'Redneck" lower control arm - LCA Bushing Press
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBow, Jan 19, 2011.
  1. May 28, 2015 at 11:30 AM
    #61
    Nazupag524
    Nazupag524 Well-Known Member
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    Heavy ass pig sitting on 35s
    I'm getting ready to buy an energy suspension control arm bushing kit but I only need the lowers. Does anyone out there need the upper bushings?
  2. May 28, 2015 at 4:52 PM
    #62
    Burnwithin
    Burnwithin Member
    CJ
    monroe
    10 tacoma
    i had the same issue on my 2010 tacoma with 85k miles i did the bilstien 5100 and AAL 1.5 rear 1.75 in front and when went to do the alighment it was all froze up so i also used a sawzall to get the LCA off both side were siezed up. I got all new OEM parts both front bushings and rears new bolts cam gears nuts all of it and it was around 350 to 400$ but i didnt want to use aftermarket bushings sence it would have only saved me maybe 20 bucks at most i used heat and air hammer to get them lose with no luck. After I got the LCA's out I just
    set the bushing on fire let them melt and pushed the outer ring out like butter. and when i did the alignment it was cake after
    20150407_184906[1].jpg 20150407_184912[1].jpg 20150407_204808[1].jpg 20150407_204829[1].jpg
    Crom likes this.
  3. Nov 12, 2015 at 8:17 PM
    #63
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Old thread but good info!
  4. Nov 12, 2015 at 8:25 PM
    #64
    Crom
    Nick
    San Diego, CA
    Millions
  5. Nov 13, 2015 at 7:38 AM
    #65
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
  6. Nov 13, 2015 at 8:01 AM
    #66
    Crom
    Nick
    San Diego, CA
    Millions
    It looks worse than it is. It's not too much pressure. The jack is basically acting like a stopper. When heat is applied, the bushing expands and only has one way to go, and that's out! As I recall, @brutalguyracing tried it and it worked really well. I just refound the video again last night and wanted to post it. Probably deserves it's own thread...
    Sandman614 likes this.
  7. Nov 13, 2015 at 8:06 AM
    #67
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I've done it too and it works well. For any concerns of it bending the arms out, when I reinstalled I had to bend the outer tabs in a little, meaning it did not bend.
    Crom[QUOTED] likes this.
  8. Nov 13, 2015 at 2:09 PM
    #68
    TacoBow
    TacoBow [OP] Intentionally cosmetically correct.
    Central PA
    2015 Tacoma TRD Sport 4x4 Quad LB
    The jack method does work well for a bushing that's defiant, but not so much for one that's rusted fast into the LCA.
    Pause the video at 49 seconds and inspect the body of that bushing once it releases from the control arm. Smooth and still cylindrical with no gaulded surfaces. Now compare that to the control arm bushing from the salty state of PA seen on page 1.
    Significant difference. The rust on the control arms themselves suggests a southern or later model year vehicle was depicted in the video.
    Not that it's a bad method, but that jack would have simply not prevailed here. Opting for a larger bottle jack or increasing the heat required to free the PA application would have damaged the LCA as nd4spdbh noted. PA corrosion issues often require much more heat than a hobby propane torch can provide. Their primary use here in a garage setting is for soldering or lighting cigarettes. Aside from a new vehicle purchase, a southern vehicle offered for sale is favored in the northern states for obvious reasons.
    DoorDing likes this.
  9. Nov 13, 2015 at 4:06 PM
    #69
    Crom
    Nick
    San Diego, CA
    Millions
    Thanks for commenting. I appreciate your thread and OP, very ingenious.
    Why not just just set the bushing on fire?
  10. Nov 14, 2015 at 6:44 AM
    #70
    TacoBow
    Central PA
    Setting them on fire is a proven option, one that Burnwithin used -
    I'm thinking his username implies he might carry a lighter.
    Having a garage filled with burnt rubber would have been more like spoiled cabbage and disappointment once the little lady got home. Not a safe move for me at all. I have a vertically challenged wife, 5 foot 1/2 inch and she will remind you of that .05 inch. After 24 years, I've learned not to fabricate any explanation for floating black soot tails that would surely be aloft as she drove into the garage.
    Lighting them up in the driveway would have been equally as precarious, since at that time, we lived next door to the local sheriff. Still, I agree that it is a good option if your location permits and fire safety precautions are observed.
    Crom likes this.
  11. Nov 18, 2015 at 7:52 PM
    #71
    White Bear
    White Bear Well-Known Member
    Louisiana
    Probably have the only 2nd Gen with an 8274 in the world.
    Tacobow, how did you remove the lip from the old bushing.
    I used a bottle jack a few removing a few of mine, it did spread the LCA a little but it seemed to spring back with no permanent spread. Thanks for the thread though.
  12. Apr 20, 2017 at 8:58 AM
    #72
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    *Zombie thread*
    http://www.ebay.com/itm/262286672915
    If I'm looking at the diagram right, I only need 4x part #16 (4819060020 - adjustment cams) and new bushings, if I'm taking the "rip and replace" method. Can anyone confirm that those cams come with all the parts or are there other parts in addition to those that I'll need?
    #72
  13. May 14, 2017 at 4:15 PM
    #73
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Here is a variation of the Redneck and bottle jack methods. Essentially, I used a bolt and a coupling nut to press out the bushings.
    For the larger bushing, you need a set of washers with 2 1/8" OD because the OEM washer on the bushing is not wide enough. 2 1/4" & 2 1/2" cups came from a BJ Service kit from Harbor Freight, #60827. 9-inch bolt (grade 8 $18) and coupling nut ($8)is a 3/4"-10 - got them on Zoro. Also get an assortment of 3/4" std and extra wide washers. Need a crescent wrench that opens 2.25". A propane torch may be needed to break the bushings free. Did't take much heat to remove mine; less than a minute for the small one and about 2 min for the large bushing. The large bushing has a smaller ID; so, you need a M12 bolt and assorted washers to press out that bushing (bottom 2 pics). The smaller bushing can accommodate a 3/4" bolt.
    Installing the bushings required a 2.5" ID cup for the large bushing. I'm using a customized cup - It's a standard 2.5" ID 2" long pipe but the inside was smooth out with a lathe to remove the seam. Same pipe is used to remove Moog ball joints, which are wider than OEM.
    Crom, Micbt25, zippo88 and 2 others like this.
  14. May 14, 2017 at 4:29 PM
    #74
    Pigpen
    Pigpen My truck is never clean
    Northwest Montana
    2012 AC Manual 4.0 4x4 Base Model
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Backcountrry MT 3 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 24F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, OME 90021 front shocks with 885 coils, SPC LR UCAs, Up2NoGood 2wd low range mod, 4 Wheel Campers Grandby slide in camper
    This is a great thread! Wish I would have read it last year :pout:
  15. Sep 8, 2022 at 1:31 PM
    #75
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB
    Cheers to YOU !! Nice work.
