Installed Sittin Sic Sway Bar on my Reg Cab...FINALLY!
Old 01-07-2011, 10:15 AM   #1
parting out...
speckdzl4shzl is on a distinguished road
speckdzl4shzl's Tacoma Gallery
As for a review, well I haven't got to push it like I wanted to last night, too much traffic, but the rear feels less squirrely then before, follows me into and out of turns. Shit I noticed the difference just pulling out of my garage and parking my truck in the street! Unfortunately having this on really shows how crappy the rest of our suspension really is, ESPECIALLY Bilstein shocks...terrible.
anyways onwards with the pics.
everything needed, minus a few U-bolts from ACE and bolts for the brackets.
rivet that was removed, on each side (this look the longest, minus my wait to install them )
you can see the two sides here maybe a little clearer where they are for you noobs that haven't been under your trucks before. Note my X-brace (to be painted Red to match the sways)
Brackets mounted. holes in the frame and the bracket are drilled out to 1/2". bolts are 1/2" x 1.5". used washers are each side a nylon lock nuts. Torqued down to specs of my back and bi's (don't want them going anywhere!)
U-bolts on the axle
complete end links
and a shot of it all, the red is pure sex under there, it's so clean!
Old 01-07-2011, 01:03 PM   #2
Science!
AndrewFalk is one of the sharper tools in the shedAndrewFalk is one of the sharper tools in the shedAndrewFalk is one of the sharper tools in the shedAndrewFalk is one of the sharper tools in the shedAndrewFalk is one of the sharper tools in the shedAndrewFalk is one of the sharper tools in the shedAndrewFalk is one of the sharper tools in the shedAndrewFalk is one of the sharper tools in the shedAndrewFalk is one of the sharper tools in the shedAndrewFalk is one of the sharper tools in the shedAndrewFalk is one of the sharper tools in the shed
AndrewFalk's Avatar
AndrewFalk's Tacoma Gallery
I've had my rear sway bar on for months, and I love how the truck handles. I feel so much more confident in the corners.
Old 01-07-2011, 01:43 PM   #3
buddywh1 is one of the sharper tools in the shedbuddywh1 is one of the sharper tools in the shedbuddywh1 is one of the sharper tools in the shedbuddywh1 is one of the sharper tools in the shedbuddywh1 is one of the sharper tools in the shedbuddywh1 is one of the sharper tools in the shedbuddywh1 is one of the sharper tools in the shedbuddywh1 is one of the sharper tools in the shedbuddywh1 is one of the sharper tools in the shedbuddywh1 is one of the sharper tools in the shedbuddywh1 is one of the sharper tools in the shed
Air Force: 2nd Bomb Wing
buddywh1's Tacoma Gallery
x2...really like how it handles now. I also can appreciate how much better it is at freeway speeds....in crosswinds the pull is so greatly reduced and there's no mystery when passing semi's now. It's just a pleasure to cruise.
It lost articulation off-road as expected, but surprisingly it's a lot more confident feeling on gravel roads and loose terrain. I guess because all four wheels are in more solid contact as it sways and leans around curves. It's still perfectly suitable for my kind of off-road trekking.
I have a Hellwig sway bar...it looks pretty much the same (not red though) but the links are a LOT shorter! I'm wondering if OP has an X-Runner? or a base Taco he put the x-brace on? I also notice he has a big lowering spacer in the axle perch?
Interesting mods...
Old 01-07-2011, 02:04 PM   #4
Science!
AndrewFalk's Avatar
I'm also running a Hellwig bar...and I still have more than enough articulation to get me through the little bit of offroading that I do.
Old 01-07-2011, 02:10 PM   #5
My spoon is too Big!
xJuice is one of the sharper tools in the shedxJuice is one of the sharper tools in the shedxJuice is one of the sharper tools in the shedxJuice is one of the sharper tools in the shedxJuice is one of the sharper tools in the shedxJuice is one of the sharper tools in the shedxJuice is one of the sharper tools in the shedxJuice is one of the sharper tools in the shedxJuice is one of the sharper tools in the shedxJuice is one of the sharper tools in the shedxJuice is one of the sharper tools in the shed
xJuice's Avatar
xJuice's Tacoma Gallery
OP has a reg cab, so it must be a base 5 lug.
Old 01-07-2011, 06:52 PM   #6
parting out...
Interesting mods...
have a "reg" cab
Old 01-16-2013, 05:09 PM   #8
TwzteD is a name known to allTwzteD is a name known to allTwzteD is a name known to allTwzteD is a name known to allTwzteD is a name known to allTwzteD is a name known to all
TwzteD's Avatar
TwzteD's Tacoma Gallery
U-bolts on the axle
complete end links
If i were you i would not leave you exhaust like that, keeping it that way will heat up the axle housing and cause premature failure of the parts inside.
