front differential side bearing replacement.. done!
Old 01-25-2011, 04:10 PM   #21
AK27 is one of the sharper tools in the shedAK27 is one of the sharper tools in the shedAK27 is one of the sharper tools in the shedAK27 is one of the sharper tools in the shedAK27 is one of the sharper tools in the shedAK27 is one of the sharper tools in the shedAK27 is one of the sharper tools in the shedAK27 is one of the sharper tools in the shedAK27 is one of the sharper tools in the shedAK27 is one of the sharper tools in the shedAK27 is one of the sharper tools in the shed
AK27's Avatar
AK27's Tacoma Gallery
Originally Posted by wiscdave View Post
Yeah and why would it not just fail again if you used the same part?? Pics of the destroyed bearing in question would be great....and put all these rumors to rest.
Total BS
my old bearing wasnt 'destroyed'. it just had no lubricant left in it
Old 01-25-2011, 04:17 PM   #22
tacos is on a distinguished road
tacos's Avatar
tacos's Tacoma Gallery
Old 01-25-2011, 04:18 PM   #23
AK27's Avatar
Originally Posted by tacos View Post
sorry i didnt get a pic of it.
Old 01-25-2011, 04:35 PM   #24
KColoTaco will become famous soon enough
KColoTaco's Avatar
KColoTaco's Tacoma Gallery
Send a message via AIM to KColoTaco
Where did you get your CV shaft from?
Old 01-25-2011, 07:01 PM   #25
meafordmike is one of the sharper tools in the shedmeafordmike is one of the sharper tools in the shedmeafordmike is one of the sharper tools in the shedmeafordmike is one of the sharper tools in the shedmeafordmike is one of the sharper tools in the shedmeafordmike is one of the sharper tools in the shedmeafordmike is one of the sharper tools in the shedmeafordmike is one of the sharper tools in the shedmeafordmike is one of the sharper tools in the shedmeafordmike is one of the sharper tools in the shedmeafordmike is one of the sharper tools in the shed
meafordmike's Avatar
Army: RCR( Royal Canadian Regiment) INF
meafordmike's Tacoma Gallery
I also replaced my driver side Diff seal, I have a few photo's somewhere. Took a few of us about 4 hours, I maybe should of replaced my axle because the seal replacement didn't fix my growl. It stopped my leaking diff, I have since had my diff replaced.
Old 01-26-2011, 05:41 PM   #26
bigmooze is one of the sharper tools in the shedbigmooze is one of the sharper tools in the shedbigmooze is one of the sharper tools in the shedbigmooze is one of the sharper tools in the shedbigmooze is one of the sharper tools in the shedbigmooze is one of the sharper tools in the shedbigmooze is one of the sharper tools in the shedbigmooze is one of the sharper tools in the shedbigmooze is one of the sharper tools in the shedbigmooze is one of the sharper tools in the shedbigmooze is one of the sharper tools in the shed
bigmooze's Avatar
bigmooze's Tacoma Gallery
Mike, did your leaky seal ever cause a drip to form?
Old 01-26-2011, 06:04 PM   #27
BenWA is one of the sharper tools in the shedBenWA is one of the sharper tools in the shedBenWA is one of the sharper tools in the shedBenWA is one of the sharper tools in the shedBenWA is one of the sharper tools in the shedBenWA is one of the sharper tools in the shedBenWA is one of the sharper tools in the shedBenWA is one of the sharper tools in the shedBenWA is one of the sharper tools in the shedBenWA is one of the sharper tools in the shedBenWA is one of the sharper tools in the shed
BenWA's Avatar
BenWA's Tacoma Gallery
So is the verdict that the OP was just yanking our chains? I haven't been keeping up on all the front diff vibe threads, but everything I have read up to this point suggests that such a bearing replacement is not possible unless you take the diff off the truck and crack it open.
Old 01-26-2011, 06:10 PM   #28
BenWA's Avatar
Total BS
Even if it does fail again, if it meant that I could run my lift at a higher setting I'd be all for a 5 hour DIY job that involves a $50 replacement bearing and a borrowed puller from autozone, even if I have to do the procedure twice a year.
Old 01-26-2011, 06:18 PM   #29
Sorry, I just re-read the original post, and now realised he said Diff Bearing and not diff seal.
I have not, and I don't think itís possible to replace the side bearing without removing the whole diff.
I looked at a diagram somewhere and determined it impossible to get the bearing out of the axle shaft opening.
I may be wrong about it being possible!
I have only changed my Side bearing Seal.
Old 01-26-2011, 06:20 PM   #30
No, it was just wet.
Old 01-26-2011, 06:23 PM   #32
BenWA's Avatar
C'mon Metallikatz3, I see you lurking in the thread...... spill the details bro!
