3 Inch TOYTEC Ultimate Lift OR RCD 4.5 Inch Lift Kit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FXHO, Oct 3, 2010.
  1. Oct 3, 2010 at 8:07 PM
    FXHO
    FXHO [OP] Well-Known Member
    Luis
    Miami,FL
    2013 Toyota Tacoma DCSB TRD Sport
    I need some help from TW on deciding which lift would be best for the TACO and why. Pros and cons PLS
    1) 3 Inch TOYTEC Ultimate Lift
    OR
    2) RCD 4.5 Inch Lift Kit
    either one would be running XD Monster Wheels 18x9, 275/70/18
    I really like how the 4.5 inch looks bc of the aggressiveness but is $$$$ and the 3 inch looks nice and is more affordable but I would like it a bit higher.... So Taco lovers, what do you guys think. Remember pros and cons abt both would really help and your honest opinion too.:cool:
  2. Oct 3, 2010 at 8:09 PM
    francis1291
    francis1291 Well-Known Member
    10 4x4 SR5 super white
    3" procomp lift wit 20" rockstars on 33 toyo mt's
    I have a pro comp 3 inch lift on mine and i like it. Came wit new coil springs and shocks and aal's
  3. Oct 4, 2010 at 2:51 PM
    FXHO
    Luis
    Miami,FL
    any 1?
  4. Oct 4, 2010 at 2:52 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    I wouldn't run a drop bracket lift but it's just personal preference.
  5. Oct 4, 2010 at 2:53 PM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    i am partial to the toytec ultimate lift.
    is your truck a 4x4?
  6. Oct 4, 2010 at 2:59 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    I run the RCD... and had a 3" lift before, but I'd talk to jrobson... he had the toytec ultimate and now has the RCD... he has personal experience with both, he switched for a reason, but I don't remember why (something about blowing cv's)
    Pro:
    the RCD gives you smooth ride (a little stiffer than stock due to bilsteins) and the perfect ride height for these trucks.
    CV angles are perfect...
    run atleast 33"/12" wide tires with no rubbing/cutting/modification
    Con:
    Drop bracket lift (if thats a con to you)
    The rear set up (blocks) is a little undesirable but can be changed.
    just one con related to the RCD lift kit itself... rough texture causes some difficulty with the install, along with the positioning of the cam bolts
    btw, wheelersoffroad has the RCD kit for $1799 vs ULT $1149
  7. Oct 4, 2010 at 3:08 PM
    FXHO
    Luis
    Miami,FL
    whats a drop bracket lift ??? what does that mean? whats so bad abt it?
    and what do you mean rough texture?
  8. Oct 4, 2010 at 3:09 PM
    FXHO
    Luis
    Miami,FL
    no its not 4x4.
  9. Oct 4, 2010 at 3:11 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    oh you're not 4x4! forget everything I just said
    easy... get lift spindles... and a leaf in the rear and call it a day...
  10. Oct 4, 2010 at 3:14 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    drop brackets are only important to 4wd vehicles... allows the front cross member to be chopped to allow the front diff to drop down and thus lower the LCAs to allow longer spindles and shocks...
    you are 4x2 don't worry about it... get new spindles either 3.5" or 4" and something for the rear... run either stock shocks or bilsteins or any shock you want...
    lifting 4x2 = easy
    don't waste your money lifting a 4x2 with shocks/springs alone... check out iamrayzians build or search for spindles
    camburg 4" spindles
    or
    Total Chaos 3.5" spindles
  11. Oct 4, 2010 at 3:19 PM
    FXHO
    Luis
    Miami,FL
    so the is it ok to buy this kit and install it the way it comes>>>>
  12. Oct 4, 2010 at 3:24 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    ^I guess you could do that without cutting anything (but IDK for sure)... but why would you do that... just get spindles from camburg... that would be a lot of unnecessary work
    http://www.camburg.com/?p=452
    add some bilsteins 5100 set an zero and 4" something for the rear and you'd be golden
  13. Oct 4, 2010 at 6:01 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    You will rub like crazy with 18x9's. I ran 17x9 with 285-70-17's and had my coils cranked to the max and it still rubbed with the toytec kit. I would definately go with RCD unless you are just going for a mall crawler.The Toytec lift was a rough ride as well with the coils set where I had them. Spend the extra and go RCD. Your 18'swill run perfectally under it and it will perform great ofroad also.
  14. Oct 4, 2010 at 6:03 PM
    jrobson
    Mobile, Alabama
    09 DC 4x4
    Go with Solus's idea. I like that the best for a 4x2.
  15. Oct 4, 2010 at 7:00 PM
    DevL
    DevL Well-Known Member
    If you get an drop bracket instead of spindles for a 4x2 you are an idiot... but thats just my opinion.
  16. Oct 4, 2010 at 8:13 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    ^no need to bash him... he doesnt know any better... thats why he is here to get an Tacomacation!
  17. Feb 23, 2013 at 10:47 AM
    pvfd1270
    pvfd1270 Member
    John
    Polkville, NC
    06 tacoma dlb cab 4x4
    Fab four bumper
    Whats the best 3" lift kit to get for my 06 Tacoma 4x4? I have a pro comp on my 99 with diff drop but it blows cv boots still.....im scared to death of the spacer deal cause of this. Is a lift with new spings and taller struts safer? Dont want this prob on my new one.......thanks!
  18. Aug 8, 2013 at 12:37 PM
    waheed
    waheed Well-Known Member
    Waheed
    Vancouver
    2010 Tacoma TRD OFF-ROAD
    Banks power Exhaust, 4x4 LED mod, Duratracs, SNUGTOP, LED insideNout
    [QU"OTE=sol us;22 clearence43300]I run the RCD... and had a 3" lift before, but I'd talk to jrobson... he had the toytec ultimate and now has the RCD... he has personal experience with both, he switched for a reason, but I don't remember why (something about blowing cv's)
    Pro:
    Con:
    Sooooo I got a 4x4 "drop bracket lIft" means less clearnce under truck??
