Having all lights on at once, Brights, Dims, and Fog.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by luk8272, Jun 27, 2008.
  1. Jun 27, 2008 at 4:06 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I am not knowledgeable about messing with the wires on our trucks so I was wondering is there a way to leave all your lights on when you put your brights on. I would like my dim, brights and fog lights to remain on when I turn on the brightrs. On older chevys there was a kit you could purchase. I hardly ever use my brights except when riding the levees early in the morning or late in the evening. I'm sure the fog light mod will enable the fogs to remain on, but how about the dims?
  2. Jun 27, 2008 at 4:09 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
  3. Jun 27, 2008 at 4:31 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    I don't want Day time running lights. At night when you turn on your bright lights your dim and for lights turn off. I want them to stay on when I turn on my brights. Am I misunderstanding the mod?
  4. Jun 27, 2008 at 4:55 PM
    silver07taco
    COIL
    Maryland
    Dam sorry man, I mesed you all up I ment the fog light mod is the one you need.
    Sorry i dont have anypics youll need to tap into the wire that runs to the little running light on the side of the headlight to the unused spot on the blinker.
  5. Jun 27, 2008 at 5:02 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    Not a problem man thanks for the info. I thought the fog light anytime mod would only allow the fog lights to be on any time, I didn't think it affected the dim lights. I have been meaning to do the fog light mod but have just been putting it off. I have messing with wiring on vehicles unless it is just for play, or a complete new rewire.
  6. Jun 27, 2008 at 5:46 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    I know in my 01 Tacoma I could pull the headlight lever back just enough for the lows and the highs to be on at the same time.
  7. Jun 27, 2008 at 7:51 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    The fog anytime mod ONLY allows the fogs to be on whenever the key is on. Nothing else.
    You would need something to send power to the low filaments. IE, a relay or something that doesn't also send power to the highs when just the lows are on.... Maybe a diode (limit electricity flow to only highs to lows, and not from lows to highs)?
  8. Jun 27, 2008 at 8:35 PM
    gavonder
    gavonder She's Kickass!
    Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    If you had your dims and brights on at the same time, wouldn't it be too hot and burn out the bulbs really fast?
    GA
  9. Jun 27, 2008 at 11:09 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    Agreed... you can do it with a relay but i would not reccomend it.
    if you had sepperate bulb for both lows and highs then yes very cool..
    I did it on my Old Passat Here is a picture...
    Man that car was fun....
  10. Jun 28, 2008 at 6:20 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    I never thought about it being able to burn them out. I just remembered doing it on the older trucks and it being conveinent. They wouldn't be on for long just a few minutes here and there early in the morning and late in the evening. Maybe 5 minutes at a time. Thanks for the responses.
  11. Jun 28, 2008 at 6:25 AM
    kristopherl
    kristopherl AKA: Jake the Wolf
    Cincinnati, Ohio
    08 Tacoma DC 4x4 Sport LB. Foglight
    Cup holder LEDs, Black Max Tonau, BHL Mod, N-Fab side steps
    yeah, I would think it would burn the bulb out faster. Also consider the fuse to make sure it doesn't overload.
  12. Jun 28, 2008 at 6:44 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    May be smarter for me to just get an extra set of lights. I really hate messing with wires in new vehicles, it never fails i'll mess something up.
  13. Jun 28, 2008 at 7:03 AM
    silver07taco
    COIL
    Maryland
    When I did the fog light mod, I was able to keep the fogs on and have the brights on at the same time.
  14. Jun 28, 2008 at 7:20 AM
    piercedtiger
    Jon
    Southern Tier, NY
    That's the point of that mod. The OP wants LOWS and brights on at the same time... Not just fogs, but low beams AND high beams as well. The fog light mod has absolutely nothing to do with how hi/low beams work.
  15. Jun 28, 2008 at 7:25 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    the problem is that both the low and high beam come from the same bulb. on the 90's model chevys there where 2 seperate bulbs, therefore really easy to do.
  16. Jun 28, 2008 at 7:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    FWIW, I just did the Foglight mod, and it was the easiest thing I have done to the truck yet. Thatnks, piercedtiger! :)
  17. Jun 28, 2008 at 7:45 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    keason1 Thats exactly right. It being so easy made it also easily forgetable, you mentioning that brought it all back.
  18. Jun 28, 2008 at 7:46 AM
    silver07taco
    COIL
    Maryland
    O ok, Thanks I was reading it wrong
