AWESOME off the line throttle response
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dark Knight, Aug 8, 2008.
  1. Aug 8, 2008 at 7:12 AM
    Dark Knight
    Dark Knight [OP] Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    My first reactions to the new Airaid Poweraid Throttle Body Spacer is wow! The torque increase is amazing from a stop to about 3000 RPM and Airaid claims up to 4mpg better mileage. I received this yesterday at work and was jumping out of my seat wanting to go home and install it. I decided to do a write up on the install process and tell you guys a bit about it. This install was a bit easier since i had the TRD CAI.
    This is what you start out with.
    Start by removing the negative battery cable, this allows time for your computer to reset while doing the install. Remove the two 10mm bolts from the top of the engine cover, take it off and set aside.
    Now remove the MAF sensor wire harness by squeezing down on the clip and pulling back. Also remove the valve cover breather hose on the front of the intake tube. You wont need to remove the long vacuum hose. Now you can unscrew the (4) hose clamps that hold the intake tube in place.
    Place the intake tube back next to the fire wall. Unbolt (4) bolts on the throttle body and place the bolts somewhere out of the way. Place the Poweraid spacer between the throttle body and intake manifold there will be a "TB Side" marked on the spacer this side goes toward the, you guessed it, Throttle Body Side along with the supplied gasket.
    Reinstall the (4) new bolts and washers that were supplied. Be careful not to over tighten, its only brass fittings in there!
    Now reinstall the intake tube, tighten hose clamps and reinstall MAF sensor into its connection and the valve cover breather hose. The Airaid instructions now go on to say reinstall the engine cover, i decided to leave it off, I like looking at all the engine parts. Now reinstall the negative battery cable and your ready to feel the benefits. this is the finished product with no engine cover.
    The Verdict: This is a great addition. Throttle response is amazing and fuel economy should increase, just haven't gotten to drive long distance yet, but the actual science behind what this does for your intake and air mixture makes complete sense.
    This is where you can get one: http://performanceparts.com/part.php?partID=449683
  2. Aug 8, 2008 at 9:00 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    hmmmm... I got one of those a couple years ago thinking it would help. I certainly didn't get the 4mpg increase as I never even got the EPA estimates until they lowered them. :rolleyes: I didn't get any improvement until I swapped to an AFE Pro Dry filter. Suppose I should take the TBS off sometime and see if there's a difference! :laugh: It's been on 2 years now, long before the truck was broken in so I have no idea if it really does anything. Just been too lazy to take it off to compare. :laugh:
  3. Aug 8, 2008 at 9:17 AM
    Dark Knight
    Jeff
    NC/SC
    Yes the 4mpg increase is a high end guesstimate that Airaid says is a possibility of getting up to..... I do have the CAI and Exhaust helping me get great throttle response and hopefully better MPG's
  4. Aug 8, 2008 at 10:39 AM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    what exactly does the TB spacer do? Im sure i could look it up but figured one of you guys would have a simple answer.
  5. Aug 8, 2008 at 10:55 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    The general consensus is that they do nothing.
  6. Aug 8, 2008 at 11:05 AM
    Dark Knight
    Jeff
    NC/SC
    Airaid does not promise any HP gain or definite MPG gain. here is their direct quote
    "The benefits you will see are tremendous torque gains between 800 to 2500 RPM, and potential increases in your fuel economy, depending on driving conditions."
  7. Aug 8, 2008 at 11:08 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    If it isn't proven on a dyno by them then they're full of crap. If it really gave "tremendous torque gains" I'm sure they'll want to prove it.
  8. Aug 8, 2008 at 11:09 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    No dyno = no proof.
  9. Aug 8, 2008 at 11:11 AM
    klown
    klown Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    Hmm this is the first thread I've read that has a positive review of TBS's.
    I have yet to see anybody explain the physics to me on why this would improve anything.
    Anybody got any dyno charts with and without a TBS? What about 0-60 and 1/4 mile times with and without one of these?
  10. Aug 8, 2008 at 11:15 AM
    Wood
    Wood Well-Known Member
    Hmmm, I saw one these gizmos at the local auto parts store....I can't remember which aisle it was in...oh wait now, I think it was in the 'Snake Oil' aisle.:p
  11. Aug 8, 2008 at 11:15 AM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^Good luck with that. Over the years in all the forums I've been a member of I've never once seen hard (independent) proof. Waste of money, IMO.
  12. Aug 8, 2008 at 11:21 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Torque is a number- and fuel economy is MPG gains- You got hosed for 120 bucks...and it sounds like you should get your butt dyno calibrated.:rolleyes:
  13. Aug 8, 2008 at 11:25 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    OK, I think everyone gets it...let's play nice and move on.
    The bottom line here is that it is Friday and I don't have to come to work tomorrow or the next day.
  14. Aug 8, 2008 at 3:30 PM
    gdawg25
    gdawg25 Zoom-Zoom
    Victoria, BC
    '08 Mazdaspeed 3
    They would make a good paper weight! Or even better...a beer holder.
  15. Aug 8, 2008 at 3:32 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    or u can use it as a weapon when u catch crack heads stealing ur cats!
  16. Aug 8, 2008 at 6:11 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    That's too much effort. I prefer to just shoot them (hey, why have a concealed carry permit then?).
    :p
    Bottom line here is, like I said, I've never seen hard evidence that these things do anything. BUT, if the OP is happy with his mod, that's all that matters to him.
  17. Aug 8, 2008 at 6:26 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    How very diplomatic of you. I would have to agree.
  18. Aug 8, 2008 at 6:59 PM
    piercedtiger
    Jon
    Southern Tier, NY
    :laugh: It doesn't help that people like me (who bought one before really reading a lot about them) are too lazy to do back-to-back tests to see if there's a difference. Maybe I should actually get around to doing that sometime....
  19. Aug 8, 2008 at 7:39 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
  20. Aug 8, 2008 at 8:09 PM
    grantfire319
    grantfire319 Well-Known Member
    KENTUCKY
    05 DOUBLE CAB TRD SPORT 4.OL
    Secondary Air Filter removal. More to come hopefully.
    It allows the fuel more time to atomize, allows the air to cool off somewhat before coming into the engine. It doesn't do much for madern FI engines or dry intake engines. Only TBI and carburated engines see a difference
