Passenger window wont roll up
Old 10-18-2010, 09:34 AM   #1
rraether [OP] rraether is offline
rraether has much to be proud ofrraether has much to be proud ofrraether has much to be proud ofrraether has much to be proud ofrraether has much to be proud ofrraether has much to be proud ofrraether has much to be proud ofrraether has much to be proud of
rraether's Tacoma Gallery
My passenger window wont roll up. i checked the fuzes and nothing is blown. Anyone have a recommendations before i take it to toyota?? p.s. neither of the switches will work. doesnt make a sound or anything. only drivers window works now.
Old 10-18-2010, 09:48 AM   #2
Time is precious; use it wisely
Crom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shed
Crom's Avatar
Crom's Tacoma Gallery
Sounds like the motor went out. Hopefully you're truck is till under warranty.
EDIT: Check to make sure that you haven't activated the child window lock. It's the switch on the driver arm rest.
Old 10-18-2010, 09:50 AM   #3
Pasti-Dip Free Since 1983
Pugga's Avatar
Pugga's Tacoma Gallery
x2, there aren't many components to the window operators. If the fuse isn't blown and the wires aren't cut, either switch is bad (unlikely) or the motor is bad (likely).
Old 10-18-2010, 09:51 AM   #4
The MOST Badass Offroad Truck
BravesFan is one of the sharper tools in the shedBravesFan is one of the sharper tools in the shedBravesFan is one of the sharper tools in the shedBravesFan is one of the sharper tools in the shedBravesFan is one of the sharper tools in the shedBravesFan is one of the sharper tools in the shedBravesFan is one of the sharper tools in the shedBravesFan is one of the sharper tools in the shedBravesFan is one of the sharper tools in the shedBravesFan is one of the sharper tools in the shedBravesFan is one of the sharper tools in the shed
BravesFan's Avatar
BravesFan's Tacoma Gallery
Probs child window lock.....ive done it many times
Old 10-18-2010, 09:53 AM   #5
Mind = Blown
Loudpedal is one of the sharper tools in the shedLoudpedal is one of the sharper tools in the shedLoudpedal is one of the sharper tools in the shedLoudpedal is one of the sharper tools in the shedLoudpedal is one of the sharper tools in the shedLoudpedal is one of the sharper tools in the shedLoudpedal is one of the sharper tools in the shedLoudpedal is one of the sharper tools in the shedLoudpedal is one of the sharper tools in the shedLoudpedal is one of the sharper tools in the shedLoudpedal is one of the sharper tools in the shed
Loudpedal's Avatar
Army: EOD
Loudpedal's Tacoma Gallery
Odd. So when you say neither switch do you mean the switch on the driver's door won't work either? Sounds like maybe the motor died. Or perhaps something in the door is disconnected. Maybe jostled around good at the puerco? Or have you washed it recently. The wife's 350Z window switched died when they got wet from opening the door in the rain, so maybe water got in the motor through a bad place in the weatherstrip?
Old 10-18-2010, 09:55 AM   #6
Mind = Blown
Loudpedal's Avatar
Army: EOD
Or this. Forgot about that. My 1st gen with manual crank windows doesn't have them.
Old 10-18-2010, 09:55 AM   #7
Pugga's Avatar
That would be pretty funny.... Check this before you take it to the dealership!!
Old 10-18-2010, 11:10 AM   #8
Dummy error for sure. Lol I just checked the window lock on the drivers door and sure enough it was engaged. Haha glad im not the only one who has done that
Old 10-18-2010, 11:14 AM   #9
Pugga's Avatar
Personally, I would have just said the motor was bad and not admitted to it...
Old 10-18-2010, 12:53 PM   #10
jpmorrisvb is one of the sharper tools in the shedjpmorrisvb is one of the sharper tools in the shedjpmorrisvb is one of the sharper tools in the shedjpmorrisvb is one of the sharper tools in the shedjpmorrisvb is one of the sharper tools in the shedjpmorrisvb is one of the sharper tools in the shedjpmorrisvb is one of the sharper tools in the shedjpmorrisvb is one of the sharper tools in the shedjpmorrisvb is one of the sharper tools in the shedjpmorrisvb is one of the sharper tools in the shedjpmorrisvb is one of the sharper tools in the shed
jpmorrisvb's Avatar
Navy: NDT/QA
jpmorrisvb's Tacoma Gallery
Well, as long as you don't tell anyone you'll be okay ...... .
Passenger seat wont lock - keeps reclining? omegax 1st Gen. Tacomas 2 01-18-2014 08:49 PM
Passenger Window Wont Go Up or Down? 98Tacomav6 1st Gen. Tacomas 0 09-12-2011 06:44 AM
Passenger door wont latch turboser 2nd Gen. Tacomas 2 02-06-2011 06:26 PM
my window wont roll up! davestaco 1st Gen. Tacomas 4 09-12-2010 01:02 PM
Passenger Window will not roll down. nitrus5 2nd Gen. Tacomas 16 12-14-2008 12:01 PM
