Changed oil - TOO FULL?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Krusey1011, Dec 6, 2010.
  1. Dec 6, 2010 at 5:18 PM
    Krusey1011
    Krusey1011 [OP] Well-Known Member
    Kyle
    Washington
    So, I've changed my oil myself on my 07' Taco (1GR-FE) all but two times. (the other two times I took it in because I was lazy). I'm at 45,000 miles now. This is my 7th time changing my own oil on this truck. I change it every 5,000 miles. It's easy now, and it was easy the first time.
    I'm saying this because I know how to change my own oil. It's easy! Which is why I don't understand why I'm having trouble.
    Here's what's happening -
    I took off my old oil filter, the oil fill cap, and the drain plug. I gave it pleanty of time to drain because I went inside the house and ate. About 25 minutes later I put the plug back in, added the new filter, added 5.5 qts of royal purple, and capped it off. Ran the truck up for a bit. let it sit for a few minutes and checked the dip stick. WAY TO FULL!
    So I let the truck sit for about an hour and checked it again thinking it would go down. Nope, still too full.
    Is it possible that the oil could have not drained out completely? I don't know what else it could be. I re-checked that I had put in the correct amount several times and also had the gf verify I wasn't being an idiot.(which makes me feel like an idiot because I'm . . . changing my oil)
    The only difference this time is I switched from mobile 1 (which I had been using since my first oil change) to royal purple. I change it every 5,000 miles not going over.
    The truck was on a slight incline. Nothing extreme at all. I wouldn't even notice the incline if my oil level hadn't read so full. I'm just looking for anything.
    My oil was changed by sears last time. I always bring my own oil and filter since I don't like their brand. maybe the guy swiped my oil and put generic oil in. You can't go back to generic oil after changing to full synthetic. Maybe they ripped me off and it created some sludge? Lol I'm just looking at everything now. I'm clueless as to why Their's too much oil in my engine.
    Any thought's TW?
  2. Dec 6, 2010 at 5:24 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    its probably good, the dipstick on these things are garbage and impossible to get a good reading. Id say you're good. Drive on my friend.
  3. Dec 6, 2010 at 5:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    As long as 5.5 quarts are put in, you should be fine. THe stick is not precise. Also, you can go from Synthetic oil, to dino oil with no ill affects.
  4. Dec 6, 2010 at 5:25 PM
    jandrews
    '09 FourDubDee TRD OR
    The dipstick is shit. If it drained to a drip and you put in 5.5 Qts, you're fine.
    I usually change my oil with about 5.25 Qts just to account for what would take hours to drip out making up the difference. Better to be slightly underfilled than overfilled.
  5. Dec 6, 2010 at 5:27 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    You'll be fine. 5.5 quarts is 5.5 quarts no matter what the dipstick says.
  6. Dec 6, 2010 at 5:29 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    Roughing up the end of the dipstick with sand paper helps but it's still crap.
  7. Dec 6, 2010 at 5:42 PM
    Krusey1011
    Kyle
    Washington
    Yeah, I've read the dipstick in the Taco is junk. But I've never had a reading like this. It's way over! I also figured the same thing. 5.5 qts is 5.5 qts. After driving down the road shortly my truck started to shift at strange rpms.
    Oh yeah, truck was in 4wd at the time of the oil change but I figured no big deal. I don't see how that would be a problem.
    I don't know maybe I'll just drain and re-fill but at 8.99 a qt it's a little pricey.
    Damn! An oil change and I'm having problems. I'm starting to feel like the bad dip stick:p
  8. Dec 6, 2010 at 5:48 PM
    canadiancon
    canadiancon Member
    Tom
    Whistler, Canada
    05 trd
    Stock
    Did you run the truck after you filled it?
  9. Dec 6, 2010 at 5:52 PM
    Krusey1011
    Kyle
    Washington
    Oh yeah. . . I'm stumped as to how this happens
  10. Dec 6, 2010 at 5:55 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    did you drain the transmission? was the fluid red?
    Did it look like this
    or this
    Pictures from mr4x4
  11. Dec 6, 2010 at 5:56 PM
    jandrews
    The dipstick smears on the side of its sleeve as you draw it out. It pushes oil everywhere. Also, if you had just driven the truck, it's entirely possible the oil splashed around further farting up the reading.
    Give it a couple days. Nothing's wrong with your truck. Royal Purple is great oil.
    Just settle down, go inside, eat a sammich, and proceed with your life as normal.
  12. Dec 6, 2010 at 6:01 PM
    ppham444
    Phuong
    Portland, OR
    FIXED....
  13. Dec 6, 2010 at 6:02 PM
    jandrews
    I told him to eat a sammich. There was no discussion of the preparation method. Not fixing, just clarifying ;)
  14. Dec 6, 2010 at 6:07 PM
    xroller
    xroller Blowin by em sideways
    Ramon
    Albuquerque New Mexico
    2006 Toyota Tacoma Xrunner Speedway Blue
    1 hp mod
    I have a feeling.... :tacodead:
  15. Dec 6, 2010 at 6:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Quoted for TRUTH!
  16. Dec 6, 2010 at 6:10 PM
    JKD
    JKD Well-Known Member
    Welcome to I-drained-my-transmission-ville, population YOU.
  17. Dec 6, 2010 at 6:12 PM
    Krusey1011
    Kyle
    Washington
    Thanks ktmrider i like to think I'm not that slow. Though I have seen it done on here before. Idk I tend to think oil changes are pretty easy but I'm going to take a little precaution on this and check how much oil was drained into my oil pan and if its 5.5 qts or so. then I'll just drain a little out of the truck. IDK, maybe I blacked out and put an extra qt in their. After that. . . Then I'll eat a sammich:D
  18. Dec 6, 2010 at 6:15 PM
    ktmrider
    Junk
    I know you said you had done it before, but in the next post you had you stated it was shifting funny so I just had to ask:)
  19. Dec 6, 2010 at 6:16 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    You touched on my guess. . . . was the truck on an incline/decline when you drained it.
  20. Dec 6, 2010 at 6:24 PM
    xroller
    Ramon
    1 hp mod
    Do us all a favor and check your transmission oil...... if it's really THAT full.... something doesn't seem right because first off... you used royal purple.... that alone is a lot easier to read on a dipstick..... let alone it being the first time you used it..... it should read fairly accurately with a light purple tint......
    When you say it's WAY over.... how much? 1" over fill line? 1/2"?
