Ordered FJ Cruiser wheels, need opinions on tires...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chronism, Nov 15, 2010.
  1. Nov 15, 2010 at 4:06 PM
    Chronism
    Chronism [OP] Well-Known Member
    Michael
    Richmond, Virginia
    2011 Tacoma TRD OR/DC
    Finally settle on a wheel, silver FJ Cruiser's. First off, my Tacoma only has 2000 miles on it, so the tires have plenty of life left. The stock tires are 265/70/R16. My options are:
    Just swap the original tires over w/ TPMS'.
    Or
    Order new tires, a little larger 265/75/R16, and probably a little more aggressive BFG AT's.
    Is it worth the 1/2" increase in height and more aggressive look to buy new tires? Will I see much of a difference in tires size on the truck?
    I know, ultimately, it is what I want, but I am curious what others would do. Common sense says save $650 and wait until I NEED new tires...
  2. Nov 15, 2010 at 4:08 PM
    Lost_Humanity
    Lost_Humanity Bad decisions make great stories.
    Seattle
    It's a Toyota.
    Bumper Dent Mod
    You can always sell the stock wheels and tires and recoup some of the costs of the new setup.
  3. Nov 15, 2010 at 4:09 PM
    Chronism
    Michael
    Richmond, Virginia
    True. I'd be curious to see what the silver FJ's look like with 265/75/R16 BFG AT's on a stock suspension. Off to utilize the search function...
  4. Nov 15, 2010 at 4:15 PM
    Palmetto Pete
    Palmetto Pete Well-Known Member
    Pete
    In the Mountains
    2012 SSM TRD Sport DCSB 4x4
    3M Paint Pro Film, OEM Bed Mat, Antenna X, WeatherTech Floor Mats, Foglight Anytime Mod, 8000k HIDs, BFG AT/KOs (265/70/17), Debadged, Ultra-Gauge, Leer 100XR
    i have silver fjs with 265/75/16 Goodyear Wrangler Duratracs on stock suspension. I love my set-up, glad I made the upgrades.
  5. Nov 15, 2010 at 4:37 PM
    Chronism
    Michael
    Richmond, Virginia
    Thanks for the pic Pete.
    Was just looking on Tire Rack and the 265/70/R16 BFG AT's are more expensive than the larger 265/75/R16??
  6. Nov 15, 2010 at 5:01 PM
    Palmetto Pete
    Pete
    In the Mountains
    Do they have a different load rating?
  7. Nov 15, 2010 at 5:13 PM
    Chronism
    Michael
    Richmond, Virginia
    Yes, the 265/70 has a "D" rating and the 265/75 has an "E" rating which confuses me more, isn't "D" 65psi and "E" 80 psi max?
  8. Nov 15, 2010 at 5:21 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    usually the E ratings mean more plys are in the tire.
    thus the tires are heavier and require more psi.
    usually if you have a heavy vehicle or tow heavy items.
    E rated are not needed on our trucks, they are not that heavy
    or can tow really heavy items.
    Recommend you look at the Goodyear Duratrac's, C rated.
  9. Nov 15, 2010 at 5:51 PM
    Chronism
    Michael
    Richmond, Virginia
    Yeah but what confused me is that the lighter load rated tire (and larger) actually cheaper.
    I'll look into the Duratracs, what size in those would you recommend with a stock TRD OR supsension?
  10. Nov 15, 2010 at 5:55 PM
    The End
    The End Support our troops!
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    265/75's for stock. Duratrac, Toyo A/T and the Nitto are all great tires, the BFGs are good but they are proud of them, they're not cheap.
  11. Nov 15, 2010 at 6:02 PM
    skistoy
    Western New York
    above, pete has a great pic of the 265/75 Duratracs on a stock truck.
    my truck has the rear TSB and billy's @ .85, or otherwords, about 1 inch of lift.
  12. Nov 15, 2010 at 6:02 PM
    Chronism
    Michael
    Richmond, Virginia
    I think I may be sold. Any issues balancing them with stickies instead of rim weights on the outside? I don't want any stinking weights showing on my wheels...
  13. Nov 15, 2010 at 6:03 PM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
  14. Nov 15, 2010 at 6:05 PM
    skistoy
    Western New York
    Unsure about the stickys
    I would only use what works best for the wheel / tires
  15. Nov 15, 2010 at 6:06 PM
    rcote99
    rcote99 Member
    Rhode Island
    2003 Tacoma TRD Off-Road 4x4 (Impulse Pearl Red)
    Hey I am looking to upgrade my tires in the near future too. I've done a lot of research the last couple of days and found that Kumho Road Venture SAT KL61's got the best write ups. Their aggressive, good looking tires but not crazy aggressive like bfg mud terrains. Plus they fit stock sizes for trd's so try looking into them, they got em on tire rack!
  16. Nov 15, 2010 at 6:18 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Another vote for Duratracs here.
  17. Nov 15, 2010 at 6:40 PM
    Lunercrab
    Lunercrab Well-Known Member
    Beth
    Lehigh Valley area, PA
    2019 off road cement
    I vote for duratracs here also
  18. Nov 15, 2010 at 6:42 PM
    Chronism
    Michael
    Richmond, Virginia
    I appreciate all of the responses. The more I read other threads about the Duratracs, the more undecided I get.. I read some bad things about wear. To be honest, I don't do a lot of off roading and do drive many highway miles every day.
  19. Nov 15, 2010 at 6:49 PM
    bevans
    bevans Well-Known Member
    GA
    If you like the BFG a/ts, check out the general grabber at2. The at2's tread pattern look identical to the bfg's. Also the generals have a 60k mile warranty and cost about $70 less per tire.
    I just got mine today and love them.
  20. Nov 15, 2010 at 7:42 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    I had BFG' A/T's on my 1st gen... When I sold it, they had 80k miles and plenty of life left. No balancing/wear issues. Great traction on snow and quiet throughout thier life. Just thought I would give you my personal experience... Good luck with your decision.
