Bed rails attachments.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EricGagne, Sep 18, 2010.
  1. May 10, 2011 at 6:53 AM
    #61
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  2. Jun 7, 2011 at 11:27 AM
    #62
    wootalien
    wootalien Well-Known Member
    Nathan
    Texas
    Virgin
  3. Jun 7, 2011 at 11:30 AM
    #63
    winterboy04
    winterboy04 Professional Cube-Jockey
    MA
    07 SR5 TRD (Bright Red)
    Alpine CDA-9886 Hybrid Audio Unity Series components JL 250.1, JL300.4 Infinity Perfect 10.1 SVC 4ohm in custom enclosure / amp rack Alpine PXA-H100 Processor FatMat everywhere URD short shifter OEM Bed Mat Tail Gate Safety Mod (Plumbing clamps) Pro-Dry S Filter
    i actually tried to order of some these, and i was told by a Fastenal Rep that they have a small shortage and that he would let me know as soon as he got some in. bummed...
  4. Jun 7, 2011 at 11:55 AM
    #64
    wootalien
    Nathan
    Texas
    Virgin
    When did you call? I ordered these last week. Did you call a store around your area?
  5. Jun 7, 2011 at 12:00 PM
    #65
    winterboy04
    MA
    I did, i called one in Massachusetts (this past Thursday 6/2/11) and the guy said that he only saw a single unit and it was in Tennessee or something. Maybe i just got the new guy, i suppose it can't hurt to try and order them now anyway.
  6. Jun 7, 2011 at 12:20 PM
    #66
    wootalien
    Nathan
    Texas
    Virgin
    The Rep I talked to said there was only 2 in Texas but he was able to place an order with the manufacture in Ohio. They can also ship the item to your house. Call this store if you can't get your store to help you. FYI Shipping was $7 for 10 slotted nuts.
    7720 Pinemont
    Houston, TX 77040
    713-939-7153
  7. Jun 7, 2011 at 5:50 PM
    #67
    Sandman614
    Tim
    '06 SR5 Off Road
    Ask for Kent Leonard. Tell him Tim sent you.
    Store Code:
    NCWES
    Hours: Monday - Friday 7:00am - 5:00pm
    Phone: 336-846-8748
    Fax: 336-846-1298
    1203 South Jefferson Ave
    West Jefferson, NC 28694
    Map and directions
  8. Jul 15, 2011 at 10:18 AM
    #68
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I just got the T-nuts from my local Fastenal shop- (had be be shipped to them, and there were only a few in stock across the country he said)
    They fit good, and the many potential uses these will offer... I can't wait to find my first use for them. :)
  9. Jul 15, 2011 at 3:43 PM
    #69
    EricGagne
    EricGagne [OP] Well-Known Member
    Eric
    Montreal
    2010 TRD Off Road
    Literider Tonneau Cover, RAM Mount Laptop Support. Uniden CB RTT and awning with self-designed custom rack Dual battery system - National Luna solenoid and monitor, Columbia Overland dual battery tray, 2 Odyssey PC1200 12 circuits Fuse block with 80A macro fuse block "breaker" OME suspension Replaced passenger area with a flat platform for my ARB fridge and camping clothes. Tiregate HG series
    PJS I'm sure you do know that posting in this thread legally binds you and that from now on you must post pictures of whatever use you come up with for your T-Nuts.
    :D
  10. Jul 15, 2011 at 7:36 PM
    #70
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    Gotcha- I was already looking a steel and aluminum stock today to get ideas for creating brackets to hang from the t-nuts to mount "items of necessity". I will post anything I come up with... :spy:
  11. Jul 15, 2011 at 7:46 PM
    #71
    1Bigbird
    1Bigbird Yo! Wat up peeps?
    winter-peg
    2010 TRD D-Cab
  12. Jul 16, 2011 at 11:58 PM
    #72
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    I believe right off the bat you could install a "Quick Fist" to any T-slot nut, by drilling out the mounting hole of the quick fist to fit the 3/8" bolt size of the T-slot. From here, you could attach a shovel or Ax, or any tool the quick fist will hold. If you had a shell, or cover, etc. I believe you can get some 1"x1/8" flat stock iron, to cut "brackets" to hang down from the rail to be able to clear the "topper" with the same tools.
  13. Jul 17, 2011 at 12:03 AM
    #73
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    #73
  14. Jul 17, 2011 at 12:05 AM
    #74
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Cool thread
  15. Jul 17, 2011 at 12:12 AM
    #75
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 Mt/r kevlar
    Thanks for reviving this thread.
  16. Jul 17, 2011 at 5:42 AM
    #76
    EricGagne
    Eric
    Montreal
    2010 TRD Off Road
    Good idea but if you drive a lot on gravel roads I think it would be best to make a bracket even if you don't have a cover. A shovel or axe would generate strong vibrations at medium or high speed on washboards and I wonder if the quick fist would resist if you enlarge the hole.
  17. Jul 21, 2011 at 6:40 AM
    #77
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    Good point. I thought about this. However, the t-slot requires a 3/8" bolt, and the width of the Quick fist where the bolt goes thru is 13/16" W. It illustrates a "plastic washer" supplied which goes on the inside of the clamp between the bolt and the clamp. I think if you can reconfigure the mount set up with the 3/8" bolt, and with the clamps I believe having a holding power of 22 or 23 lb EA, I do not think it will be an issue. But I will let you all know when I try it... :D
  18. Jul 21, 2011 at 7:49 AM
    #78
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    How did this never get a sticky?
  19. Jul 21, 2011 at 9:01 AM
    #79
    silver taco
    silver taco Well-Known Member
    Los Angeles
    07 4X access cab
    Icon 2.5 ext travel, Camburg 1.25" uca's, All-pro leafs, Icon 2.5" rear shocks, LR jounce front and back, breather mod, KR Fab rear bumper, Kenwood 2m radio, All-Pro sliders, Front bumper by Surfinferno (Dylan), Glassworks fenders, 4:56 gears, gusseted spindles and coil buckets
    Slightly off- topic but kind of related. L2S makes adapters that bolt to bed cleats to allow use of Yakima or thule crossbars with the cleats. You can use conduit as a cheaper alternative to the Yakima bars as well.
  20. Jul 21, 2011 at 9:15 AM
    #80
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
