Serpetine Belt replacement????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ETaco23, Nov 9, 2010.
  1. Nov 10, 2010 at 10:18 AM
    #21
    chyknees
    chyknees nomadic wanderer
    So Cal
    05 Tacoma TRD 4x4
    TRD, Total Chaos, Fox, Volk, BFHoodrich
    be sure to check your belts every now and then. I changed my supercharger belt and 10k miles later, it was cracked to hell. Had to make toyota do a part warranty.
  2. Nov 10, 2010 at 4:15 PM
    #22
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    thanks for the tips guys! And I will check my pulleys when I go to change the belt. I hope none of them are bad. But alot of members have had to replace either there Tensioner pulley or a idler. I hope I dont!
  3. Nov 10, 2010 at 7:28 PM
    #23
    ETaco23
    Evan
    PNW
    If it is one of the idler pulleys, bc the sound does seem to be coming from the passeger side.
    But if it is, how hard are they to cange?
  4. Nov 11, 2010 at 6:31 AM
    #24
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I moded 1999 Taco so much it had turned to Land Cruiser
    They are 12 mm on fan clutch, and.... they easily round off. One advice I would give is to get 12 mm 6 point wrench to work on them. Its harder to round em off that way :)
  5. Nov 11, 2010 at 6:56 AM
    #25
    ETaco23
    Evan
    PNW
    thanks! is it fairly easy to replace pulleys? ive never done it before...
  6. Nov 11, 2010 at 9:07 AM
    #26
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Just fyi... once you get the belt off spin the idlers and if they have no resistance and sound like a roller skate, that means it needs replacement. Its not hard ro replace them. Simple R&R.
    X2 on using a 6 point 12mm
  7. Nov 11, 2010 at 4:31 PM
    #27
    ETaco23
    Evan
    PNW
    awsome! thanks for the tip, and help! cant wait to get rid of this annoying squeek.
  8. Nov 18, 2010 at 6:32 PM
    #28
    wolfman05
    wolfman05 Well-Known Member
    Seattle, Washington
    05 Prerunner
    Working on it
    After replacing my belts the squealing under my hood came back. Did a little research, it sounds like its pretty common for the #2 pulley to go out (passenger side top). My mechanic said i should replace the pulleys (all 3), and he would sell them to me at coast, $30 each. I decided to take off my old pulleys give them a good clean out and re grease. The squeal is gone didn't cost me a cent! I can do a write up if needed but Google and Youtube are your friend.
  9. Nov 18, 2010 at 6:35 PM
    #29
    wolfman05
    Seattle, Washington
    05 Prerunner
    Working on it
    Thats how I found out mine were bad. Took the belt off and gave them a good spin. Like stated above it sounds like a roller skate. They are easy to replace but you can just clean out and re grease as well.
  10. Nov 18, 2010 at 7:17 PM
    #30
    ETaco23
    Evan
    PNW
    I will have to try this... Thanks Matt!
    What If its the Tensioner? can I still take it out and clean/re-grease it?
  11. Nov 19, 2010 at 8:06 AM
    #31
    wolfman05
    Seattle, Washington
    05 Prerunner
    Working on it
    Not to sure about the tensioner. If your going to pull off your pulleys just be careful there is a rubber seal that sits ontop of your bearings. I bought a set of small screw drivers and and picks. Use the pick on the outside of the rubber seal to get it off.
  12. Nov 19, 2010 at 9:28 AM
    #32
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    it's easy to change one of the idler pulleys, just one bolt holds it on, take the old one off and put the new one on, pretty simple, i doubt it's your tennsioner, at least hope it isn't cause i hear they're a mother to change, it's more than likely one of your idler pulleys, they're pretty cheap less than $50ea from my local parts store
  13. Nov 20, 2010 at 2:08 PM
    #33
    ETaco23
    Evan
    PNW
    Well just got done changing my Belt. what a pain! all my pulleys are good, and it was just the belt. :)
  14. Nov 20, 2010 at 3:58 PM
    #34
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Good to hear. That's usually the problem.:)
