2 questions...wheels fitting truck and tires fitting wheels?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by InfamousTonyTaco7714, Oct 18, 2010.
  1. Oct 18, 2010 at 9:16 PM
    InfamousTonyTaco7714 [OP] Well-Known Member
    Lucas
    Wilkes, NC
    09 SR5 DCSB 4x4 Timberland Mica
    Borla Catback, 6 inch Pro Comp Stage 1 17x9 Matte Black XD Revolvers, 285/70/17 Radar Renegade R7, Pioneer Double Din, Iron Cross Side Steps, Tactical Armor Group Front Bumper, ARE MX series camper shell, Geared 4.10
    I have a 2009 taco db 6-lug 4x4 and was looking at some 16" BLACK MB Chaos 6 WHEELS RIMS 6x139.7 (6x5.5") LUG with a -6mm backspacing and was wondering if they would fit the truck.
    Also, I have some Kelly Safari Trex 255/75/R16 tires and was wondering if they would fit this wheel?
  2. Oct 19, 2010 at 7:48 AM
    TexasTacoma37
    Depends on the rim width. The -6mm you posted is the offset, not the backspacing. Backspacing is calculated by using rim width and offset. Ideal backspacing is 4.5" to run up to 285's.
  3. Oct 19, 2010 at 7:53 AM
    98tacoma27
    Ben
    Not Beech Creek
    10" tire on an 8.5" rim. I think that's ok. Anyone else?
  4. Oct 19, 2010 at 7:57 AM
    TexasTacoma37
    If 8.5 is the rim width, then the backspacing with a -6 offset is 4.5", so you are good to go there as far as rim fitment. Just make sure that brand of wheels will clear the front calipers. Certain 16's won't.
  5. Oct 19, 2010 at 7:58 AM
    98tacoma27
    Ben
    Not Beech Creek
    The BS won't be a concern with a 255 tire. He could run them on stockers.
  6. Oct 19, 2010 at 7:59 AM
    TexasTacoma37
    True, he'd be good with anything between 4.5" and 5.5".
  7. Oct 19, 2010 at 8:56 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    OP didn't tell us a rim width. I assume someone looked up those rims to come up with 8.5? At any rate: OP: Check the tire specs from the mfr and make sure that the range of rim widths for the tire includes the width of the specific rim you're considering. Otherwise, looks good to go.
    At 16" rims - one consideration is some 16" aftermarket rims hit the caliper. That's more a function of rim style than any of the specs, so it's hit or miss, if you'll pardon the pun. Only thing you can do is try it, unless you can find someone who's already mounted that specific rim in that specific size on a Taco of this generation.