Old 01-26-2011, 06:27 PM   #33
Metallikatz3 is a splendid one to beholdMetallikatz3 is a splendid one to beholdMetallikatz3 is a splendid one to beholdMetallikatz3 is a splendid one to beholdMetallikatz3 is a splendid one to beholdMetallikatz3 is a splendid one to beholdMetallikatz3 is a splendid one to behold
Metallikatz3's Tacoma Gallery
Sorry guys. I've just been really busy with work for the past month basically. I'm still alive and the fix is still holding up.
I started to take some pictures but it just got annoying while wrestling with everything. It wasn't an easy fix, I'd rate it a 7 out of 10.
Parts required are:
Needle Roller Bearing - 90364-35010 $11.31
Oil Seal - 90311-47012 $7.56
Cardone CV Shaft - 665235 $44.79
Its very straight foreward though. Here's the basic steps I took.
1. Jack up truck and remove the wheel.
2. Take off the caliper and rotor (more room to wrestle with the CV shaft)
3. Remove the dust cap over the axle nut
4. Remove wheel nut (I had to use an impact gun, I could not even budge it with a 3ft breaker bar)
5. Separate the upper ball joint and steering tie rod to pull the spindle out far enough to get the cv off.
6. pry out the cv from the diff. (Oil will leak from diff at this point)
7. Remove cv shaft from truck and set aside
8. Pry out oil seal from diff
9. Use slide hammer to pull out bearing (pain in the ass)
10. Install new bearing (I put mine in the freezer for a while)
11. Install new oil seal
12. Wrestle new CV shaft into place
13. Bolt everything back in and torque it down.
I know these are very general steps, and they may not be correct per the FSM (which says to remove the diff anyway) But they worked for me.
Old 01-26-2011, 06:31 PM   #34
BenWA's Avatar
Parts required are:
If you are serious about this (which it sounds to me like you are), then I'm going to mail you a case of your favorite beer if I can successfully do this fix.
Old 01-26-2011, 06:36 PM   #35
I'm dead serious about this.
My old bearing didn't visibly look damaged, although several of the needles did fall loose while removing it (I did count them to make sure none dropped into the diff) There were also some grooves on the CV shaft, not deep but I didn't feel comfortable re-using it considering the work involved removing it.
Old 01-26-2011, 06:52 PM   #36
BenWA's Avatar
Dammmm, I wish there were pics.
If someone made a video of this procedure and charged $100 for it, I would buy it in a heartbeat.
Old 01-26-2011, 07:03 PM   #37
So you'd pay $100 for a lot of cursing and busted knuckles??
This was by no means easy, but still much easier then dropping the differential
Old 01-26-2011, 08:07 PM   #38
ETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shed
ETaco23's Avatar
ETaco23's Tacoma Gallery
I had the dealer replace my bearing but my noise is still there.... So the next thing they want to try would be wheel bearings. But they havent changed my CV axle.. Do you guys think I should replace the cv?
Old 01-26-2011, 08:22 PM   #39
BenWA's Avatar
If they are footing the bill under warranty, then why not?
Old 01-26-2011, 08:33 PM   #40
Middle-Aged Member
05Moose is one of the sharper tools in the shed05Moose is one of the sharper tools in the shed05Moose is one of the sharper tools in the shed05Moose is one of the sharper tools in the shed05Moose is one of the sharper tools in the shed05Moose is one of the sharper tools in the shed05Moose is one of the sharper tools in the shed05Moose is one of the sharper tools in the shed05Moose is one of the sharper tools in the shed05Moose is one of the sharper tools in the shed05Moose is one of the sharper tools in the shed
05Moose's Avatar
05Moose's Tacoma Gallery
I think we should automatically be changing the CV axle if we're changing the bearing. With my diff drop uninstalled and the new diff, I can feel the vibe. I'm thinking it's due to the wear that was probably on the CV axle and the techs just swapped the diff without ever looking at it. I'll probably put the diff drop back in to take the pressure off the bearing again.
So my opinion is that if you have wear marks on the CV axle (whether they're measurable or not), it makes sense to me that it could then cause more wear/strain on the bearing (and continue the vibe). After all, the bad needle bearing has to be scoring the CV axle (and we've seen that from the pics in the other thread). I would think it would score it in an even fashion, but that's not necessarily the case when looking at the pics. The safe bet is then to replace it while you've got it all apart anyway and not risk the scored axle putting any strain on the new bearing.
Front wheel bearing replacement fireftrjef 2nd Gen. Tacomas 134 12-22-2012 03:07 PM
front diff bearing replacement Silver_Taco 2nd Gen. Tacomas 54 07-14-2012 09:27 PM
Front differential bearing, need everyones help. brian 2nd Gen. Tacomas 36 12-13-2011 08:20 AM
Front Differential Bearing Failure dingchavez24 2nd Gen. Tacomas 7 08-26-2009 01:22 PM
