2005. Misfire?
Old 12-22-2010, 10:57 PM   #1
Hiatt1991 [OP] Hiatt1991 is offline
Hiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shedHiatt1991 is one of the sharper tools in the shed
Hiatt1991's Avatar
Hiatt1991's Tacoma Gallery
Send a message via MSN to Hiatt1991
2005. Misfire?
Today I was driving my Tacoma and it started jerking pretty bad. I don't know if it was missing or what but I felt the jerking. Do you know what it could be? I recently changed the spark plugs and found out that the previous owner ruined 2 bolts that hold the part that connects the wire to the plug although it seems to be held in place ok?
Old 12-23-2010, 12:31 AM   #2
He who angers you conquers you
Unknown is one of the sharper tools in the shedUnknown is one of the sharper tools in the shedUnknown is one of the sharper tools in the shedUnknown is one of the sharper tools in the shedUnknown is one of the sharper tools in the shedUnknown is one of the sharper tools in the shedUnknown is one of the sharper tools in the shedUnknown is one of the sharper tools in the shedUnknown is one of the sharper tools in the shedUnknown is one of the sharper tools in the shedUnknown is one of the sharper tools in the shed
Unknown's Avatar
Unknown's Tacoma Gallery
Do you have an aftermarket air filter?
Old 12-23-2010, 01:19 PM   #3
Hiatt1991's Avatar
Originally Posted by wolfpack_5150 View Post
If the other owner ruined 2 bolts (meaning threads) to a coilpack....then that could be a huge problem.
Sometimes even a hairline crack can spell disaster in rain, or after a wash....
My friends expedition, and another friends 300zx tt were both suseptable and had the same chugging, but threw codes
After doing a lot of searching, I couldnt find any cracks. One hole is stripped in the engine block and the other hole is fine its just the bolt head came off and I have to way to get it out. I tried an extracter but I got no luck. Also, I was told that a hielcoil would be good for the stripped hole on the block? im not sure
Old 12-23-2010, 01:20 PM   #4
Hiatt1991's Avatar
oh and I cleaned the MAF and the airfilter is clean as well. It all started when I changed the plugs and noticed the problem.
Old 12-24-2010, 06:29 AM   #5
buddywh1 is one of the sharper tools in the shedbuddywh1 is one of the sharper tools in the shedbuddywh1 is one of the sharper tools in the shedbuddywh1 is one of the sharper tools in the shedbuddywh1 is one of the sharper tools in the shedbuddywh1 is one of the sharper tools in the shedbuddywh1 is one of the sharper tools in the shedbuddywh1 is one of the sharper tools in the shedbuddywh1 is one of the sharper tools in the shedbuddywh1 is one of the sharper tools in the shedbuddywh1 is one of the sharper tools in the shed
Air Force: 2nd Bomb Wing
buddywh1's Tacoma Gallery
Are these these for the bolts that hold the coil packs down? If so, they aren't threaded into the block but into the valve covers. I think a helicoil would work just fine, just don't torque 'em down so tight in the future. They don't really need it and it sounds like PO did just that.
Old 12-24-2010, 11:33 PM   #6
Hiatt1991's Avatar
Ya I noticed you are right. I realize that I can either get helicoils or new valve covers. A set of valve covers is about 500 but Im not sure about the helicoils or if they are durable. Can anyone vouche for that?
Old 12-24-2010, 11:38 PM   #7
"That's what she said..."
Hondarider08 is just really niceHondarider08 is just really niceHondarider08 is just really niceHondarider08 is just really nice
Hondarider08's Avatar
Air Force: Currently ROTC, future fighter pilot.
Hondarider08's Tacoma Gallery
Helicoils are just about as durable as regular threads in my opinion. I've used them in some pretty serious motor applications on motorcycles and they held up really well. This is if you do them correctly, that is.
Old 12-25-2010, 07:43 AM   #8
... Im not sure about the helicoils or if they are durable. Can anyone vouche for that?
Just to add to that.... My company installed helicoils in a cast aluminum housing for line mounted CATV amplifiers. They put the helicoils in because tech's had to get inside them twice a year to adjust the gains of the amps and they had to pull-up the housing really tight for weather seal as well as RFI. Just threading into the aluminum would not have held up under that useage and give 10 years service.
For this application where the bolt isn't taking any load worth mentioning, helicoils will last far longer than the original aluminum threads. Just be sure to install them carefully: use a bottoming tap and coil of right length.
misfire help MrMackey89 2nd Gen. Tacomas 0 11-02-2011 04:58 PM
2005 1st cylinder misfire LjHarp 2nd Gen. Tacomas 9 06-06-2011 08:34 AM
bumming with misfire gofas 1st Gen. Tacomas 1 05-22-2011 06:42 AM
misfire and overheating mcight Technical Chat 1 10-09-2010 11:24 AM
Misfire toyotadan 1st Gen. Tacomas 5 07-10-2010 12:13 AM
