$1200 for new lower control arms!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SpaceMonkey, Sep 24, 2010.
  1. Sep 24, 2010 at 9:33 AM
    SpaceMonkey
    SpaceMonkey [OP] Well-Known Member
    Houston, Tx
    06 PreRunner
    So my truck has been making a strange metallic popping sound, usually when turning. The shop I took it to said I need new lower control arms to the tune of $1200. They said the LCAs had some movement to them which was causing that noise. I couldn't believe the cost to replace them. Do you guys think a dealer will be cheaper? Any idea where I might find new LCAs for less cost?
    Also, how would my LCAs go bad? I only have a little over 50k miles on my truck and it sees mostly highway miles. It has a mild lift too so what's the deal? Pretty bummed out.
  2. Sep 24, 2010 at 9:35 AM
    stroM-
    stroM- @alteregoadventure
    Jason
    Santa Rosa, California
    2006 4X4 TRD OR
    There was a thread on this a while back... Try to torque the LCA bolts to 110lbs (i think thats what i remember) And the noise should go away.
  3. Sep 24, 2010 at 9:37 AM
    SpaceMonkey
    Houston, Tx
    06 PreRunner
    ^ I already did that and it helped but the shop said there is still too much play in those LCAs. Sucks I can't just get new bushings.
  4. Sep 24, 2010 at 9:43 AM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    Sounds like it's time to upgrade to LONG TRAVEL!!
    or, maybe you can find a member on here who has long travel, and wants to sell their old LCAs.
    I just did a quick RockAuto.com search because I was curious myself. Yeah, they're basically $500 a piece on there, and they usually have the lowest prices. But holy crap that's so expensive!
    Sorry, bud, looks like your SOL unless you find somebody to help you out.
    Gunshot-6A and JDawg562 like this.
  5. Sep 24, 2010 at 9:45 AM
    SpaceMonkey
    Houston, Tx
    06 PreRunner
    Thanks sachou. i told the shop to loosen the bolts and to try to retorque them down again. My buddy and I tried that about a month ago but we may have not torqued them down enough. We'll see. Yeah, it's really expensive. Thanks Toyota.
  6. Sep 24, 2010 at 9:45 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    Dominic4Lo and ChadsPride like this.
  7. Sep 24, 2010 at 11:02 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    x2. If you're dropping that much coin you might as well upgrade. The TC LCAs are far stronger and serviceable.
    JDawg562 and ChadsPride like this.
  8. Sep 24, 2010 at 11:05 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    X2 this is like the perfect excuse
  9. Sep 24, 2010 at 11:06 AM
    FL Forester
    FL Forester Well-Known Member
    Jason
    Tallahassee, FL
    2016 4Runner
    You should still be under the powertrain warranty. Ask the dealership if it is covered.
  10. Sep 24, 2010 at 11:13 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I moded 1999 Taco so much it had turned to Land Cruiser
    thats BS
    Here are part numbers for 2007 4x4 bushings
    48654E BUSH, FRONT LOWER ARM, NO.1 RH48654‑04040GRN245, 250, 265, 270, TRN24*, 26*1$61.97
    48654F BUSH, FRONT LOWER ARM, NO.1 LH48654‑04040GRN245, 250, 265, 270, TRN24*, 26*1$61.97
    48655D BUSH, FRONT LOWER ARM, NO.2 RH48655‑04020GRN245, 250, 265, 270, TRN24*, 26*1$74.23
    48655E BUSH, FRONT LOWER ARM, NO.2 LH48655‑04020GRN245, 250, 265, 270, TRN24*, 26*1$74.23
    You can verify them in dealership
  11. Sep 24, 2010 at 11:23 AM
    SpaceMonkey
    Houston, Tx
    06 PreRunner
    Is that 5 years/60K? I forget. I could try the dealer but the issue is with the suspension not the powertrain.
  12. Sep 24, 2010 at 11:24 AM
    SpaceMonkey
    Houston, Tx
    06 PreRunner
    I was under the impression we couldn't get these separately. Interesting. Thanks for checking.
  13. Sep 24, 2010 at 11:49 AM
    BlueT
    NorthEast
    np
    Cut the old bushings out, dont even try to press them out its not gonna happen :D
    Cleanup arms and press new ones in. Done... :)
    Pirhett likes this.
  14. Sep 24, 2010 at 12:46 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    X2
    Acetylene torch works nicely also.
  15. Sep 24, 2010 at 1:05 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Damn why are those things so much? They don't look particularly complicated to make.
  16. Sep 24, 2010 at 1:26 PM
    SpaceMonkey
    Houston, Tx
    06 PreRunner
    ^ Good old Toyota. I have my truck back as it was. I asked the guy at the shop if they sold the bushings separately and he told me no, that it all has to be replaced. I guess they really wanted $1200 out of me.
    I have some good knowledgeable friends who can help me troubleshoot this further. Thanks for everyone's help.
    I married my tacoma likes this.
  17. Sep 24, 2010 at 2:36 PM
    Fortech
    CANADA
    All you need to do to check the bushings is jack up the front of the truck and check for play at the bushings with a pry bar. 10 mins work.
  18. Sep 24, 2010 at 2:41 PM
    wilsonpj
    wilsonpj Well-Known Member
    Pete
    Charleston, South Carolina
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
    same problem here I think. I'm still trying to figure out exactly what it is and make sure its not something else.
  19. Sep 27, 2010 at 10:38 AM
    BMiller421
    BMiller421 FMLYHM
    Brandon
    Bakersfield, CA
    05 Pre-runner
    LT, Kings, Fabricated Trucks Worldwide For The Win, K&N and Doug Thorley LT Headers
    My LCA bushings are shot to sh!t..and I know I need to replace them cus I get all the same poping and clinky clanky noises too.
    It's kind of embarrassing to say the least..I wish they were greasable..
  20. Sep 27, 2010 at 10:50 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    What shop is this?
