’s, lots o’ goodies
    I use Prestone DOT 3, never had any problems even when towing at 200k miles. It’s synthetic, just like all decent brake fluids are.
    Old brake fluid usually has a darker color to it, you’ll know when it’s all flushed out.
    whatstcp likes this.
  15. Oct 4, 2020 at 9:18 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
  16. Oct 4, 2020 at 9:19 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Do you have ABS?
    If so, then changing brake fluid is more complex to bleed. Probably best to have a certified shop do the bleed.
    Definitely, read the manual. Do not mix.
    BTW, break and brake are not the same.
  17. Oct 4, 2020 at 9:20 AM
    billygoat
    American Southwest
    08 TRD Offroad 4x4
    Aren’t they all synthetic? Even house brands usually say synthetic, and Prestone says synthetic which is one of the biggest and most trusted brands for brake fluid.
    2015WhiteOR and Plain Jane Taco like this.
  18. Oct 4, 2020 at 9:21 AM
    Plain Jane Taco
    USA
    You do realize that all brake fluid is synthetic, right?
    Lester Lugnut and 2015WhiteOR like this.
  19. Oct 4, 2020 at 9:25 AM
    billygoat
    American Southwest
    08 TRD Offroad 4x4
    If he’s just flushing and not draining (doesn’t let it get low enough to get air in the lines) then this is a non-issue. FWIW, the FSM doesn’t specify a complex bleed procedure for all ABS systems, it’s really VSC (but also some ABS systems) that requires a computer to cycle the solenoids to get the air out. The FSM doesn’t specify any special procedures for my 2005 with ABS but no VSC.
    Lester Lugnut likes this.
  20. Oct 4, 2020 at 9:35 AM
    Plain Jane Taco
    USA
    Just to clarify a few things:
    All brake fluid is synthetic.
    The difference between DOT 3 and DOT 4 is 4 has a higher boiling point.
    It's perfectly fine to put DOT 4 in a system calling for DOT 3. Valvoline DOT 3/4 is actually DOT 4. That's why it's marketed that way.
    Generally speaking, it's not recommended that you put DOT 3 in a system calling DOT 4. It won't hurt anything if you do. But you will be lowering the boiling point of the fluid, which could lead to brake fade if the fluid gets hot enough.
    Do not use anything other than DOT 5 in a system calling for it. And never use DOT 5 in a system calling for DOT 3/4. DOT 5 is a different type of fluid and can cause damage to the internals of non 5 rated systems.