Old 01-17-2013, 11:27 AM   #9
parting out...
lol nahh never had an issue. besides, it's a 4 banger not an LS motor
Old 01-17-2013, 11:36 AM   #10
parting out...
Originally Posted by jmarquez808 View Post
Im about to do this mod stoked!!!! Xii performance pointed me to ur thread. Could you tell me where u got the brackets and stuff needed. I dont know any part numbers. Thanks man
They're good people. I have everything you need besides the sways. responded to your PM.
Old 01-17-2013, 03:23 PM   #12
Dafuq
Who Dat Popcorn is one of the sharper tools in the shedWho Dat Popcorn is one of the sharper tools in the shedWho Dat Popcorn is one of the sharper tools in the shedWho Dat Popcorn is one of the sharper tools in the shedWho Dat Popcorn is one of the sharper tools in the shedWho Dat Popcorn is one of the sharper tools in the shedWho Dat Popcorn is one of the sharper tools in the shedWho Dat Popcorn is one of the sharper tools in the shedWho Dat Popcorn is one of the sharper tools in the shedWho Dat Popcorn is one of the sharper tools in the shedWho Dat Popcorn is one of the sharper tools in the shed
Who Dat Popcorn's Avatar
Who Dat Popcorn's Tacoma Gallery
You ever sell the truck?!?!
Old 01-18-2013, 09:41 AM   #13
parting out...
stoked!!! Gonna have my sway bar mounted veryyyyy soon
yea i did in May. I got a first gen scion xB and bagged that bitch actually just took the bags off tho
I'm missing the truck now for sure.
Old 01-18-2013, 12:55 PM   #14
Calmer than you are
jmg256 is one of the sharper tools in the shedjmg256 is one of the sharper tools in the shedjmg256 is one of the sharper tools in the shedjmg256 is one of the sharper tools in the shedjmg256 is one of the sharper tools in the shedjmg256 is one of the sharper tools in the shedjmg256 is one of the sharper tools in the shedjmg256 is one of the sharper tools in the shedjmg256 is one of the sharper tools in the shedjmg256 is one of the sharper tools in the shedjmg256 is one of the sharper tools in the shed
jmg256's Avatar
jmg256's Tacoma Gallery
Were you using the drive shaft as a lift point with your floor jack?
Old 01-21-2013, 01:36 PM   #15
donnison27 is on a distinguished road
donnison27's Avatar
donnison27's Tacoma Gallery
What size U-bolts did you use? I ordered the sway bar and the stock height x runner coils today. I found all the brackets and linkage already.
Old 01-21-2013, 03:13 PM   #16
parting out...
yup. it's fine.
idk tbh. i got them at ACE Hardware tho. you can use any u-bolts u want
Old 01-21-2013, 05:05 PM   #17
donnison27's Avatar
Okay, cool. Thanks
Old 01-21-2013, 06:37 PM   #18
ManMan is one of the sharper tools in the shedManMan is one of the sharper tools in the shedManMan is one of the sharper tools in the shedManMan is one of the sharper tools in the shedManMan is one of the sharper tools in the shedManMan is one of the sharper tools in the shedManMan is one of the sharper tools in the shedManMan is one of the sharper tools in the shedManMan is one of the sharper tools in the shedManMan is one of the sharper tools in the shedManMan is one of the sharper tools in the shed
ManMan's Avatar
ManMan's Tacoma Gallery
Oh man, those end-link frame attachments are SOOOOOO much better than the ADDCO bar I installed. It's not even funny!
Old 01-30-2013, 06:46 PM   #19
donnison27's Avatar
I just installed my sittin sic swaybar on my truck tonight and man what a difference. The truck is so much more stable around bends, it's a complete different animal. If anyone else is interested in this mod I highly recommend it.
For questions on the parts required this is what you'll need.
-2 3" U-bolts 3/8" (exhaust clamps work mint)
-4 M12x175 bolts and all the matching hardware (I used all lock nuts)
-Linkage from rockauto.com ($35)
-X-Runner sway bar brackets from https://www.trdparts.com/ ($50)
-12.5mm Drill bit (or 1/2")
-Black spray paint
wtb sittin sic drop for x-runner bluuge 2nd Gen Tacoma Marketplace 0 10-02-2011 01:27 PM
Sittin Sic coils. Why so Long?? F16TACO Street Trucks 17 06-05-2011 12:10 AM
WTB: X-Runner QA1's and Sittin Sic stock height coils. ryanjboutin Buy / Sell / Trade 0 04-04-2010 03:03 PM
Sittin Sic Sways info ntinhri X-Runners 12 08-18-2009 04:22 PM
Sittin Sic Sway Bar Group Buy interest!!! heylookatthatblackXRunner X-Runners 0 08-18-2009 02:59 AM
