WHEEL STUD REPLACEMENT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by socal4x, Oct 25, 2010.
  1. Oct 25, 2010 at 9:05 AM
    socal4x
    socal4x [OP] Well-Known Member
    CA
    '16 MGM DCSB OR 4x4 6MT
    Did some work on the Suspension this weekend and broke a wheel stud (pos Harbor Freight torque wrench, now in trash).
    Anybody ever replace one of these (2 gen 4x4)? How much stuff do I have to take apart?
  2. Oct 25, 2010 at 9:09 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    shouldnt need to take much apart. remove your rotor and just hammer on the broken stud and it should pop out the back. new one just slide back in its place. i think there is enough room without having to remove anything other than the rotor
    AR15xAR10 likes this.
  3. Oct 25, 2010 at 9:11 AM
    98tacoma27
    Ben
    Not Beech Creek
    Front = tire, rotor/brakes Rear = drum and brakes
    Torspd likes this.
  4. Oct 25, 2010 at 9:14 AM
    socal4x
    CA
    Oh, yeah, its the front...sweet, now I just have to find the part!
  5. Oct 25, 2010 at 9:18 AM
    socal4x
    CA
    Thanks for that .pdf!!!
  6. Oct 25, 2010 at 9:30 AM
    Yoytoda
    Roland
    completely stock
    fyi if you disconnect the brake line bracket you can remove the caliper without taking the line loose. will help when reassembling to not have to bleed brakes...
    REDdawn6 likes this.
  7. Dec 20, 2015 at 11:11 AM
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
    Any new link? didn't open for me
  8. Sep 27, 2016 at 1:39 AM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    I'm bringing this thread back to life.
    I just broke a front stud off on my 2007 while rotating tires... I was using a very expensive torque wrench.... Dealership was the last place to touch it when they put new tires on. Lol
    Does anybody have any part numbers for a new stud? Hoping to grab one at Napa or another parts house, nearest Toyota dealership is 30 miles away.
  9. Sep 27, 2016 at 5:49 AM
    98tacoma27
    Ben
    Not Beech Creek
    07 sport 4x4 and chunt5 like this.
  10. Sep 27, 2016 at 6:58 AM
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    Lazy techs use an impact to put lug nuts back on. Same lazy techs don't use a torque stick.
    07 sport 4x4[QUOTED] likes this.
  11. Sep 27, 2016 at 9:49 AM
    magnetic4x4
    magnetic4x4 Well-Known Member
    2013 Magnetic Gray DCSB XSP-X 4x4
    There's nothing wrong with using an impact on lug nuts IF you use a torque stick. I've had cars come into the shop I work at that somebody obviously didn't know what they were doing with an impact because they hard to remove.
    07 sport 4x4 likes this.
  12. Sep 27, 2016 at 8:15 PM
    randomguy
    The Dalles, OR
    17 T4R 4x4 MGM
    Key word is torque stick. I'm pretty sure that tool is missing in the majority of quick oil change and tire places that use an impact on lug nuts.
    I've personally twisted a 4 way taking off impacted lug nuts. I've also seen much worse. A family member had a Ford Explorer go into the shop to have a spindle replaced. At a picnic 3-4 days later I heard the vehicle rolling in, sounded like rocks in a tin can. I popped the hub cap off expecting to find a loose lug nut. Instead I found 3 of the 5 studs were snapped and rolling around loose in the hub cap.
  13. Sep 28, 2016 at 5:05 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Thanks for the replies everybody, I ran to autozone after I posted that and grabbed a couple extra wheel studs. I had it fixed in about an hour. I ended up pulling the hub/bearing assembly off and knocking the new one in there with a hammer and punch. I used the dorman stud, it perfect fit. image.jpg
  14. Sep 28, 2016 at 5:23 PM
    Clearwater Bill
    Clearwater Bill Never answer an anonymous letter
    Billy
    Largo Florida
    '13 5 lug AC w/convenience package
    A few OE parts from fancy trucks
    You didn't have to knock the new one in. Just get it started a bit with the splines aligned, put an open nut on it and pull it in place with the nut.
  15. Sep 28, 2016 at 6:25 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    I tried, couldn't get it to draw in all the way. The splines might be a little bigger on the dorman than the oem. The OEM lug was super easy to knock out, but the dorman took a pretty good lick to seat in. I decided to take the hub/bearing off anyways to see what kind of shape the bearings were in.
  16. Sep 28, 2016 at 6:41 PM
    JaxJim
    JaxJim Well-Known Member
    Jim
    Jacksonville, FL
    13 TRD Sport, DCSB, 4x4, JBL, NAV
    Exterior: Duratrac 265/70/17, SpiderTrax 1.25" wheel spacers, BAMF sliders, DiamondBack SE Tonneau Cover, Pop&Lock, Tail Gate guard, Bed Mat, Bullaculla Trailer Harness bracket, Front Side Windows tinted to match rear, Removed all chrome and dealer badges, Toyota OEM Roof Rack/Rails, SOS Concepts Front Recovery bracket Under Hood: Redline Tuning Quicklift Hood Struts, Foglight anytime mod, UniFilter for Secondary Air Pump Interior: Seat bell Chime disable (TechStream), WeatherTech floor liners, ImMrYo rearview mirror relocation bracket, 12v Always-on Power port in console Radios/Comms: AntennaX 14", Escort Passport MAX Radar Detector, Yaesu 2900 Ham Radio, Uniden 980SSB CB Radio, Relentless Fabrication hood antenna mount, BAMF tailgate antenna mount, FireStik 2m and CB antennas, FireRing coax
    Get a standard lug nut that the lug bolt can go all the way through. Use the flat side of the lug nut against the hub and crank down with a socket wrench, impact wrench of lug wrench. This should draw the new lug bolt in flush to the back of the hub. Use a little lube to make it easier as well.
  17. Sep 28, 2016 at 6:43 PM
    magnetic4x4
    I've had that problem a couple times at work. I believe they were dorman as well. One of them wouldn't go all the way, even with a snap on air hammer.
  18. Sep 28, 2016 at 6:45 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    They weren't that tight.... I wish there was a hole in the dust cover so you could smack em with a punch. I thought about drilling a hole just for that, but didn't. Lol
  19. Oct 22, 2016 at 3:12 PM
    oxinbox21
    oxinbox21 Well-Known Member
    Hi everyone,
    I have some badly cross threaded studs that I need to replace. What studs do I buy??? Anything else I am going to need to buy? Front and back??? Thanks
  20. Apr 5, 2018 at 7:06 AM
    Jon G
    Jon G Hoarding Tacomas one at a time,
    Jon
    St John's Newfoundland Canada
    02, 04 & 07 Tacoma
    Magnaflow 2.5 Catback Exhaust K&N filter
