Check LCA bolts! Clunk fixed!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trd09, Jan 4, 2011.
  1. Jan 4, 2011 at 8:16 PM
    trd09
    trd09 [OP] Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    2009 Taco, 29,000 miles. Noticed a clunk from the drivers side when reversing and turning and also doing certain maneuvers which would load/unload the front end.
    Best way to describe the "clunk" was a pop, almost as if the 4wd was binded and you would disengage it. Felt the same way too.
    Did a search on TW. Found a thread where the OP had the same problem and his lower control arm bolts were lose and thus caused the clunk.
    I thought a cv issue at first, but low and behold, I grabbed the breaker bar and went at it. Yes, they were loose, and after tightening them up (tq to 100ft/lbs), clunk is gone and the front end feels tighter. WIN!
    See attached img.
    Check yours out!
  2. Jan 4, 2011 at 8:17 PM
    Its_Taco_Time
    Its_Taco_Time Well-Known Member
    Yorba Linda
    07 Tunda DC TRD Offroad
    CST spindles, Magnaflow, TRD intake
    Nice find! I'm gonna try this. I have that annoying clunk too
  3. Jan 4, 2011 at 8:21 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Very cool! Do you recall what size socket?
  4. Jan 4, 2011 at 8:22 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    Good job! :thumbsup:
  5. Jan 4, 2011 at 8:27 PM
    trd09
    Chuck
    NW Ark
    17 TRD Pro 6AT
    19
  6. Jan 4, 2011 at 8:29 PM
    ColtsTRD
    Scott
    AZ
    cool thanks...i'll check mine in the morning :)
  7. Jan 4, 2011 at 8:32 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Ive got the clunk too, but can we do this without messing with the alignment cams, or do we tighten from the inside?
    The Internt likes this.
  8. Jan 4, 2011 at 9:00 PM
    trd09
    Chuck
    NW Ark
    17 TRD Pro 6AT
    I thought the same but when I tightened it I watched for cam movement and they didn't.....
  9. Jan 4, 2011 at 9:10 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    If they were clunking maybe they are already off? You might want to have your alignment re-checked just to be safe?
  10. Aug 29, 2019 at 3:22 PM
    tacoma2g
    tacoma2g Well-Known Member
    Midwest Ohio
    2015 DCSB
    Bringing this post back from the dead... tightening my LCA bolts on the passenger side worked for me. Thank you Search Function.
    nd4spdbh likes this.
  11. Aug 29, 2019 at 5:53 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    You're welcome!
    tacoma2g likes this.
  12. Mar 16, 2020 at 4:18 PM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    I just got my truck inspected today and the note on my receipt reads "Lower control arms appear to have play - monitor, suggest suspension check". Frankly, I"m surprised they didn't check the bolts or even mention it when I picked it up.
    I recently installed bilstein 5100s with 2" HS coils, replacing the stock. I also replaced the wheel bearing assemblies and my truck has never sounded better. I don't hear a clunk or anything out of the ordinary at this point. So I guess for my next steps I'm going to re-torque touched on the suspension and check the front lower arm bolts in the process. I'll also try a 12/6 tug on the wheels (bearings check) and 3/9 tugs (LCA check) to see if I get any play. Is there anything I'm missing? THANKS!
