New cheap/free mod (key lock box install)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mmadej87, Jan 14, 2011.
  1. Jan 14, 2011 at 1:49 PM
    mmadej87
    mmadej87 [OP] Mayday
    NMB, FL
    98 Xcab Prerunner
    (not sure if someone has done this before, but thought id show my idea for hiding/securing a spare key)
    well today i picked up one of those key lock boxes from work, we had ordered what we thought was one, turned out to be one box so they were just sitting around, so i thought to myself that i need a place to put my spare key, but i dont like using those magnetic key boxes that everyone sticks on to the frame
    so heres what i did:
    i took the passenger side bed compartment lid/door, drilled a couple holes and mounted the box to that:
    but since there really wasnt a flat spot on the inside, i had to bend down one of the frame ribs, which turned out to work pretty well cause it put some pressure against the box to keep the screws tight:
    since toyota gave me 3 keys, im putting the one they call the "valet" key inside this box, dont know why they call it the valet key cause it doesnt seem to disable anything within the vehicle when ran with this key..but it didnt fit to well so i snipped off the hole for the key ring:
    and it fit perfectly:
    and now i have a locked up key available if i ever need it:
  2. Jan 14, 2011 at 1:54 PM
    Richard Cranium
    Richard Cranium The lice...they hate the sugar
    Ted
    Omaha, NE
    2013 Raven FR-S
    Forever sideways and smiling :D
    Until someone steals the removable door it's attached to...
    FREE TACO'S AT THIS GUYS PLACE! :hungry:
  3. Jan 14, 2011 at 1:55 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    hahaha. yeah they can just take the lid.
    i wonder if i can find an old supra key box from work and do the same thing, somewhere else on my truck.
  4. Jan 14, 2011 at 1:56 PM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    Unfortunately
  5. Jan 14, 2011 at 1:56 PM
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    I think it's a "valet" key b/c you give it to the valet, thus keeping your house key and everything else with you.
    It's easy enough to run a copy of your home keys and pull your address of either your insurance or registration. Then mosey on over while you're still at dinner.
  6. Jan 14, 2011 at 1:58 PM
    udy2554
    udy2554 NORTHERN RED-NECK
    John
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    COOL!
  7. Jan 14, 2011 at 2:00 PM
    mmadej87
    NMB, FL
    98 Xcab Prerunner
    yea i thought of them taking the whole door, but i think this maybe be harder to get to than those magnetic boxes that everyone sticks on the frame, with no lock or anything...
    plus i rattle canned the screws on the outside, its pretty hard to see unless youre really looking for it
  8. Jan 14, 2011 at 2:03 PM
    Richard Cranium
    Ted
    Omaha, NE
    2013 Raven FR-S
    Aren't the bedside boxes removable with some work? I would've attached it to inside of the box after seeing this and thinking about it.
  9. Jan 14, 2011 at 2:06 PM
    mmadej87
    NMB, FL
    98 Xcab Prerunner
    they are, about 6 screws will take it off, ill probably switch it to be inside there, once i get the right driver to get the screws off, damn star screws
  10. Jan 14, 2011 at 2:16 PM
    sg4506
    sg4506 Member
    Andrew
    Anchorage
    '11 TRD offroad
    3" RevTek lift, Poweraid throttle body spacer, K&N Aircharger, 8000k Headlights and foglights, 2" aluminum wheel spacers
    The Valet Key will not open a locked glove box or a trunk. It's so you can put your valuables in either of those places so the valet can't take them, ever hear someone say to a valet in a movie, "I know how many pennies are in the ash tray" same principal.
    However a Tacoma has no locked glove box or trunk. Really a valet key is pointless on a Taco. It's just there for title, doesn't work any different from the regular keys.
  11. Jan 14, 2011 at 2:19 PM
    07SpeedwaySport
    07SpeedwaySport Senior MoFo'ing Member
    Fairfax, VA
    06 DCSB TRD OR--now silver
    tint.
    Valet key is supposed to start the truck and work on the door. It does NOT work on the glove box (and trunk if you drive a Camry or something)...that is the only real difference.
  12. Jan 14, 2011 at 2:36 PM
    RogueLeader
    RogueLeader Well-Known Member
    Rod
    Las Vegas, NV
    2011 Tacoma Double Cab SR5 TRD
    The valet key is used so that they can't copy the key. Since the keys are chipped, they can't get a duplicate chipped key made. They have to have either the two master keys, or the code on the key ring you got when you bought the truck. They can still get the truck, but it would have to be from their lot. You can put cabinet locks on those covers to make it very hard to just open and remove the cover.
  13. Jan 14, 2011 at 2:43 PM
    OffroadToy
    Great idea! I don't have a spare hidden but in the case I ever lock the keys inside my dealer sent me a plastic credit card key that I had to come in and have cut to my key configuration....good for emergencies.
  14. Jan 14, 2011 at 2:49 PM
    OffroadToy
