HELP WITH RED TOP OPTIMA
Old 09-10-2010, 09:48 PM   #1
erion109 [OP] erion109 is offline
erion109 has a brilliant futureerion109 has a brilliant futureerion109 has a brilliant futureerion109 has a brilliant futureerion109 has a brilliant futureerion109 has a brilliant futureerion109 has a brilliant futureerion109 has a brilliant futureerion109 has a brilliant futureerion109 has a brilliant futureerion109 has a brilliant future
erion109's Avatar
Army: 1/145 AVN REG
erion109's Tacoma Gallery
I bought a 35 series red top Optima today and my first attempt to install was a failure. The cables will not reach the top post. I noticed someone else had a yellow top that looked to be the same configuration but mounted to the side post. Is there a top to side adapter? He mentioned something about an adapter, but the other way around (side to top). I need some suggestions on making this fit. If it will work, the next thing I want is one of those really nice billet trays that secures the battery from the base. But lets get it working first.
Old 09-10-2010, 09:51 PM   #2
Banned
If you got the specific battery for your truck it should work. The plastic adapter goes on the bottom of the battery but I'm not sure which one is needed for the taco.
Old 09-10-2010, 11:33 PM   #3
erion109's Avatar
Army: 1/145 AVN REG
The plastic adapter doesn't help with the harness. It is for adding height to the battery, which is not a problem.
Old 09-11-2010, 05:09 PM   #5
erion109's Avatar
Army: 1/145 AVN REG
Optima help
I've got the 35. The top post are too far to reach and if I turn it around to mount it with the side post, they are on the wrong side and my body ground won't let my negative cable reach???
Old 09-11-2010, 05:23 PM   #6
T0LLPHR33 is one of the sharper tools in the shedT0LLPHR33 is one of the sharper tools in the shedT0LLPHR33 is one of the sharper tools in the shedT0LLPHR33 is one of the sharper tools in the shedT0LLPHR33 is one of the sharper tools in the shedT0LLPHR33 is one of the sharper tools in the shedT0LLPHR33 is one of the sharper tools in the shedT0LLPHR33 is one of the sharper tools in the shedT0LLPHR33 is one of the sharper tools in the shedT0LLPHR33 is one of the sharper tools in the shedT0LLPHR33 is one of the sharper tools in the shed
T0LLPHR33's Avatar
T0LLPHR33's Tacoma Gallery
Send a message via Yahoo to T0LLPHR33
you can always place the battery as close as possible towards the fuse box...I had to do that with my 35 series...
then I put my 35 series in my chicks altima and put a 75 series instead with a custom mount...
Old 09-11-2010, 06:08 PM   #7
Hot Steppa
pinktaco808 is one of the sharper tools in the shedpinktaco808 is one of the sharper tools in the shedpinktaco808 is one of the sharper tools in the shedpinktaco808 is one of the sharper tools in the shedpinktaco808 is one of the sharper tools in the shedpinktaco808 is one of the sharper tools in the shedpinktaco808 is one of the sharper tools in the shedpinktaco808 is one of the sharper tools in the shedpinktaco808 is one of the sharper tools in the shedpinktaco808 is one of the sharper tools in the shedpinktaco808 is one of the sharper tools in the shed
pinktaco808's Avatar
pinktaco808's Tacoma Gallery
picssss
Old 09-11-2010, 06:12 PM   #8
RCL RCL is offline
RCL will become famous soon enoughRCL will become famous soon enough
RCL's Avatar
Army:
RCL's Tacoma Gallery
Lay it on side and cables will reach. Had to do this on a 2007 TRD.
Old 09-11-2010, 07:54 PM   #9
T0LLPHR33's Avatar
Originally Posted by pinktaco808 View Post
picssss
pics of my setup? or pics of his 35 series where its not reaching the positive and negative terminals?
Old 09-11-2010, 09:03 PM   #10
erion109's Avatar
Army: 1/145 AVN REG
I can lay it on it's side without any negative effects? I'm assuming you used the top post? Does optima have a recommendation since this is the battery they list to fit the tacoma?
Old 09-11-2010, 09:04 PM   #11
erion109's Avatar
Army: 1/145 AVN REG
I'd like to see pics of your 75 setup with custom mount
Old 09-12-2010, 01:16 PM   #13
erion109's Avatar
Army: 1/145 AVN REG
Originally Posted by george3 View Post
I hope someone will provide pics of the problem and solution as I was considering going with Optima but not if it is a major hassle. Thanks.
If someone has a solution, I will post some pics of the problem and proposed solution. I don't want to go through the hassle again without a possible solution.
Old 09-12-2010, 01:21 PM   #14
Proud Tundra *****
oofy15354 is one of the sharper tools in the shedoofy15354 is one of the sharper tools in the shedoofy15354 is one of the sharper tools in the shedoofy15354 is one of the sharper tools in the shedoofy15354 is one of the sharper tools in the shedoofy15354 is one of the sharper tools in the shedoofy15354 is one of the sharper tools in the shedoofy15354 is one of the sharper tools in the shedoofy15354 is one of the sharper tools in the shedoofy15354 is one of the sharper tools in the shedoofy15354 is one of the sharper tools in the shed
oofy15354's Tacoma Gallery
yes that is the point of the optima batteries. they are one of the only(if not THE only battery that can do this and wont spill and will function perfectly normally)
Old 09-12-2010, 03:01 PM   #15
RCL RCL is offline
RCL's Avatar
Army:
I had one in my 2007 TRD for 2years with it on the side and no ill effects. Would post pic but sold it last week and bought new TRD.
Old 09-12-2010, 03:59 PM   #16
Hacksaw engineer
Trapper6speed has much to be proud ofTrapper6speed has much to be proud ofTrapper6speed has much to be proud ofTrapper6speed has much to be proud ofTrapper6speed has much to be proud ofTrapper6speed has much to be proud ofTrapper6speed has much to be proud ofTrapper6speed has much to be proud of
Trapper6speed's Avatar
Trapper6speed's Tacoma Gallery
I can' remeber who sells a nice buillet mount for the Optima, but I mounted both mine on the SuperDuty I had on the frame rails. Made a lot of room in the engine compartment.
Old 09-12-2010, 04:00 PM   #17
ilovetacos is one of the sharper tools in the shedilovetacos is one of the sharper tools in the shedilovetacos is one of the sharper tools in the shedilovetacos is one of the sharper tools in the shedilovetacos is one of the sharper tools in the shedilovetacos is one of the sharper tools in the shedilovetacos is one of the sharper tools in the shedilovetacos is one of the sharper tools in the shedilovetacos is one of the sharper tools in the shedilovetacos is one of the sharper tools in the shedilovetacos is one of the sharper tools in the shed
ilovetacos's Avatar
ilovetacos's Tacoma Gallery
Send a message via ICQ to ilovetacos
I have a D34/78 Yellow Top with sideposts. The posts are opposite from the factory battery. The factory positive cable was long enough to extend to the sidepost but I had to buy a longer negative cable that was long enough to reach.
I use the top posts for my amp and added fuse block.
Old 09-12-2010, 04:02 PM   #18
ilovetacos's Avatar
Here's another picture of when I had the Red Top, same battery size as the Yellow Top I have now.
Old 09-12-2010, 04:09 PM   #19
Club Soda Not Seals
Mush Mouse is one of the sharper tools in the shedMush Mouse is one of the sharper tools in the shedMush Mouse is one of the sharper tools in the shedMush Mouse is one of the sharper tools in the shedMush Mouse is one of the sharper tools in the shedMush Mouse is one of the sharper tools in the shedMush Mouse is one of the sharper tools in the shedMush Mouse is one of the sharper tools in the shedMush Mouse is one of the sharper tools in the shedMush Mouse is one of the sharper tools in the shedMush Mouse is one of the sharper tools in the shed
Mush Mouse's Tacoma Gallery
Take it back and get a Sears Diehard,fits perfect,and better than Optima without any special mounts
Optima Yellow Top Digiratus Deals & Coupons 4 07-22-2012 10:26 PM
Optima Red Top Group 34 ROCKSLINGER Buy / Sell / Trade 0 04-06-2011 11:57 PM
Optima red vs yellow Cr250jumper Technical Chat 9 02-19-2011 05:43 PM
Optima D34/78 Red Top (install w/pic) ilovetacos 2nd Gen. Tacomas 10 03-05-2010 04:11 PM
Optima D34/78 Red Top (install w/pic) ilovetacos 2nd Gen. Tacomas 0 02-28-2010 11:56 PM
